I am using a 128KB-rom 16KB-ram nrf51822 and trying to run blinky from SDK 11 with softdevice.
If I load nrf51 S130 1.0.0 softdevice, and use the following in my gcc compiling setting: FLASH (rx) : ORIGIN = 0x1c000, LENGTH = 0x4000 RAM (rwx) : ORIGIN = 0x20002800, LENGTH = 0x1800 I was able to run blinky.
After I change to S130 2.0.0 softdevice, and use the following: FLASH (rx) : ORIGIN = 0x1b000, LENGTH = 0x5000 RAM (rwx) : ORIGIN = 0x20002800, LENGTH = 0x1800 blinky does not work any more. I assume the RAM setting is wrong? what should be the correct setting?
Also what is the correct ROM/RAM setting for S130 2.0.0-7.alpha? I can't get blinky to work with this SD either.
Thanks for any help!
