Hello.
I use nRF52 & mpu9250. I want to use dmp. But now it's not going well.
Now, there is no error,but fifo_count doesn't change after fifo_count became 512. I think fifo_count should reset after finished reading fifo data. DMP is enable. It checks code of reading fifo_stream.
I think the cause is method of loading from fifo register.
I test code below,but it's not going well.
static uint32_t mpu9250_read_fifo_register(uint8_t address, uint8_t reg, uint32_t length, uint8_t * p_data)
uint32_t err_code;
err_code = nrf_drv_twi_tx(&m_twi_instance, address, ®, 1, false);
if(err_code != NRF_SUCCESS) {
printf("err_code = %d @read_register_#1\n\r",err_code);
return err_code;
if(!waitInt(MPU9250_TWI_TIMEOUT)){// for Check timeout
printf("Timeout read_reg #1\r\n");
return NRF_ERROR_TIMEOUT;
twi_done = false;
for(unsigned char iii = 0; iii < length; iii++){
uint8_t * p_tmp;
err_code = nrf_drv_twi_rx(&m_twi_instance, address, p_tmp, 1);
printf("err_code = %d @read_register_#2\n\r",err_code);
return err_code;
printf("Timeout read_reg #2\r\n");
p_data[iii] = p_tmp[0];
twi_done = false;
return err_code;
unsigned short fifo_count;
int mpu_read_fifo_stream(unsigned short length, unsigned char *data,
unsigned char *more)
unsigned char tmp[2];
//printf("mpu_read_fifo_stream st@rt\r\n");
if (!st->chip_cfg.dmp_on){
printf("mpu_read_fifo_stream return -1\r\n");
return -1;
if (!st->chip_cfg.sensors){
printf("mpu_read_fifo_stream return -2\r\n");
return -2;
unsigned char tmp1[1];
unsigned char tmp2[1];
if (i2c_read(st->hw->addr, st->reg->fifo_count_h, 1, tmp1)){
printf("mpu_read_fifo_stream return -3\r\n");
return -3;
if (i2c_read(st->hw->addr, (st->reg->fifo_count_h)+1, 1, tmp2)){
return -3;
fifo_count = (tmp1[0] << 8)| tmp2[0];
printf("temp %x | %x temp - > fifoCount = %d , length = %d\r\n",tmp1[0],tmp2[0],fifo_count,length);
if (fifo_count < length) {
more[0] = 0;
printf("return 1\r\n");
return 1;
//fifo count > 512
if (fifo_count > (st->hw->max_fifo >> 1)) {
/* FIFO is 50% full, better check overflow bit. */
if (i2c_read(st->hw->addr, st->reg->int_status, 1, tmp)){
printf("return -5\r\n");
return -5;
if (tmp[0] & BIT_FIFO_OVERFLOW) {
mpu_reset_fifo();
printf("return 2\r\n");
return 2;
// fifo_count > 512
if (i2c_read_fifo(st->hw->addr, st->reg->fifo_r_w, length, data)){
printf("return -7\r\n");
return -7;
for(unsigned char iii = 0;iii<length;iii++){
printf("%d:%d\r\n",iii,data[iii]);
delay_ms(10);
more[0] = fifo_count / length - 1;
printf("more = %d\r\n",more[0]);
delay_ms(10);
return 0;
Please tell me how to read data from fifo register?
added 2017/06/01
