Hi In our Nordic SDK ble_peripheral projects , It almost support following boards
1. pca10028
2. pca10036
3. pca10040 .
I want to port in pca20006
May I know the way ?
1. pca10028
2. pca10036
3. pca10040 .
Use the pca10028 project.
If you are using Keil, then under "Options for target" -> "C/C++" tab, under "Preprocessor Symbols" remove the define BOARD_PCA10028, and add the define BOARD_PCA20006.
If you are using GCC, you need to modify the makefile. Change ASMFLAGS += -DBOARD_PCA10028 to ASMFLAGS += -DBOARD_PCA20006
You also might need to adjust the FLASH/RAM settings, depending on what version of the PCA20006 you have.
hi , I changed both setting
1. Modify the Makefile ASMFLAGS += -DBOARD_PCA10028 to ASMFLAGS += -DBOARD_PCA20006
2. I am using nrf51822 QFAAH00(0x0072) becoan board, version 3 , Flash is 256KB
RAM is 16KB. So I changed beacon_gcc_nrf51.ld below values
MEMORY
{ FLASH (rx) : ORIGIN = 0x1b000, LENGTH = 0x25000 RAM (rwx) : ORIGIN = 0x20001870, LENGTH = 0x2790 }
Still I am not able to port the application in my board PCA20006.
can you guide me ?
Make sure that you have flashed the SoftDevice.
Also make sure that you have changed from external LF crystal to internal RC oscillator. See this post: devzone.nordicsemi.com/.../
If its still not working, try debugging. See this post: devzone.nordicsemi.com/.../
