Sharp Memory LCD LS044Q7DH01
Edit: The code posted below works on the 96x96 3V(LS013B4DN04) variant of the display, I still have no idea why it doesn't work on LS044Q7DH01, but I'm guessing it doesnt have much to do with the nordic chip. I'll post an update here if I get a reply from Sharp..
Edit2: Mystery solved..... Clearly these are somewhat fragile..
image description
Hi developers. I've seen this been asked before but the answers don't really show me any working examples.
Setup picture
image description
I get no response from the display (not even when I power on..?). I am fairly certain I have connected it correct, I made as simple code as meaningfully possible, and I have a scope on the SCLK, SS and MOSI line
i feel i've checked "everything"
  • Connection on FPC contact, and order of pins
  • SPI signal
  • Timing on init
  • Tried all combinations of SPI modes and CS configs
  • Timing on SPI signal
  • Lower SPI frequencies
  • Voltage levels
  • (but I am pretty sure there must be something i've missed)
Datasheet LS044Q7DH01
Appnote from Sharp
Would appreciate any insight so I can get any further..
Code that works on LS013B4DN04:
#include <stdint.h>
#include "nrf_delay.h"
#include "boards.h"
#include "nrf_drv_spi.h"
#define DISP_SPI_INSTANCE 1
#define DISP_SS_PIN 12
#define SCLK_DISP 22
#define MOSI_DISP 23
#define DISP_VCOM 24                /**< VCOM has to be toggled since EXTMODE = H */
#define DISPLAY_CS_IDLE         nrf_gpio_pin_write(DISP_SS_PIN, 0) // Set CS pin low
#define DISPLAY_CS_ACTIVE       nrf_gpio_pin_write(DISP_SS_PIN, 1) // Set CS pin high
// Commands
#define MLCD_WR 0x80 //MLCD write line command
#define MLCD_CM 0x20 //MLCD clear memory command
#define MLCD_NO 0x00 //MLCD NOP command (used to switch VCOM)
//LCD resolution
#define MLCD_XRES 320 //pixels per horizontal line
#define MLCD_YRES 240 //pixels per vertical line
#define MLCD_BYTES_LINE MLCD_XRES / 8 //number of bytes in a line
#define MLCD_BUF_SIZE MLCD_YRES * MLCD_BYTES_LINE
//defines the VCOM bit in the command word that goes to the LCD
#define VCOM_HI 0x40
#define VCOM_LO 0x00
#define HIGH 1
#define LOW 0
#define DISP_ON_PIN 11
static const unsigned char BitReverseTable256[] =
  0x00, 0x80, 0x40, 0xC0, 0x20, 0xA0, 0x60, 0xE0, 0x10, 0x90, 0x50, 0xD0, 0x30, 0xB0, 0x70, 0xF0,
  0x08, 0x88, 0x48, 0xC8, 0x28, 0xA8, 0x68, 0xE8, 0x18, 0x98, 0x58, 0xD8, 0x38, 0xB8, 0x78, 0xF8,
  0x04, 0x84, 0x44, 0xC4, 0x24, 0xA4, 0x64, 0xE4, 0x14, 0x94, 0x54, 0xD4, 0x34, 0xB4, 0x74, 0xF4,
  0x0C, 0x8C, 0x4C, 0xCC, 0x2C, 0xAC, 0x6C, 0xEC, 0x1C, 0x9C, 0x5C, 0xDC, 0x3C, 0xBC, 0x7C, 0xFC,
  0x02, 0x82, 0x42, 0xC2, 0x22, 0xA2, 0x62, 0xE2, 0x12, 0x92, 0x52, 0xD2, 0x32, 0xB2, 0x72, 0xF2,
  0x0A, 0x8A, 0x4A, 0xCA, 0x2A, 0xAA, 0x6A, 0xEA, 0x1A, 0x9A, 0x5A, 0xDA, 0x3A, 0xBA, 0x7A, 0xFA,
  0x06, 0x86, 0x46, 0xC6, 0x26, 0xA6, 0x66, 0xE6, 0x16, 0x96, 0x56, 0xD6, 0x36, 0xB6, 0x76, 0xF6,
  0x0E, 0x8E, 0x4E, 0xCE, 0x2E, 0xAE, 0x6E, 0xEE, 0x1E, 0x9E, 0x5E, 0xDE, 0x3E, 0xBE, 0x7E, 0xFE,
  0x01, 0x81, 0x41, 0xC1, 0x21, 0xA1, 0x61, 0xE1, 0x11, 0x91, 0x51, 0xD1, 0x31, 0xB1, 0x71, 0xF1,
  0x09, 0x89, 0x49, 0xC9, 0x29, 0xA9, 0x69, 0xE9, 0x19, 0x99, 0x59, 0xD9, 0x39, 0xB9, 0x79, 0xF9,
  0x05, 0x85, 0x45, 0xC5, 0x25, 0xA5, 0x65, 0xE5, 0x15, 0x95, 0x55, 0xD5, 0x35, 0xB5, 0x75, 0xF5,
  0x0D, 0x8D, 0x4D, 0xCD, 0x2D, 0xAD, 0x6D, 0xED, 0x1D, 0x9D, 0x5D, 0xDD, 0x3D, 0xBD, 0x7D, 0xFD,
  0x03, 0x83, 0x43, 0xC3, 0x23, 0xA3, 0x63, 0xE3, 0x13, 0x93, 0x53, 0xD3, 0x33, 0xB3, 0x73, 0xF3,
  0x0B, 0x8B, 0x4B, 0xCB, 0x2B, 0xAB, 0x6B, 0xEB, 0x1B, 0x9B, 0x5B, 0xDB, 0x3B, 0xBB, 0x7B, 0xFB,
  0x07, 0x87, 0x47, 0xC7, 0x27, 0xA7, 0x67, 0xE7, 0x17, 0x97, 0x57, 0xD7, 0x37, 0xB7, 0x77, 0xF7,
  0x0F, 0x8F, 0x4F, 0xCF, 0x2F, 0xAF, 0x6F, 0xEF, 0x1F, 0x9F, 0x5F, 0xDF, 0x3F, 0xBF, 0x7F, 0xFF
static char vComState = 0;
static const nrf_drv_spi_t disp_spi = NRF_DRV_SPI_INSTANCE(DISP_SPI_INSTANCE);  /**< SPI instance. */
void LS044Q7DH01_Init(void){
    uint32_t err_code;
    // SPI Init
    nrf_drv_spi_config_t disp_spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    disp_spi_config.ss_pin   = NULL;
    disp_spi_config.miso_pin = NULL;
    disp_spi_config.mosi_pin = MOSI_DISP;
    disp_spi_config.sck_pin  = SCLK_DISP;
    disp_spi_config.mode = NRF_DRV_SPI_MODE_0;
    disp_spi_config.orc = 0x00;
    disp_spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
    disp_spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
    err_code = nrf_drv_spi_init(&disp_spi, &disp_spi_config, NULL);
    nrf_gpio_cfg_output(DISP_SS_PIN);
    DISPLAY_CS_IDLE;
    nrf_gpio_cfg_output(DISP_VCOM);
    // SPI init done
void dispTest(unsigned char in, uint8_t line){
    uint32_t err_code;
    line = BitReverseTable256[line];
    unsigned char dataToSend[16] = {MLCD_WR, line, // Start with write, line addr, data
        in, in, in, in, in, in, in, in, in, in,
        in, in,
        0x00}; // end with zero trailer
    DISPLAY_CS_ACTIVE;
    err_code = nrf_drv_spi_transfer(&disp_spi, dataToSend, 16, NULL, NULL);
    DISPLAY_CS_IDLE;
void dispToggleVCOM(void){
    // Toggle pin (if EXTMODE = H)
    nrf_gpio_pin_toggle(DISP_VCOM);
    // Send toggle message (if EXTMODE = L)
    unsigned char dataToSend[2] = {0x00, 0x00};
    if (vComState) dataToSend[0] = VCOM_HI;
    else dataToSend[0] = VCOM_LO;
    vComState = 1 - vComState;
    DISPLAY_CS_ACTIVE;
    nrf_drv_spi_transfer(&disp_spi, dataToSend, 2, NULL, NULL);
    DISPLAY_CS_IDLE;
void dispClear(void){
    unsigned char dataToSend[2] = {MLCD_CM, 0x00};
    DISPLAY_CS_ACTIVE;
    DISPLAY_CS_IDLE;
int main(void){
    /* Configure board. */
    bsp_board_leds_init();
    nrf_delay_us(100);
    nrf_gpio_cfg_output(DISP_ON_PIN);
    nrf_gpio_pin_write(DISP_ON_PIN, HIGH);
    nrf_delay_us(100);
    LS044Q7DH01_Init();
    dispClear();
    nrf_delay_us(200);
    while(1){
        unsigned char i = 0;
        unsigned char y = 96;
        for(i = 0; i<= y; i++){
            dispTest(0x00, i);
            dispToggleVCOM();
            nrf_delay_ms(10);
            dispTest(0xFF, i);
            dispToggleVCOM();
            nrf_delay_ms(10);
        //nrf_delay_ms(1000);
        dispClear();
        dispToggleVCOM();
        bsp_board_led_invert(1);
