I am using SDK 12.2.0 with soft device s132 3.0.0 using NRF52 Development Board(PCA10040).
I want to update Battery level to central device/APP.As i want to use code for my custom Board i.e, battery operated ,so i want to configure in Low power mode.In 12.0.0 proximity example .there is an option to enable Low power mode.So,i Enabled.But it is not updating the Values.
#ifndef SAADC_CONFIG_LP_MODE
#define SAADC_CONFIG_LP_MODE 1
I am using the exact example problem,But it is not Updating the Values.
If i test the SAADC seperatly,There it is working.All code is similar Don't know how it is not working.
void SAADC_IRQHandler(void)
if (nrf_saadc_event_check(NRF_SAADC_EVENT_END))
nrf_saadc_event_clear(NRF_SAADC_EVENT_END);
NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_END));
NRF_LOG_INFO(" SAADC in SAADC_IRQHandler : Inside NRF_SAADC_EVENT_END \r\n");
if (!m_cb.low_power_mode || m_cb.conversions_end)
NRF_LOG_INFO(" SAADC in SAADC_IRQHandler : Inside !m_cb.low_power_mode || m_cb.conversions_end. \r\n");
nrf_drv_saadc_evt_t evt;
evt.type = NRF_DRV_SAADC_EVT_DONE;
evt.data.done.p_buffer = (nrf_saadc_value_t *)m_cb.p_buffer;
evt.data.done.size = m_cb.buffer_size;
if (m_cb.p_secondary_buffer == NULL)
m_cb.adc_state = NRF_SAADC_STATE_IDLE;
m_cb.p_buffer = m_cb.p_secondary_buffer;
m_cb.buffer_size = m_cb.secondary_buffer_size;
m_cb.p_secondary_buffer = NULL;
if (!m_cb.low_power_mode)
nrf_saadc_task_trigger(NRF_SAADC_TASK_START);
NRF_LOG_INFO(" SAADC in SAADC_IRQHandler : Inside !m_cb.low_power_mode || m_cb.conversions_end. : Inside low power.\r\n");
m_cb.event_handler(&evt);
m_cb.conversions_end = false;
if (m_cb.low_power_mode && nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED))
NRF_LOG_INFO(" SAADC in SAADC_IRQHandler : Inside m_cb.low_power_mode && nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED)\r\n");
nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED);
NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STARTED));
if (m_cb.buffer_size_left == 0)
// Sampling finished, next buffer in progress.
m_cb.buffer_size_left = m_cb.buffer_size - m_cb.active_channels;
nrf_saadc_buffer_init((nrf_saadc_value_t *)&m_cb.p_buffer[m_cb.buffer_size -
m_cb.buffer_size_left],
m_cb.active_channels);
else if (m_cb.buffer_size_left > m_cb.active_channels)
// More samples to convert than for single event.
m_cb.buffer_size_left -= m_cb.active_channels;
else if ((m_cb.buffer_size_left == m_cb.active_channels) &&
(m_cb.p_secondary_buffer != NULL))
// Samples to convert for one event, prepare next buffer.
m_cb.conversions_end = true;
m_cb.buffer_size_left = 0;
nrf_saadc_buffer_init((nrf_saadc_value_t *)m_cb.p_secondary_buffer,
else if (m_cb.buffer_size_left == m_cb.active_channels)
// Samples to convert for one event, but no second buffer.
nrf_saadc_task_trigger(NRF_SAADC_TASK_SAMPLE);
if (nrf_saadc_event_check(NRF_SAADC_EVENT_CALIBRATEDONE))
nrf_saadc_event_clear(NRF_SAADC_EVENT_CALIBRATEDONE);
NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_CALIBRATEDONE));
evt.type = NRF_DRV_SAADC_EVT_CALIBRATEDONE;
if (nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED))
nrf_saadc_event_clear(NRF_SAADC_EVENT_STOPPED);
NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STOPPED));
uint32_t limit_flags = m_cb.limits_enabled_flags;
uint32_t flag_idx;
nrf_saadc_event_t event;
while (limit_flags)
flag_idx = __CLZ(limit_flags);
limit_flags &= ~((1UL << 31) >> flag_idx);
event = FLAG_IDX_TO_EVENT(flag_idx);
if (nrf_saadc_event_check(event))
nrf_saadc_event_clear(event);
evt.type = NRF_DRV_SAADC_EVT_LIMIT;
evt.data.limit.channel = LIMIT_EVENT_TO_CHANNEL(event);
evt.data.limit.limit_type = LIMIT_EVENT_TO_LIMIT_TYPE(event);
NRF_LOG_DEBUG("Event limit, channel: %d, limit type: %s.\r\n", evt.data.limit.channel, (uint32_t)EVT_TO_STR(evt.data.limit.limit_type));
It is Entering into the above function.From this it is not calling the below function.(Where as when SAADC LP mode disabled ,it is calling the below Function.)
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
NRF_LOG_INFO("Entered into SAADC event Handler.\r\n");
NRF_LOG_INFO("Entered into SAADC event Done.\r\n");
nrf_saadc_value_t adc_result;
uint16_t batt_lvl_in_milli_volts;
uint8_t percentage_batt_lvl;
uint32_t err_code;
adc_result = p_event->data.done.p_buffer[0];
NRF_LOG_INFO("Loaded Buffer into adc result.\r\n");
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
NRF_LOG_INFO("Coverting data Buffer as Read.\r\n");
NRF_LOG_INFO("The adc Value : %d. \r\n",adc_result);
batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
DIODE_FWD_VOLT_DROP_MILLIVOLTS;
percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl);
if (
(err_code != NRF_SUCCESS)
(err_code != NRF_ERROR_INVALID_STATE)
(err_code != BLE_ERROR_NO_TX_PACKETS)
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
Please, Help out if any one aware of it.
