Test Events
BLE Tests
ZigBee Tests
Coordinator:
Router:
End Device:
Thread Tests
CoAP Server:
CoAP Client:
Distance Measurement
Results
Results were as follows:
Distances are in meters.
Summary
Olaf
Olaf
