Greetings,
I've been trying to implement a cloud-based solution for Bluetooth Mesh. I've got two questions that I would like to receive some comments on and I would be...
I am evaluating the Thingy 53 + nRF7002 EB for Wifi and Bluetooth scanning.
But depending on which power source I plug the devkit, the wifi interface doesn't set...
We are evaluating a solution for our product where we would like to use
Zephyr RTOS with NCS
nRF52840 + nRF7002 for a combined WiFi/BLE solution. nRF52 will...
I need to run a time-sensitive application on the NRF52840 platform, hence I require disabling and re-enabling the softdevice. After successfully disabling and re-enabling...
Hello!
Do you have a link to a ready-made RF cable which can connect the nrf5340 audio dk SWF output to the nrf21540 EK TRX input?
Henrik
I just started working with ZBus and even though Zephyr's documentation states that " Publishing, reading, claiming, and finishing are available in all RTOS thread contexts...
A current project of ours includes a nRF9151 and I stumbled across a contradiction in the datasheet (nRF9151 Objective Product Spec v0.7).
In Table 55, pins 112 and...
I'm testing the IQ feature of the radio test. According to the documentation on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/wifi/radio_test...
Greetings,
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
I am developing a custom nrf5340 board design, that is using the BL5340PA external antenna module to implement the nrf5340 chip in the design. The BL5340 module allows all...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
CIS mode using the nRF5340 Audio application We are considering implementing a bidirectional stream.
Edit prj_release.conf as below and build/write I did it using a script...
example:ble_app_uart + secure_bootloader sdk:17.1 hello. Well, a strange phenomenon occurred when I was testing the connection between our ble device and the app。 Our app...
We are working with nRF5340 with SDK v2.5.2.
Each time we try to program the board, we get below error.
We do not see this error if we try Erase and Flash option...
We have a product in production that we need to update to a newer version of NCS. We currently use the mpsl_radio_notification_cfg_set() interface to drive some custom HW...
hi
I am configuring a product using nRF52832 and NUS.
This time, I'm trying to view BLE wireless data (raw) from central and peripheral, but I can't find a way to do...
Hello, Modem firmware is 1.3.5 and SDK version is 2.5.0. I am using Nrf9160 DK to evaluate a cellular network to control, for example, LED remotely.
At the moment I am trying...
Hi Nordic,
In my project, I have a NRF9160 and a NRF52832 with a ble host/controller stack over SPI HCI on NCS v2.5.2 As soon as I activate the HCI SPI in my project, the...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
