Example of PDM data
Digital microphone interface
- Clock (MIC_CLK)
- Data (MIC_DOUT)
PDM on nRF52832
PDM initialization
And play as below,
Note:
Requirements
- nRF52 SDK version 11.0.0
- nRF52832 DK 1.1.0 or later
PhilS
PhilS
in reply to PhilS
-1
PhilS
in reply to PhilS
-1
