PA / LNA support in S132
The S132 SoftDevice for the nRF52 has support for enable/disable switching of external Power Amplifiers (PA) and Low Noise Amplifiers (LNA) using GPIO pins. This was introduced in S132 version 2.0.0-7.alpha.
In the nRF51 there was an option to use the VDD_PA pin to detect when the radio was in TX mode, but this is not an option on the nRF52, making the SoftDevice solution necessary.
The following function can be used to enable PA/LNA signal. Adapt it as required in order to change the number of pins (1 or 2), pin numbers, polarity etc.
static void pa_lna_assist(uint32_t gpio_pa_pin, uint32_t gpio_lna_pin)
    ret_code_t err_code;
    static const uint32_t gpio_toggle_ch = 0;
    static const uint32_t ppi_set_ch = 0;
    static const uint32_t ppi_clr_ch = 1;
    // Configure SoftDevice PA/LNA assist
    ble_opt_t opt;
    memset(&opt, 0, sizeof(ble_opt_t));
    // Common PA/LNA config
    opt.common_opt.pa_lna.gpiote_ch_id  = gpio_toggle_ch;        // GPIOTE channel
    opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch;            // PPI channel for pin clearing
    opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch;            // PPI channel for pin setting
    // PA config
    opt.common_opt.pa_lna.pa_cfg.active_high = 1;                // Set the pin to be active high
    opt.common_opt.pa_lna.pa_cfg.enable      = 1;                // Enable toggling
    opt.common_opt.pa_lna.pa_cfg.gpio_pin    = gpio_pa_pin;      // The GPIO pin to toggle
    // LNA config
    opt.common_opt.pa_lna.lna_cfg.active_high  = 1;              // Set the pin to be active high
    opt.common_opt.pa_lna.lna_cfg.enable       = 1;              // Enable toggling
    opt.common_opt.pa_lna.lna_cfg.gpio_pin     = gpio_lna_pin;   // The GPIO pin to toggle
    err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt);
The plot below shows a measurement using the PA/LNA signal when starting up the radio in TX mode. In the plot, M2 is the point where the analyzer triggered on the PA signal from the GPIO. This is ~7.6 us after the radio was turned on (M1) and ~5.8 us before the radio starts to modulate data (M3). The measurement was performed using S132 version 2.0.0-7.alpha.
  • This is an excellent post on the subject of using the new PA and LNA support in S132 2.0.0, but you should change the title and remove the forward slash, or repost it under a better title. The slash just causes the search engine on the dev site to fail and even if you look under just pa or lna the posting does not show up. The only reason I found it was because it was linked to from another post.
