nRF52832 watchdog issue
Hi
I'm trying to implement the watchdog to my project, but I'm having some odd issues. When I power cycle the device the watchdog works fine, but when I program the device through keils Load button (system reset) the device just goes into a limbo state from which it can't recover anymore until I power cycle it, then it works fine again. I've found a similar issue in another post:
https://devzone.nordicsemi.com/question/4575/problem-with-system_reset-and-watchdog/
That post is about the nRF51, but I have the nRF52.
I found two different examples that use the wdt, one is this one:
https://github.com/NordicPlayground/nrf51-watchdog-resetreas-example/blob/master/watchdog_simple/main.c
And the other one is in keils example library that uses the nrf_drv_wdt library.
Both have the same issue.
Edit: The RESETREAS workaround has also issues sometimes.
