buttonless DFU Start upgrade
Hi.
Softdevice 6.0.0
SDK 15.0.0
IDE IAR 7.80.4
Chip NRF52832
I buid progect buttonless DFU in IAR.
I added peer_id.c, peer_data_storage.c, peer_database.c, peer_manager.c, pm_buffer.c, pm_mutex.c, security_dispatcher.c, security_manager.c, gatt_cache_manager.c, gatts_cache_manager.c,id_manager.c include in sdk_config.h CRC16_EABLE, FDS_ENABLE, NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS, NRF_SDH_BLE_SERVICE_CHANGED and BLE_DFU_ENABLED and added BL_SETTINGS_ACCESS_ONLY, NRF_DFU_SVCI_ENABLED
NRF_DFU_TRANSPORT_BLE=1
I changed the function "services_init(void)" of project ble_app_uart in:
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    nrf_ble_qwr_init_t qwr_init = {0};
    ble_dfu_buttonless_init_t dfus_init = {0};
    // Initialize Queued Write Module.
    err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init);
    // Initialize NUS.
    //***** buttonless DFU *****
    // Initialize the async SVCI interface to bootloader.
    err_code = ble_dfu_buttonless_async_svci_init();
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
and add peer_manager_init
    bool erase_bonds;
  //  static uint32_t pages_to_erase = 1;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    peer_manager_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start(erase_bonds);
I changed NRF_SDH_BLE_VS_UUID_COUNT with 1 in 2.
I modify RAM start and RAM STOP in IAR.
How do start work DFU? I use function ble_dfu_buttonless_bootloader_start_finalize(); but she not started DFU.
Error on line nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU); in function
uint32_t ble_dfu_buttonless_bootloader_start_finalize(void)
    uint32_t err_code;
    NRF_LOG_DEBUG("In ble_dfu_buttonless_bootloader_start_finalize\r\n");
    err_code = sd_power_gpregret_clr(0, 0xffffffff);
    VERIFY_SUCCESS(err_code);
    err_code = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
    // Indicate that the Secure DFU bootloader will be entered
    m_dfu.evt_handler(BLE_DFU_EVT_BOOTLOADER_ENTER);
    // Signal that DFU mode is to be enter to the power management module
    return NRF_SUCCESS;
I don't know that do. Help me.
  • Hi.
    Take a look at the answer hungbui have given you in your other ticket, this explains the questions you have here.
    Andreas
  • I looked at the answer hungbui and built project but got error in function
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                // LED indication will be changed when advertising starts.
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
                // No system attributes have been stored.
                err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            default:
                // No implementation needed.
    In line
    Function sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL) return error 8.
  • Hi.
    You will be answered in this duplicate ticket by hungbui, I'm closing this one.
    Andreas
  • Hi.
    I'm sorry but hungbui not answer question.
    How long to wait?
  • Hi.
    Just continue to wait for answer in that ticket.
    Andreas
