nRF51 current consumption for common scenarios
Advertising 1:
TX power: +4dBm
payload: 10 bytes
Advertising 2:
TX power: +4dBm
adv interval: 1200ms
payload: 10 bytes
Advertising 3:
TX power: +4dBm
payload: 10 bytes
Advertising 4:
TX power: -20dBm
payload: 10 bytes
Total: 318 uA
Total: 89 uA
Connection interval: 1 second
Slave latency: 0
TX power: 0dBm
application processing: 0%
DCDC operation excluded
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
  • DCDC operation is excluded in all connection examples. With nRF51 third revision hardware, DCDC reduces current consumption with up to 20% during radio activity, see the nRF51822 PS 3.1 figure 11.
  • If using internal 32kHz RC with temperature calibration instead instead of crystal: add ~2 uA.
  • If using internal 32kHz RC without temperature calibration instead instead of crystal: add ~10 uA.
  • @muhkuhns: The connection interval is 1200ms so the application processing utilization (proportional CPU usage) is 0.002/1.2=0.001667. For 0.001667 CPU utilization the nRF51 consumes 33.4-35.7=7.7uA. So for 0.01 (10ms) utilization you would cost you 7.7uA*0.01/0.001667=46.2uA.
    Another way to calculate this is to look at table 34 in the nRF51822 PS v3.1, which says that the CPU consumes 4.1mA when executing code from RAM. The calculated current consumption with 0.01 utilization is then 0.0041*0.01=41uA.
    If you process for 10ms every 6 seconds then the utilization is 0.01/6=0.002 and the current consumption is 0.0041*0.002=8.2uA. The 4dBm is just TX power of the radio and does not affect the current consumption for the application processing (CPU processing)
