hello there , i have put my nrf51 dk in system off mode.then i am generating interrupt using button 3 to wake up it. but my nrf51dk can't wake up. can you hel p me??
my main function and interrupt handler function are as below
uint32_t err_code;
bool erase_bonds;
ret_code_t ret_code;
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
advertising_start();
conn_params_init();
ret_code = nrf_drv_gpiote_init();
nrf_drv_gpiote_out_config_t led_config = GPIOTE_CONFIG_OUT_TASK_LOW;
ret_code = nrf_drv_gpiote_out_init(LED_3, &led_config);
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
nrf_drv_gpiote_in_config_t config =
// .sense = NRF_GPIOTE_POLARITY_HITOLO,
.sense =NRF_GPIOTE_POLARITY_TOGGLE, //NRF_GPIOTE_POLARITY_LOTOHI,
.pull = NRF_GPIO_PIN_PULLUP , // NRF_GPIO_PIN_NOPULL
// .pull = NRF_GPIO_PIN_PULLUP ,
.is_watcher = false,
.hi_accuracy = false
ret_code = nrf_drv_gpiote_in_init(INTERRUPT_PIN, &config, gpiote_evt_handler);
nrf_drv_gpiote_in_event_enable(INTERRUPT_PIN,true);
nrf_gpio_cfg_sense_input(INTERRUPT_PIN, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
sd_power_system_off();
while(true)
void gpiote_evt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
switch(action)
case NRF_GPIOTE_POLARITY_TOGGLE:
if(nrf_drv_gpiote_in_is_set(INTERRUPT_PIN))
{ // sd_power_system_off();
// nrf_drv_gpiote_out_clear(LED_3);
nrf_drv_gpiote_out_set(LED_3);
//do nothing
