nRF51 current consumption for common scenarios
Advertising 1:
TX power: +4dBm
payload: 10 bytes
Advertising 2:
TX power: +4dBm
adv interval: 1200ms
payload: 10 bytes
Advertising 3:
TX power: +4dBm
payload: 10 bytes
Advertising 4:
TX power: -20dBm
payload: 10 bytes
Total: 318 uA
Total: 89 uA
Connection interval: 1 second
Slave latency: 0
TX power: 0dBm
application processing: 0%
DCDC operation excluded
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
  • DCDC operation is excluded in all connection examples. With nRF51 third revision hardware, DCDC reduces current consumption with up to 20% during radio activity, see the nRF51822 PS 3.1 figure 11.
  • If using internal 32kHz RC with temperature calibration instead instead of crystal: add ~2 uA.
  • If using internal 32kHz RC without temperature calibration instead instead of crystal: add ~10 uA.
  • Looking at advertising 2 and 3 can I conclude that 2ms application processing takes the difference of 33,4-25,7=7,7µA ?
    So for 10ms processing it will be ~80µA + 25µA = ~ 105µA
    And looking at adv 1+2 each, the intervall and the current consumtion is ~factor 60
    Does it mean I can roughly assume 105µA/5 = 21µA average consumption for 10ms processing every 6seconds at +4dBm?
