The problem
I am trying to build the examples contained in Bluetooth Mesh stack, but I get the following error when running cmake
-- Found assembler: /usr/local/bin/arm-none-eabi-gcc
-- Check for working C compiler: /usr/local/bin/arm-none-eabi-gcc
-- Check for working C compiler: /usr/local/bin/arm-none-eabi-gcc -- broken
CMake Error at /Applications/CMake.app/Contents/share/cmake-3.10/Modules/CMakeTestCCompiler.cmake:52 (message):
The C compiler
"/usr/local/bin/arm-none-eabi-gcc"
is not able to compile a simple test program.
##What I do Here are the steps I take to try to build the examples:
- I download the Mesh SDK from www.nordicsemi.com/.../nRF5-SDK-for-Mesh
- I unzip the file
- Using the terminal:
cd nrf5_SDK_for_Mesh_v1.0.0_src; mkdir build; cd build;
, and cmake -DPLATFORM=nrf52832_xxAA -DTOOLCHAIN=gccarmemb -DSOFTDEVICE=s132_5.0.0 ..
##More information about my setup
- macOS High Sierra 10.13.2
- nrf5_SDK_for_Mesh_v1.0.0_src
- CMake version 3.10.1
- gcc-arm-none-eabi-7-2017-q4-major (NOTE:
is a symbolic link to{somewhere on my system}/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-gcc
