40uA on Power OFF nrf52832 s223
Hello, My problem is to much current c.a. 40uA in POWER OFF mode. Below attach code:
void power_down()
	nrf_gpio_pin_clear(22);			// Wylacz mostek tensometryczny
	nrf_delay_ms(10);
	nrf_gpio_pin_clear(20);			// Wylacz LDO 2V5
	nrf_delay_ms(10);
	timer_disable();
	saadc_sampling_event_disable();
	sd_clock_hfclk_release();
	// Disable TWI ready for sleep
	NRF_TWI0->ENABLE= TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
	// shut down the dcdc
	sd_power_dcdc_mode_set(NRF_POWER_DCDC_DISABLE);
	sd_power_system_off();
    nrf_gpio_cfg_output(20);		// Ustaw EN LDO jako output
	nrf_gpio_pin_set(20);		// Wlacz LDO
	nrf_gpio_cfg_output(22);		// Ustaw mosfet jako output
	nrf_gpio_pin_set(22);		// Wlacz mostek tensometryczny
	nrf_gpio_cfg_input(14, NRF_GPIO_PIN_PULLUP);	// Ustaw mosfet jako input
	nrf_gpio_cfg_input(3, NRF_GPIO_PIN_PULLUP);		// Ustaw jako wejsicie INT1 z MMA8452
	nrf_gpio_cfg_input(18, NRF_GPIO_PIN_PULLUP);	// Ustaw jako wejsicie INT2 z MMA8452
	// ANT+ init
    uint32_t err_code;
    utils_setup();
    softdevice_setup();
    ant_state_indicator_init(m_ant_bpwr.channel_number, BPWR_SENS_CHANNEL_TYPE);
    simulator_setup();
    profile_setup();
	// This pin is used for waking up from System OFF and is active low, enabling sense capabilities.
    nrf_gpio_cfg_sense_input(PIN_GPIO_WAKEUP, BUTTON_PULL, NRF_GPIO_PIN_SENSE_LOW);
	//Enable DCDC
	err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
    // Workaround for PAN_028 rev1.1 anomaly 22 - System: Issues with disable System OFF mechanism
    nrf_delay_ms(1);
    // TWI
    twi_init();
    //HMC5883L_init();
    //MMA8452Q_init();
    // SAADC
    saadc_sampling_event_init();
    saadc_init();
    while(FORCE_SLEEP == 0)
	   __SEV();
       __WFE();
	   __WFE();
    power_down();
I think that any pherips is disabled... No chips connected to TWI. I would be gratefull for help.
