Hi, Everyone,
I am Using S130 and sdk 11.0.0.2-alpha with nRF51422 chip. I have two crystal in my custom pcb, one is 32 Khz crystal for LFCLK between XL1 and XL2 (pin 45,46 ) and other is 16Mhz HFCLK between XC1 and XC2(pin 37, 38)
Inside ble_stack_init()
I use either following only for 32Khz external osciilator initialization SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_250_PPM, NULL);
OR following only when using internal RC osc SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_16000MS_CALIBRATION, NULL);
when I switch LFCLK to internal RC then HFCLK gets updated to 0x10001 -which is external 16Mhz crystal. All perfect , no problem
But when I use 32 Khz external crystal as LFCLK, HFCLK stays to 0x10000 - which says internal RC instead of external oscillator
According to the specs, Radio should not work without external crystal HF clock source, But I can see Advertised data in Master control panel, with accurate information even when i use external 32 khz crystal for LFCLK and HFLCK stays to 0x10000
Can anybody make me clear here ???
