I would like to start a pwm signal on PIN 15 while BUTTON_1 or BUTTON_2 is pressed. If BUTTON_1 or BUTTON_2 is released, than there should be no signal(low) on PIN 15.
Setup is:
-SoftDevice 8.0
-SDK 8.1
-nRF51DK
There is a related post to this topic: devzone.nordicsemi.com/.../
The problem is, if I comment out app_pwm_enable(&PWM1); in the PWMinit function then I cannot connect to the board and the buttons are also not working.
If I enable the pwm in the PWMinit function, then the pwm will start immediately. But the pwm should only start when BUTTON_1 or BUTTON_2 are pressed.
static void PWMinit(void)
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(9000L, 15);
pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
void pwm_stop(void)
app_pwm_disable(&PWM1);
nrf_drv_gpiote_out_task_disable(15);
nrf_gpio_pin_clear(15);
void pwm_start(void)
nrf_drv_gpiote_out_task_enable(15);
while (app_pwm_channel_duty_set(&PWM1, 0, 50) == NRF_ERROR_BUSY);
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
if(button_action == APP_BUTTON_PUSH)
switch (pin_no)
case Switch_up:
pwm_start();
nrf_gpio_pin_set(23);
case Switch_down:
pwm_start();
nrf_gpio_pin_set(24);
else if (button_action == APP_BUTTON_RELEASE)
switch (pin_no)
case Switch_up:
pwm_stop();
nrf_gpio_pin_clear(23);
case Switch_down:
pwm_stop();
nrf_gpio_pin_clear(24);
