1
IoT SDK 1.0.0 - DFU with IoT File - PStorage?
tb_in_sd gravatar image
asked 2017-11-17 16:36:31 +0100
updated 2017-11-17 16:37:31 +0100
Hello Dev Zone,
We've been using the IoT SDK 0.9 all year and recently ported to the production release bundled with the SDK 14.1 package.
We have the DFU working with the SDK 0.9, which is based on top of the IoT File module.
The SDK documentation is referencing the using of the PStorage module, for example in these docs:
  • API Reference / IoT Components / IoT DFU / Application IoT DFU <br>
  • Libraries / IoT Libraries / Experimental IoT Libraries / IoT File<br><p>
And in examples: /components/iot/iot_dfu/app/iot_dfu.c, it's looking for "iot_file_pstorage_raw.h"
I do see the new dfu_background module, but we already have a transport mechanism/protocol in in our architecture.
What is the recommended migration path for us? PStorage looks to have migrated to FDS but the IoT DFU libraries look to still use PStorage.
Thanks!
edit retag flag offensive close delete report spam
1 answer
Sort by ยป oldest newest most voted
1
answered 2017-11-20 20:53:34 +0100
I worked through support portal and got a timely response from Nordic like usual so I'll update here ;)
As expected, PStorage is not supported. The IoT SDK documents have some errors and will be updated, but basically you can't use the IoT DFU functionality that uses PStorage which was used in the IoT SDK 0.9.
Recommended path forward is the "IoT File Static port" using the "Background DFU", which I'll proceed with!
Thanks
edit flag offensive delete publish link more
Comments
Thanks for adding an answer here :)
Petter Myhre ( 2017-11-21 10:54:49 +0100 )editconvert to answer
Your Answer
Please start posting anonymously - your entry will be published after you log in or create a new account.
Add Answer. Do not ask a new question or reply to an answer here.
[hide preview]
User menu
    or sign up
Recent questions
Question Tools
1 follower
Stats
Asked: 2017-11-17 16:36:31 +0100
Seen: 45 times
Last updated: nov. 20
