nRF52840 long range demo
  • The RTT Viewer is a part of the J-Link Software and Documentation Pack install, which is required to use our devkits.
    The display shield is not currently available, it was originally developed for internal use only. I will check if we can either start production of the display, or make the production files available if someone else wants to manufacture them.
