Can't restore Bonding
I have a problem at restoring the bonding that is saved on Android EEPROM. I'm using Nordic 8001
I'm using the example from proximity. I modified the services.h using NRFGO to support ANCS and i added 2 characteristic for talking with the iOS phone. At some point everything worked fine, but now i have a big problem at restoring the Bond. The restore bonding functions are the functions from proximity template, so i don't thing there is a problem at the code. I think there is a problem at the NRGO settings. What can cause problem at bonding process?
I attached the setup.xml file for NRFGO.
Thank you!
proximity_setup.xml
  • Have you based your code on the latest version of the ble-sdk-arduino ? Can you also enable debug printing using the option in the lib_aci_init() and post your trace in this thread ?
    You could also look at these pages to see if they help
    http://i.got.nothing.to/code/on/avr-for-ble-and-ios/ https://github.com/guyzmo/avr_nrf_ancs_library
  • First run, when i do bonding:
    Arduino setup C1 :1, E, E3 :3, 84, E, 0, E4 :4, 81, 3, 0, 2, Evt Device Started: Standby C5 :5, 10, B4, 0, 50, 0, No Bond present in EEPROM. Advertising started : Waiting to be connected and bonded E3 :3, 84, 10, 0, E15 :F, 85, 3, 4B, 7E, D8, 5C, F8, 51, 18, 0, 0, 0, 48, 0, 5, Evt Connected [...bla, bla, bla...] Evt link connection interval changed C2 :2, 11, 1, DISCONNECT!!!! E3 :3, 84, 11, 0, E3 :3, 86, 3, 16, Evt Disconnected. Link Lost or Advertising timed out C1 :1, 7, E30 :1E, 84, 7, 1, 1, 4, 2, 3, 0, 8, A, 0, B, 1, 0, 0, E, 1, 64, 0, F, 2, 1, 0, 0, 12, 9, 0, 0, 2, 3, C1 :1, 7, E30 :1E, 84, 7, 1, 2, 1, 0, 0, 0, 0, 0, 16, 14, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, C1 :1, 7, E29 :1D, 84, 7, 1, 3, 0, 0, 0, 18, 14, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, C1 :1, 7, E30 :1E, 84, 7, 1, 4, 0, 19, 2, 1, 0, 0, 1B, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1C, 2, 1, 0, 0, 1E, 6, FF, C1 :1, 7, E29 :1D, 84, 7, 1, 5, FF, FF, FF, FF, FF, C, 4, 7, 0, F, 0, 10, 1, 8, 0, 12, 0, 13, 1, 9, 0, C, 0, D, 1, C1 :1, 7, E30 :1E, 84, 7, 1, 6, A, 0, 8, 0, 9, 1, 10, 5A, CB, A0, 79, 83, 6E, D8, 1, 1, 4B, 7E, D8, 5C, F8, 51, B7, 78, CA, 33, C1 :1, 7, E30 :1E, 84, 7, 1, 7, 10, 36, 11, 1C, FB, 2A, 84, 9E, 87, 5, 1C, EE, 18, 62, 9B, B1, F6, 0, 82, 4E, 5E, 95, 96, D8, 5B, 13, C1 :1, 7, E30 :1E, 84, 7, 1, 8, DD, CC, 82, 33, 3B, 8B, A, 34, 69, 6, D9, D5, 3B, 1E, 0, 0, 0, 0, 0, 0, 0, 0, FE, 2F, 0, 0, C1 :1, 7, E28 :1C, 84, 7, 2, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 14, 2, 91, 59, Dynamic Data read and stored successfully
    Second run, when i should restore the bond from eeprom:
    Arduino setup C1 :1, E, E3 :3, 84, E, 0, E4 :4, 81, 3, 0, 2, Evt Device Started: Standby Previous Bond present. Restoring Using existing bond stored in EEPROM. To delete the bond stored in EEPROM, connect Pin 6 to 3.3v and Reset. Make sure that the bond on the phone/PC is deleted as well. C28 :1C, 8, 1, 4, 2, 3, 0, 8, A, 0, B, 1, 0, 0, E, 1, 64, 0, F, 2, 1, 0, 0, 12, 9, 0, 0, 2, 3, E3 :3, 84, 8, 1, C28 :1C, 8, 2, 1, 0, 0, 0, 0, 0, 16, 14, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, E3 :3, 84, 8, 1, C27 :1B, 8, 3, 0, 0, 0, 18, 14, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, E3 :3, 84, 8, 1, C28 :1C, 8, 4, 0, 19, 2, 1, 0, 0, 1B, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1C, 2, 1, 0, 0, 1E, 6, FF, E3 :3, 84, 8, 1, C27 :1B, 8, 5, FF, FF, FF, FF, FF, C, 4, 7, 0, F, 0, 10, 1, 8, 0, 12, 0, 13, 1, 9, 0, C, 0, D, 1, E3 :3, 84, 8, 1, C28 :1C, 8, 6, A, 0, 8, 0, 9, 1, 10, 5A, CB, A0, 79, 83, 6E, D8, 1, 1, 4B, 7E, D8, 5C, F8, 51, B7, 78, CA, 33, E3 :3, 84, 8, 1, C28 :1C, 8, 7, 10, 36, 11, 1C, FB, 2A, 84, 9E, 87, 5, 1C, EE, 18, 62, 9B, B1, F6, 0, 82, 4E, 5E, 95, 96, D8, 5B, 13, E3 :3, 84, 8, 1, C28 :1C, 8, 8, DD, CC, 82, 33, 3B, 8B, A, 34, 69, 6, D9, D5, 3B, 1E, 0, 0, 0, 0, 0, 0, 0, 0, FE, 2F, 0, 0, E3 :3, 84, 8, 1, C26 :1A, 8, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 14, 2, 89, 1C, E3 :3, 84, 8, 88, Bond restore failed. Delete the bond and try again. C5 :5, 10, B4, 0, 50, 0, No Bond present in EEPROM. Advertising started : Waiting to be connected and bonded E3 :3, 84, 10, 0, E15 :F, 85, 3, 4B, 7E, D8, 5C, F8, 51, 18, 0, 0, 0, 48, 0, 5, Evt Connected C5 :5, 10, B4, 0, 50, 0, C1 :1, 9, E17 :11, 88, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Evt Pipe Status Service Discovery is still going on. E3 :3, 84, 10, 83, ACI Command 10 Evt Cmd respone: Status 83 E12 :C, 84, 9, 0, 0, 0, 2, 3, 1, 0, 0, 0, 0, C11 :B, D, 4, 0, 0, 2, 3, 1, 0, 0, 0, 0, E3 :3, 84, D, 0, E7 :7, 87, 1, 2, 1, 0, 0, 0, 1 E3 :3, 86, 3, 24, Evt Disconnected. Link Lost or Advertising timed out
    I know these links. I studied them all. The version i am using is the version that was on git like 1 week ago.
  • If you look in proximity example, in the "bond_data_restore" function, my code ends here:
    if (0 >= write_dyn_num_msgs) { //should have returned earlier return ACI_STATUS_ERROR_INTERNAL; }
    I don't receive ACI_STATUS_TRANSACTION_COMPLETE. I really don't understand why because the same code used to work yesterday. :(
  • Looks like the Write Dynamic data failed with a CRC mismatch
    E3 :3, 84, 8, 88,
    Event : Length = 3 bytes (in decimal) Length = 0x03 (Hex) Event opcode = 0x84 (Hex) Command code for which this event is associated with = 0x08 (Write Dynamic Data) Status code = 0x88 = ACI Status Error CRC Mis match (See appendix in nRF8001 PS v1.2)
    = I can also see that the last message used in the Read Dynamic data is different from the last message in Write Dynamic Data
    Read Dynamic Data
    Write Dynamic Data
    As you can clearly see the last 2 bytes alone are different and this, I suspect , is the reason for the CRC failure.
  • Thank you! I changed some settings in NRFGo and now it works...
