Talking to Ultrasonic Distance Sensor HC-SR04 using nRF51822
Communicating with Ultrasonic Distance Sensor HC-SR04 using nRF51-DK (nRF51822/nRF51422), and transmitting measured distance over BLE UART.
http://electronut.in/nrf51-hcsr04/
  • hello sir,
    I followed the same steps as explained by you to interface Hc SR 04. The only difference in my case is I am using nRF52832 and want to print the distance on serial monitor. But couldnot able to get it. Please help me. This is my code for refrence:-
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup uart_example_main main.c
     * @ingroup uart_example
     * @brief UART Example Application main file.
     * This file contains the source code for a sample application using UART.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <math.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    //#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
    #define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    void gpio_toggle(void);
    void trig_pulse(void);
    float compute_distance(void);
    #define pinTrig 5
    #define pinEcho 7
    #define InPin 1
    #define OutPin 0
    float countToUs ;
    float distance ;
    uint32_t tCount ;
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    #ifdef ENABLE_LOOPBACK_TEST
    /* Use flow control in loopback test. */
    #define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
    /** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
    static void show_error(void)
        bsp_board_leds_on();
        while (true)
            // Do nothing.
    /** @brief Function for testing UART loop back.
     *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
     *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
    static void uart_loopback_test()
        uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
        uint8_t   rx_data;
        // Start sending one byte and see if you get the same
        for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
            uint32_t err_code;
            while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
            nrf_delay_ms(10);
            err_code = app_uart_get(&rx_data);
            if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
                show_error();
        return;
    #else
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
      NRF_GPIO->OUT = (1 << pinTrig) ;
      nrf_delay_ms(2000);
      NRF_GPIO->OUT = (0 << pinTrig) ;
      nrf_delay_ms(2000);
     // send 12us trigger pulse
    //    _
    // __| |__
    nrf_gpio_pin_clear(pinTrig);
    nrf_delay_us(20);
    nrf_gpio_pin_set(pinTrig);
    nrf_delay_us(12);
    nrf_delay_us(20);
    // set up and start Timer1
    void start_timer(void)
      NRF_TIMER1->MODE = TIMER_MODE_MODE_Timer;
      NRF_TIMER1->TASKS_CLEAR = 1;
      // set prescalar n
      // f = 16 MHz / 2^(n)
      uint8_t prescaler = 0;
        NRF_TIMER1->PRESCALER = prescaler;
        NRF_TIMER1->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
      // 16 MHz clock generates timer tick every 1/(16000000) s = 62.5 nano s
      // With compare enabled, the interrupt is fired every: 62.5 * comp1 nano s
      // = 0.0625*comp1 micro seconds
      // multiply this by 2^(prescalar)
      uint16_t comp1 = 500;
      // set compare
        NRF_TIMER1->CC[1] = comp1;
      // set conversion factor
      countToUs = 0.0625*comp1*(1 << prescaler);
      printf("timer tick = %f us\n", countToUs);
      // enable compare 1
        NRF_TIMER1->INTENSET =
        (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
      // use the shorts register to clear compare 1
      NRF_TIMER1->SHORTS = (TIMER_SHORTS_COMPARE1_CLEAR_Enabled <<
                            TIMER_SHORTS_COMPARE1_CLEAR_Pos);
      // enable IRQ
      NVIC_EnableIRQ(TIMER1_IRQn);
      // start timer
      NRF_TIMER1->TASKS_START = 1;
    // Timer 1 IRQ handler
    // just increment count
    void TIMER1_IRQHandler(void)
        if (NRF_TIMER1->EVENTS_COMPARE[1] &&
          NRF_TIMER1->INTENSET & TIMER_INTENSET_COMPARE1_Msk) {
        // clear compare register event
        NRF_TIMER1->EVENTS_COMPARE[1] = 0;
        tCount++;
    // Reverses a string 'str' of length 'len'
    void reverse(char* str, int len)
        int i = 0, j = len - 1, temp;
        while (i < j) {
            temp = str[i];
            str[i] = str[j];
            str[j] = temp;
            i++;
            j--;
    // Converts a given integer x to string str[].
    // d is the number of digits required in the output.
    // If d is more than the number of digits in x,
    // then 0s are added at the beginning.
    int intToStr(int x, char str[], int d)
        int i = 0;
        while (x) {
            str[i++] = (x % 10) + '0';
            x = x / 10;
        // If number of digits required is more, then
        // add 0s at the beginning
        while (i < d)
            str[i++] = '0';
        reverse(str, i);
        str[i] = '\0';
        return i;
    // Converts a floating-point/double number to a string.
    void ftoa(float n, char* res, int afterpoint)
        // Extract integer part
        int ipart = (int)n;
        // Extract floating part
        float fpart = n - (float)ipart;
        // convert integer part to string
        int i = intToStr(ipart, res, 0);
        // check for display option after point
        if (afterpoint != 0) {
            res[i] = '.'; // add dot
            // Get the value of fraction part upto given no.
            // of points after dot. The third parameter
            // is needed to handle cases like 233.007
            fpart = fpart * pow(10, afterpoint);
            intToStr((int)fpart, res + i + 1, afterpoint);
    static void gpio_init(void)
       ret_code_t err_code ;
       err_code = nrf_drv_gpiote_init() ;
       APP_ERROR_CHECK(err_code) ;
       nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false) ;
       err_code = nrf_drv_gpiote_out_init(DEBUG_PIN_OUT , &out_config) ;
       nrf_drv_gpiote_out_set(DEBUG_PIN_OUT) ;
       nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
       in_config.pull = NRF_GPIO_PIN_PULLUP ;
       err_code = nrf_drv_gpiote_in_init(DEBUG_PIN_IN , &in_config , in_pin_handler) ;
     * @brief Function for main application entry.
    /*  //  bsp_board_init(BSP_INIT_LEDS);
       nrf_gpio_cfg_output(pinTrig);   // pin no. 5
       nrf_gpio_cfg_output(OutPin);    // pin no. 0
       nrf_gpio_cfg_input(InPin , BUTTON_PULL) ;  // pin no. 1
     //   NRF_GPIO->DIRSET = 0x00000020 ;
        nrf_gpio_pin_clear(OutPin);
       while(true)
         gpio_toggle() ;
        while(!nrf_gpio_pin_read(InPin))
          nrf_gpio_pin_set(OutPin);
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
              NRF_UART_BAUDRATE_115200
    #else
              NRF_UARTE_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
    #ifndef ENABLE_LOOPBACK_TEST
        printf("\r\nUART example started.\r\n");
        distance = 0 ;
        nrf_gpio_cfg_input(pinEcho , BUTTON_PULL) ;
        printf("Interfacing of HC-SR-04 with nRF52:-") ;
       // char res[20];
        char test[20];
      //  float n = 233.007;
        while(true)
          printf("inside loop");
          trig_pulse() ;
          printf("After trig pulse");
        //  printf("\"res=%s\"\n", res);
        //  nrf_delay_ms(1000);
           // listen for echo and time it
      //       ____________
      // _____|            |___
      // wait till Echo pin goes high
      while(!nrf_gpio_pin_read(pinEcho));
      // reset counter
      tCount = 0;
      // wait till Echo pin goes low
      while(nrf_gpio_pin_read(pinEcho));
      // calculate duration in us
      float duration = countToUs*tCount;
      // dist = duration * speed of sound * 1/2
      // dist in cm = duration in us * 10^-6 * 340.29 * 100 * 1/2
      float distance = duration*0.017;
      ftoa(distance, test, 4);
      printf("\"test=%s\"\n", test);
      nrf_delay_ms(1000);
        while (true)
            uint8_t cr;
            while (app_uart_get(&cr) != NRF_SUCCESS);
            while (app_uart_put(cr) != NRF_SUCCESS);
            if (cr == 'q' || cr == 'Q')
                printf(" \r\nExit!\r\n");
                while (true)
                    // Do nothing.
    #else
        // This part of the example is just for testing the loopback .
        while (true)
            uart_loopback_test();
  • hello sir,
    /** @file
    #include <stdint.h>
    #include <stdio.h>
    #include <math.h>
    #include "nrf.h"
    #include "bsp.h"
    #define pinTrig 5
    #define pinEcho 7
    #define InPin 1
    #define OutPin 0
    float countToUs ;
    float distance ;
    uint32_t tCount ;
        while (true)
            // Do nothing.
        uint8_t   rx_data;
            uint32_t err_code;
            nrf_delay_ms(10);
                show_error();
        return;
    #else
      nrf_delay_ms(2000);
      nrf_delay_ms(2000);
    //    _
    // __| |__
    nrf_delay_us(20);
    nrf_delay_us(12);
    nrf_delay_us(20);
      // set prescalar n
      // set compare
      // enable compare 1
      // enable IRQ
      // start timer
        tCount++;
        while (i < j) {
            temp = str[i];
            str[i] = str[j];
            str[j] = temp;
            i++;
            j--;
        int i = 0;
        while (x) {
            x = x / 10;
        while (i < d)
            str[i++] = '0';
        reverse(str, i);
        str[i] = '\0';
        return i;
        int ipart = (int)n;
       while(true)
         gpio_toggle() ;
        uint32_t err_code;
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
    #else
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             err_code);
        distance = 0 ;
       // char res[20];
        char test[20];
        while(true)
          trig_pulse() ;
      //       ____________
      // _____|            |___
      // reset counter
      tCount = 0;
      nrf_delay_ms(1000);
        while (true)
            uint8_t cr;
                while (true)
                    // Do nothing.
    #else
        while (true)
