I am programming the NRF51-DK on mbed compiler. I have compiled some code below for using an analog to digital converter. I was able to print a voltage measurement but I'm not sure if it is accurate. I am trying to use a 10 bit ADC and configure it so it reads the voltage at pin P01 (AnalogInput1), but I get a voltage reading around 2.89 even when there is no voltage supplied.
Thanks.
#include "mbed.h"
DigitalOut led_status(LED1);
Serial device (p9,p11); //(TX,RX)
void my_analogin_init(void)
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
NRF_ADC->CONFIG = (ADC_CONFIG_RES_10bit << ADC_CONFIG_RES_Pos) | //Configure Resolution to 10 bits
(ADC_CONFIG_INPSEL_SupplyOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) | //Configure ADC input selection and prescalar settings
//Internal reference voltage of 1.2V. Onethird prescaling -> 3.6V
(ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) | //ADC reference selection to internal 1.2V VBG
(ADC_CONFIG_PSEL_AnalogInput1 << ADC_CONFIG_PSEL_Pos) | //Select Pin to be used as ADC input pin -> Disable analog pins
(ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos); //Select external reference pin -> No external reference (we use internal reference of 1.2V)
uint16_t my_analogin_read_u16(void)
NRF_ADC->CONFIG &= ~ADC_CONFIG_PSEL_Msk; // Check if input pin has been selected
NRF_ADC->CONFIG |= ADC_CONFIG_PSEL_AnalogInput1 << ADC_CONFIG_PSEL_Pos; //
NRF_ADC->TASKS_START = 1;
while (((NRF_ADC->BUSY & ADC_BUSY_BUSY_Msk) >> ADC_BUSY_BUSY_Pos) == ADC_BUSY_BUSY_Busy) {} //
return (uint16_t) NRF_ADC->RESULT; //10bit result is returned to main function
float value;
device.baud(115200); //Set Baud rate
my_analogin_init(); //Initialize ADC settings
while(1) {
led_status = 0; // Led = off
wait(0.2); // wait 200 ms
led_status = 1; //led = on
wait(0.8); //wait 800ms
value = (float)my_analogin_read_u16(); //call function to read read voltage returns value from 0 to 1024
value = (value * 3.6) / 1024; // returns voltage from range of (0 to 3.6V)
device.printf("Input Voltage: %f\n\r",value); //Prints input voltage
