Im using sdk 14.0 and s132 When i add flashwrite codes to my project which has bluetooth communication ,it does not work I wanna send data to flash and i wanna read/write it What is the simplest way to do this
Im using NRF52832.
Thank you
Im using NRF52832.
Thank you
I would use fds.c (short for Flash Data Storage). You can a relative simple use in components/libraries/eddystone/es_flash.c
Other examples also use FDS.
Using flash is not trivial, and fds.c (in cooperation with fstorage.c) will hide away all the nasty stuff required to do it correctly.
hi,thanks your answer,but I cant find fds example in examples/peripheral/flash_fds.@@"
Updated my answer to include something which actually exists :)
Hi, you can use Fstorage with the SoftDevice backend for simple read, write and erase operations. Here is a simple example that I wrote. Make sure you have the correct include files. You can change the start_addr and end_addr to any free space you have on your chip. I believe this code should work. This just erases a page and then writes some data in that page. You can read the data using nrf_fstorage_read(....). You can also verify that the data is written by using nrfjprog.
static void fs_event_handler(nrf_fstorage_evt_t * evt){
if (evt->result != NRF_SUCCESS){
NRF_LOG_ERROR("Flash error");
} else {
NRF_LOG_INFO("Flash event success");
NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs) =
.evt_handler = fs_event_handler,
.start_addr = 0x0007F000,
.end_addr = 0x000FF000,
int main(void){
uint32_t err_code;
static uint32_t number = 123;
static uint32_t pages_to_erase = 1;
err_code = nrf_fstorage_init(&m_fs, &nrf_fstorage_sd, NULL);
ret_code_t rc = nrf_fstorage_erase(
&m_fs, /* The instance to use. */
m_fs.start_addr, /* The address of the flash pages to erase. */
pages_to_erase, /* The number of pages to erase. */
NULL); /* Optional parameter, backend-dependent. */
if (rc == NRF_SUCCESS)
/* The operation was accepted.
Upon completion, the NRF_FSTORAGE_ERASE_RESULT event
is sent to the callback function registered by the instance. */
NRF_LOG_INFO("ERASE SUCCESSFUL");
NRF_LOG_INFO("ERASE UNSUCCESFUL ");
/* Handle error.*/
rc = nrf_fstorage_write(&m_fs, m_fs.start_addr, &number, 4, NULL); //Write data to memory address. Check it with command: nrfjprog --memrd addr --n 32
NRF_LOG_INFO("WRITE SUCCESSFUL");
NRF_LOG_INFO("WRITE UNSUCCESFUL ");
/* Handle error.*/
Note that garbage collection and other mundane tasks will have to be handled in a live system. FDS makes this a lot simpler for the developer compared to using fstorage directly :)
