nRF51 current consumption for common scenarios
Advertising 1:
TX power: +4dBm
payload: 10 bytes
Advertising 2:
TX power: +4dBm
adv interval: 1200ms
payload: 10 bytes
Advertising 3:
TX power: +4dBm
payload: 10 bytes
Advertising 4:
TX power: -20dBm
payload: 10 bytes
Total: 318 uA
Total: 89 uA
Connection interval: 1 second
Slave latency: 0
TX power: 0dBm
application processing: 0%
DCDC operation excluded
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
Slave latency: 0
TX power: 0dBm
  • DCDC operation is excluded in all connection examples. With nRF51 third revision hardware, DCDC reduces current consumption with up to 20% during radio activity, see the nRF51822 PS 3.1 figure 11.
  • If using internal 32kHz RC with temperature calibration instead instead of crystal: add ~2 uA.
  • If using internal 32kHz RC without temperature calibration instead instead of crystal: add ~10 uA.
  • @John These numbers were measured with a power analyzer on a single nRF51422 QFAC third revision chip. All RAM active. 3.3V supply voltage. Current consumption is however independent of supply voltage when using LDO mode, i.e. not DCDC mode or Low Voltage mode, see explanation on this thread.
    @sruthi I think these measurements were performed with S110 7.1.0 and S120 1.0.1. The DCDC mode was not recommended to use with nRF51 third revision until S110 8.0.0 / S120 2.0.0 / S130 1.0.0. So when using nRF51 third revision together with S110 8.0.0 or S120 2.0.0 or S130 1.0.0, the current consumpiton is slightly better than stated here, how much better depends on your application and supply voltage. The current consumption should be the same for S130 1.0.0 as for S110 8.0.0 when S130 is configured in peripheral mode. The current consumption should be the same for S130 1.0.0 as for S120 2.0.0 when S130 is configured in central mode.
