Measuring elapsed microseconds between 12 successive rising edges on 12 GPIOS on NRF52832 DK
Hi everyone,
I'm new with nrf52832, and I need to measure elapsed time in microsecond between rising edges of 12 different Gpios. I have 12 piezoelectric sensors filtered, amplified, getting a 0V-3.3V Logic level in input. Once one of these senors rises up, I need to start counting microseconds and store corresponding elapsed microsecond until I have 11 different values (assuming the first sensor's timing is 0). And then posting it over ble.
I red some documentations, and I heard about Timeslot API, timers and sys_tick, but I don't know which one would be better for my application.
Would you have any idea about how should I take this ?
Thanks for your help, and have a good day !
    Have you considered using PPI? It is possible to have the Logic level input start a timer and a counter automatically. I'm not sure if I understand your use case, but it is e.g. possible to start a timer on the first Logic level event, then use a counter to count 11 logic level events, and finally stop the timer on the 11th event. All this can be done autonomously without using the CPU, Timeslot API, or sys ticks. The CPU can even be sleeping while you time your events. On the 11th event you can chose to trigger an interrupt to process your timer value. I wrote a little bit more about PPI at the bottom of this thread.
  • Below is my implementation of a microsecond timer. This is old code (SDK 10 for NRF51), so it will not run right away, but should point you in the right direction.
    #include "nrf.h"
    #include "nrf_drv_timer.h"
    #include "bsp.h"
    #include "debug.h"
    #include "timer.h"
    uint64_t timer_micros = 0;
    uint32_t timer_ticks; // set in timer_init()
    uint32_t timer_interval = 1000000; // us
    uint64_t timer_last = 0;
    // COMPARE0 is used for overflow
    // COMPARE3 is used for reading the timer
    int pin_state = 0;
    void timer_event_handler(nrf_timer_event_t event_type, void* p_context)
    	if ( event_type != NRF_TIMER_EVENT_COMPARE0 )
    		return;
    	if ( pin_state == 0 ) {
    		pin_state = 1;
    		nrf_gpio_pin_set(PIN_TIMER);
    	} else {
    		pin_state = 0;
    		nrf_gpio_pin_clear(PIN_TIMER);
    	timer_micros = timer_micros + timer_ticks;
    	if ( timer_micros >= timer_last + timer_interval ) {
    		timer_last = timer_micros;
    		timer_callback();
    // Run on TIMER1
    // Timer must be enabled in nrf_drv_config.h
    const nrf_drv_timer_t timer = NRF_DRV_TIMER_INSTANCE(1);
    nrf_drv_timer_config_t timer_config;
    uint64_t timer_read(void)
    	uint32_t ticks = nrf_drv_timer_capture(&timer, NRF_TIMER_CC_CHANNEL3);
    	uint64_t ret = timer_micros + ticks;
    	return ret;
    void timer_init(void)
    	// TIMER0 is 32-bit, TIMER1 & 2 are 16-bit
    	timer_config.bit_width = NRF_TIMER_BIT_WIDTH_16;
    	timer_config.frequency = NRF_TIMER_FREQ_1MHz;
    	timer_config.interrupt_priority = 1; // 0 = highest, 3 = lowest
    	timer_config.mode = NRF_TIMER_MODE_TIMER;
    	uint32_t err_code = NRF_SUCCESS;
    	err_code = nrf_drv_timer_init(&timer, &timer_config, timer_event_handler);
    	if ( err_code != NRF_SUCCESS )
    		_ERROR("nrf_drv_timer_init() failed");
    	uint32_t time_ms = 50;
    	timer_ticks = nrf_drv_timer_ms_to_ticks(&timer, time_ms);
    	if ( timer_ticks > 65535 )
    		_ERROR("Timer frequency too high");
    	_DEBUG ("Timer: interrupt every %d ms, %d ticks per interrupt\n", time_ms, timer_ticks);
    	nrf_drv_timer_extended_compare(
    		 &timer, NRF_TIMER_CC_CHANNEL0, timer_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    	nrf_drv_timer_enable(&timer);
  • Hi
    Thanks for your answer ! I looked at PPI but it seems like there is only 6 configurable groups. It takes me a bit of time to understand all of the concept of this but can I attach 12 inputs to PPI ? I'm working on it ! Thanks for your help :)
  • Thank you for your help, I'm trying to implement it on my code :) Have a good day !
  • Happy to help. Apparently I didn't read your question thoroughly enough. I thought we talked about one GPIO and 12 incoming pulses, not 12 different GPIOs. Although you have 16 PPI channels, you only have 6 GPIOTE channels available (which I think is what you are referring to?). So now I don't see any obvious workarounds with PPI in your case. I don't know the details of you use case, but maybe it would be possible to:
    1. Configure the GPIOTE channels to measure a certain set of 6 pins
    2. Do 6 measurements
    3. Fire an interrupt routine and reconfigure the GPIOTE channels to use the 6 other pins.
