UART
is there any Example to use the UART ? I need an monitor while the application is running, is the UART COM Port the right one for this?
Is there an example with the app_uart?
Best regards Nils
  • I need also help to send printf outputs via UART to a serial terminal.
    I am also working on Eclipse + GCC environment and using Evaluation Kit and my BLE application uses S110_SoftDevice.
    questions are:
    • Which uart- support files from Nordic S. SDK are to add to the build?
    • How to connect (printf -- putc)?
    • Which way make more sense? Using either USB (COMx) or other GPIOs as UART output?
    Yalcin
  • Hi Nils, I am sorry, from your earlier mails I had the impression, you are using Eclipse.
    Yalcin
    Yalcin
  • I started with eclipse and gcc, but didn't get it to work fine. Now i am working with Keil, normaly it works fine.
    But i need an monitor on the pc to talk with the device in the runtime, like you need it, right?
    nils
    there are a few UART examples in the SDK, depending on which hardware you are using (Evaluation Kit or Development Kit). If you are using the PCA10001 Evaluation board, take a look at nrf51822\Board\pca10001\uart_example. This example uses the com port interface, which is conveniently accessed via the USB. Albeit this example is quite simple..
    As far as I know, app_uart is part of the HCI transport layer, which is used in the connectivity chip examples. This transport layer is quite complex and not something you would use as a monitoring tool for debugging.
