Segger Embedded Studio - A Cross Platform IDE
Download and Setup
Note: It is recommended, but not necessary, to use the most recent releases of the above software.
Importing a Keil uVision project
Note: From nRF5 SDK v14.1, Segger Embedded studio projects are officially supported. If using v14.1 or newer, please use the native SES-projects instead of the "import" function.
  • Open SEGGER Embedded Studio 3.10e
  • Select Tools -> Package Manager... and install the CMSIS-CORE Support Package
  • Select File -> Import IAR EWARM / Keil MDK Project...
  • Navigate to your local nRF5 SDK and in NRF5_SDK/examples/ble_peripheral/ble_app_beacon/ select pca10040/s132/arm5_no_packs/ble_app_beacon_pca10040_s132.uvprojx
  • The Import Build Configuration window will pop-up. Make sure you select to use Embedded Studio's Internal Toolchain (GCC/Clang) for now...
Nuances
If you've used Keil uVision with Nordic's SDK before, you might remember that each example BLE project contains a dummy project configuration for easy flashing of the SoftDevice. We don't need this in Embedded Studio and it can cause confusion so let's delete it.
  • Select Project -> Build Configurations... and under Public Configurations select flash_s132_nrf52_3.0.0_softdevice and delete it by clicking the - symbol in the upper right-hand corner of the pop-up window.
Your build configurations should look like this now:
And your project explorer:
Adding nRF5 MDK Files
Keil uVision uses Device packs for Startup/System Setup. This pack contains the nRF5 startup assembly files arm_startup_nrf52.s and the system setup files system_nrf52.c along with some header files. We will need to manually add these files to our Embedded Studio project.
  • Download ses_nrf51_startup.s and ses_nrf52_startup.s and save them into NRF5_SDK/components/toolchain/embedded_studio/ (create the folder)
  • Remove Cortex_M_Startup.s from the Internal Files folder in the Project Explorer
  • Right click the Internal Files folder and select Add Existing File...
  • In NRF5_SDK/components/toolchain/ select system_nrf52.c
  • Do the same for NRF5_SDK/components/toolchain/embedded_studio/ses_nrf52_startup.s
Your project explorer should look like this now:
  • Select Project -> Edit Options... and then select the Preprocessor tab
  • Add ../../../../../../components/device to the User Include Directories field to include the device header files in our Embedded Studio project
Your user include directories should look like this now:
Peer Manager/Flash Data Storage
Most of the examples in the SDK use Peer Manager. Peer Manager uses Flash Data Storage and Flash Storage. To indicate where information from Peer Manager (e.g bonding information) should be store page tags in flash (section variables) is used. These page tags need to be written to flash. To do so, flash_placement.xml and thumb_crt0.s have to be added and modified. Thanks to @RK and @Håkon Alseth in this post.
Flash_placement.xml can be located in the project folder, for example: ..\nRF5_SDK_xxx\examples\ble_peripheral\ble_app_gls\pca10040\s132\arm5_no_packs
You have to generate flash_placement.xml using text editor, notepad for example. After that you can import it by right click on the project name and choose "Import Section placement"
For SDK v14 please use these updated files:
flash_placement.xml
thumb_crt0.s
flash_placement.xml should then look like the following (SDK 12):
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
  <MemorySegment name="$(FLASH_NAME:FLASH)">
    <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
    <ProgramSection alignment="4" load="Yes" name=".init" />
    <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
    <ProgramSection alignment="4" load="Yes" name=".text" />
    <ProgramSection alignment="4" load="Yes" name=".dtors" />
    <ProgramSection alignment="4" load="Yes" name=".ctors" />
    <ProgramSection alignment="4" load="Yes" name=".rodata" />
    <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
    <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
    <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
    <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
    <ProgramSection alignment="4" keep="Yes" load="Yes" runin=".fs_data_run" name=".fs_data" />
  </MemorySegment>
  <MemorySegment name="$(RAM_NAME:RAM);SRAM">
    <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START:$(SRAM_START:))" />
    <ProgramSection alignment="4" load="No" name=".fast_run" />
    <ProgramSection alignment="4" load="No" name=".data_run" />
    <ProgramSection alignment="4" load="No" name=".tdata_run" />
    <ProgramSection alignment="4" load="No" keep="Yes" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
    <ProgramSection alignment="4" load="No" name=".bss" />
    <ProgramSection alignment="4" load="No" name=".tbss" />
    <ProgramSection alignment="4" load="No" name=".non_init" />
    <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
    <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" />
    <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
  </MemorySegment>
  <MemorySegment name="$(FLASH2_NAME:FLASH2)">
    <ProgramSection alignment="4" load="Yes" name=".text2" />
    <ProgramSection alignment="4" load="Yes" name=".rodata2" />
    <ProgramSection alignment="4" load="Yes" runin=".data2_run" name=".data2" />
  </MemorySegment>
  <MemorySegment name="$(RAM2_NAME:RAM2)">
    <ProgramSection alignment="4" load="No" name=".data2_run" />
    <ProgramSection alignment="4" load="No" name=".bss2" />
  </MemorySegment>
</Root>
Thumb_crt0.s is located in the Segger Embedded studio install folder: ..\SEGGER\SEGGER Embedded Studio <v. xx>\source
In thumb_crt0.s, fs_data should be added, it can be added after tdata (thanks to @RK):
ldr r2, =__tdata_end__
bl memory_copy
# ADD HERE ...
ldr r0, =__fs_data_load_start__
ldr r1, =__fs_data_start__
ldr r2, =__fs_data_end__
bl memory_copy
# TO HERE ...
Building
Our project should build successfully now:
  • Build the project by selecting Build -> Build ble_app_beacon_pca10040_s132 or by simply hitting F7
Notice that the compiled binary is placed at the beginning of FLASH and SRAM. This project requires a SoftDevice so let's reserve the correct amount of room for it.
  • Select Project -> Edit Options... and then select the Linker tab
  • Paste the following into the Section Placement Macros field (SDKv12):
FLASH_START=0x1F000
SRAM_START=0x20002000
Your Project Options should look like this now:
  • Re-build the project by selecting Build -> Rebuild ble_app_beacon_pca10040_s132 or by simply hitting Alt + F7
Now you should see that space has been reserved in FLASH and SRAM for the SoftDevice:
Fine-Tuning
  • Add the definition NO_VTOR_CONFIG to the Preprocessor Definitions field (this tells Embedded Studio to expect a SoftDevice to be present and that it will forward exceptions/interrupts to the application)
Your Preprocessor Definitions should look like this now:
Flashing the SoftDevice with our application
  • Select Project -> Edit Options... and then select the Loader tab
  • Add the absolute path to the SoftDevice NRF5_SDK/components/softdevice/s132/hex/s132_nrf52_3.0.0_softdevice.hex to the Additional Load File[0] field
Your Loader options should look like this now:
Running
  • Connect your nRF5 Development Kit to your computer and turn it on
  • Run the application by selecting Debug -> Build and Run or hitting Ctrl + F5
Your Output log should look like this now:
The application should be running on your nRF5 DK and LED1 should be blinking. You should be able to scan for and find the beacon using nRF Connect.
Debugging
  • Select Debug -> Go or simply hit F5
You should see that you have entered the debugging interface now:
Notice that our application has ran until the first line in main() and is halted. You should experiment with debugging in Embedded Studio. It has all the debugging features you would expect from a professional IDE and more (makes sense as SEGGER makes the debuggers as well).
Peer manager
To make peer manager (SDK 10(?), SDK 11, SDK 12) work with Segger Embedded Studio the modifications in this post are needed.
Troubleshooting
If you are stuck, previous blog posts (although deprecated) may help you fix your problem (also see the questions section):
  • @MikeLemon, from my very limited experience... you WILL get such a compilation error if the appropriate "include" directories are not referenced.
    If you refer to your original screenshot, you'll note that you had clicked on the "Internal Files" folder in Project Explorer when you pulled up the "Set User Include Directories" window. If I select the project name in Project Explorer, however, it shows this:
    If you've done this already, I'm not sure what it could be... maybe an indication of some other setup issue?
    Unless one of the gurus here can make a better recommendation, maybe [1] try this again from scratch (maybe replace the entire example ble_app_beacon directory with the default one from an original SDK zip file) and follow the directions again, or [2] manually entering the info in the "Set User Include Directories" window... again, after selecting the project name in the Project Explorer window.
    Here's a copy and paste of mine (which should work if you retained the original SDK folder structure after unzipping):
    $(PackagesDir)/CMSIS_4/CMSIS/Include
    ../../../config
    ../../../../../../components/ble/ble_advertising
    ../../../../../../components/ble/ble_dtm
    ../../../../../../components/ble/ble_racp
    ../../../../../../components/ble/ble_services/ble_ancs_c
    ../../../../../../components/ble/ble_services/ble_ans_c
    ../../../../../../components/ble/ble_services/ble_bas
    ../../../../../../components/ble/ble_services/ble_bas_c
    ../../../../../../components/ble/ble_services/ble_cscs
    ../../../../../../components/ble/ble_services/ble_cts_c
    ../../../../../../components/ble/ble_services/ble_dfu
    ../../../../../../components/ble/ble_services/ble_dis
    ../../../../../../components/ble/ble_services/ble_gls
    ../../../../../../components/ble/ble_services/ble_hids
    ../../../../../../components/ble/ble_services/ble_hrs
    ../../../../../../components/ble/ble_services/ble_hrs_c
    ../../../../../../components/ble/ble_services/ble_hts
    ../../../../../../components/ble/ble_services/ble_ias
    ../../../../../../components/ble/ble_services/ble_ias_c
    ../../../../../../components/ble/ble_services/ble_lbs
    ../../../../../../components/ble/ble_services/ble_lbs_c
    ../../../../../../components/ble/ble_services/ble_lls
    ../../../../../../components/ble/ble_services/ble_nus
    ../../../../../../components/ble/ble_services/ble_nus_c
    ../../../../../../components/ble/ble_services/ble_rscs
    ../../../../../../components/ble/ble_services/ble_rscs_c
    ../../../../../../components/ble/ble_services/ble_tps
    ../../../../../../components/ble/common
    ../../../../../../components/ble/nrf_ble_qwr
    ../../../../../../components/ble/peer_manager
    ../../../../../../components/boards
    ../../../../../../components/drivers_nrf/clock
    ../../../../../../components/drivers_nrf/common
    ../../../../../../components/drivers_nrf/comp
    ../../../../../../components/drivers_nrf/delay
    ../../../../../../components/drivers_nrf/gpiote
    ../../../../../../components/drivers_nrf/hal
    ../../../../../../components/drivers_nrf/i2s
    ../../../../../../components/drivers_nrf/lpcomp
    ../../../../../../components/drivers_nrf/pdm
    ../../../../../../components/drivers_nrf/power
    ../../../../../../components/drivers_nrf/ppi
    ../../../../../../components/drivers_nrf/pwm
    ../../../../../../components/drivers_nrf/qdec
    ../../../../../../components/drivers_nrf/rng
    ../../../../../../components/drivers_nrf/rtc
    ../../../../../../components/drivers_nrf/saadc
    ../../../../../../components/drivers_nrf/spi_master
    ../../../../../../components/drivers_nrf/spi_slave
    ../../../../../../components/drivers_nrf/swi
    ../../../../../../components/drivers_nrf/timer
    ../../../../../../components/drivers_nrf/twi_master
    ../../../../../../components/drivers_nrf/twis_slave
    ../../../../../../components/drivers_nrf/uart
    ../../../../../../components/drivers_nrf/usbd
    ../../../../../../components/drivers_nrf/wdt
    ../../../../../../components/libraries/bsp
    ../../../../../../components/libraries/button
    ../../../../../../components/libraries/crc16
    ../../../../../../components/libraries/crc32
    ../../../../../../components/libraries/csense
    ../../../../../../components/libraries/csense_drv
    ../../../../../../components/libraries/ecc
    ../../../../../../components/libraries/experimental_section_vars
    ../../../../../../components/libraries/fds
    ../../../../../../components/libraries/fstorage
    ../../../../../../components/libraries/gpiote
    ../../../../../../components/libraries/hardfault
    ../../../../../../components/libraries/hci
    ../../../../../../components/libraries/led_softblink
    ../../../../../../components/libraries/log
    ../../../../../../components/libraries/log/src
    ../../../../../../components/libraries/low_power_pwm
    ../../../../../../components/libraries/mem_manager
    ../../../../../../components/libraries/pwm
    ../../../../../../components/libraries/queue
    ../../../../../../components/libraries/scheduler
    ../../../../../../components/libraries/slip
    ../../../../../../components/libraries/strerror
    ../../../../../../components/libraries/timer
    ../../../../../../components/libraries/twi
    ../../../../../../components/libraries/uart
    ../../../../../../components/libraries/usbd
    ../../../../../../components/libraries/usbd/class/audio
    ../../../../../../components/libraries/usbd/class/cdc
    ../../../../../../components/libraries/usbd/class/cdc/acm
    ../../../../../../components/libraries/usbd/class/hid
    ../../../../../../components/libraries/usbd/class/hid/generic
    ../../../../../../components/libraries/usbd/class/hid/kbd
    ../../../../../../components/libraries/usbd/class/hid/mouse
    ../../../../../../components/libraries/usbd/class/msc
    ../../../../../../components/libraries/usbd/config
    ../../../../../../components/libraries/util
    ../../../../../../components/softdevice/common/softdevice_handler
    ../../../../../../components/softdevice/s132/headers
    ../../../../../../components/softdevice/s132/headers/nrf52
    ../../../../../../components/toolchain
    ../../../../../../external/segger_rtt
    ../config
    I wish you luck!
    ../../../config
    ../config
    I wish you luck!
