STATIC_ASSERT and GCC (instead of Keil)
I'm bringing up ble_app_hrs as an eclipse project using gcc.
I'm running into an error in app_util.h, line 67:
#define STATIC_ASSERT(EXPR) typedef char static_assert_failed[(EXPR) ? 1 : -1]
The error is:
typedef 'static_assert_failed' locally defined but not used [-Werror=unused-local-typedefs] ble_app_hrs line 67, external location: ..../nrf51822/Include/app_common/app_util.h C/C++ Problem
I believe the instance of STATIC_ASSERT it's complaining about is in app_timer.c, line 1035:
STATIC_ASSERT(APP_TIMER_INT_LEVELS == 3);
QUESTION: what's up with this? Is there some kind of support I need to add so this mechanism will work correctly?
