nRF51 current consumption for common scenarios
Advertising 1:
TX power: +4dBm
payload: 10 bytes
Advertising 2:
TX power: +4dBm
adv interval: 1200ms
payload: 10 bytes
Advertising 3:
TX power: +4dBm
payload: 10 bytes
Advertising 4:
TX power: -20dBm
payload: 10 bytes
Total: 318 uA
Total: 89 uA
Connection interval: 1 second
Slave latency: 0
TX power: 0dBm
application processing: 0%
DCDC operation excluded
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
  • DCDC operation is excluded in all connection examples. With nRF51 third revision hardware, DCDC reduces current consumption with up to 20% during radio activity, see the nRF51822 PS 3.1 figure 11.
  • If using internal 32kHz RC with temperature calibration instead instead of crystal: add ~2 uA.
  • If using internal 32kHz RC without temperature calibration instead instead of crystal: add ~10 uA.
  • Very helpful. Thanks.
    If you have a key fob type or keyboard application where you are rarely sending any data but want quick response time, then the connection interval will be set low but the slave latency high since you can skip connections. If the connection interval is 0.040 seconds and latency is perhaps 25 intervals, what sort of current will you have? Would it be roughly equivalent to a connection interval of 1 second? What do you think are reasonable numbers for interval and latency for a remote shutter release for a camera?
    Thanks, Tom
    Thanks, Tom
