Using millis() like in Arduino.
Here are two simple functions to use when you want to use timestamps for time measurement.
uint32_t millis(void)
  return(app_timer_cnt_get() / 32.768);
and for comperison of current with given timestamp with rollover correction (thanks to Nicolas Brunner for the correction):
#define OVERFLOW ((uint32_t)(0xFFFFFFFF/32.768))
uint32_t compareMillis(uint32_t previousMillis, uint32_t currentMillis)
  if(currentMillis < previousMillis) return(currentMillis + OVERFLOW + 1 - previousMillis);
  return(currentMillis - previousMillis);
You can use it like:
uint32_t myTimeStamp = millis();
//... some code here
if(compareMillis(myTimeStamp, millis()) > 2000)
  printf("2 seconds have passed\n");
Here are unit tests https://github.com/schef/nrf_millis
  • Aha..i had problems yesterday thank God i connect the buzzer to beep on every startup and it was beeping every 8 minutes :)
    The use-case was:
    #define MINUTE 60*1000
    uint32 millisPassed(uint32_t localMillis)
        return(compareMillis(localMillis, millis()));
    This is what i used for help and the requirement was:
    if(millisPassed(lastMessage) > 15 * MINUTE)
        sd_nvic_SystemReset();
    Is there another solution for the OVERFLOW without using hardcoded number but the PRESCALER?
    The use-case was:
