Programming the nRF51822 Beacon Kit with the nRF51DK
  1. Download the ‘nRF51822 Bluetooth Smart Beacon Kit Firmware Files’ from here. (It is found under the tab ‘downloads’).
  2. Unzip the folder and install it.
  3. Open the project file ble_app_beacon_s110_pca20006.uvprojx in keil and build it. (It can be found in C:\Nordic Semiconductor\nRF51822 Beacon v1.1.0\Source Code\nrf51_beacon\ble_app_beacon\pca20006\s110\arm\).
  4. Connect the nRF51 DK to the computer with a micro USB cable. Also connect the adapter between the nRF51 DK debug output and the nRF51822 Smart Beacon. The picture below shows the connection points. Connection points
  5. Start nRFgo Studio to program the softdevice and application. In the 'Program SoftDevice' tab, hit browse and locate and upload the file s110_nrf51822_7.1.0_softdevice.hex. (Located in C:\Nordic Semiconductor\nRF51822 Beacon v1.1.1\SoftDevice\.) In the 'Program Application' tab locate the applicaion hex file that was built using Keil. If the example is not changed the file name is nrf51822_beacon_app.hex . (Located in C:\Nordic Semiconductor\nRF51822 Beacon v1.1.1\Source Code\nrf51_beacon\ble_app_beacon\pca20006\s110\arm\_build\.) The Beacon kit firmware also have a precompiled beacon app hex file that can be uploaded instead of the hex file from Keil. (Located in C:\Nordic Semiconductor\nRF51822 Beacon v1.1.1\Precompiled hex\.)
  • Wait, I'm confused. I followed the advice here and got a TC2030 cable, but it only comes in a six-pin format on the controller end. Tag-Connect seems to have a similar cable with a ten-pin controller connector, but it's called at TC2050. And my nRF51 DK board does in fact have a ten-pin "Debug out" port.
    There's a six-pin port in the middle of the board that looks like it could also be for programming a Beacon, but the documentation on it isn't very revealing.
    Did I make a mistake in ordering the (normal, ordinary) six-pin version of the TC2030?
