SD card interfacing
NOTE:
SD_Routines.c SD_Routines.h
  • Great library Kumar (and of course you Salman). Do you mind making a new blog with link to this code which uses the filesystem? This would make it easier for people to see it. Have a link to this for the hardware connections.
    I had problems when using nRF52, which was caused by this errata. The solution was to use SPI0 instead of SPIM0 (#define SPI0_USE_EASY_DMA 0). Implementing the workaround should also work.
