So I switched from Bluemod+S (nRF51822) to Bluemod+S42 (nRF52832) on my custom board and am trying to adapt my existing code to work on the newer model. Apart from various obvious and some not so obvious changes I managed to figure out myself, I'm now stuck on the initialization of the SPI:
void hal_spi_init()
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = NRF_DRV_SPI_PIN_NOT_USED; //slave select is handled seperatly
spi_config.miso_pin = SPI_MISO_PIN; //defined in custom_board.h
spi_config.mosi_pin = SPI_MOSI_PIN; //defined in custom_board.h
spi_config.sck_pin = SPI_SCK_PIN; //defined in custom_board.h
uint32_t err_code = nrf_drv_spi_init(&spi, &spi_config, NULL);
APP_ERROR_CHECK(err_code); //without setting an event handler, the transfer function just waits until the transmission is finished
which works without any error.
Subsequently I'm trying to send data to the slave, but the nrf_drv_spi_transfer
function loops indefinitely at while (!nrf_spi_event_check(p_spi, NRF_SPI_EVENT_READY)) {}
in spi_xfer
It did (still does) work on my old setup with the nRF51822 and I don't understand whats different now.
I already found similar questions here and here but those didn't help me.
I'm using S132 & SDK 12.3.0 (S130 & SDK 12.3.0 on the old setup)
