button push and release events
to initialize  the button properly
to trigger the push event on button push and the release event on button release, do I just have to change the button active state, if not how can i control it !?
/**@brief Button configuration structure. */
typedef struct
uint8_t pin_no; /**< Pin to be used as a button. */
uint8_t active_state; /**< APP_BUTTON_ACTIVE_HIGH or APP_BUTTON_ACTIVE_LOW. */
#if defined(BUTTON_HIGH_ACCURACY_ENABLED) && (BUTTON_HIGH_ACCURACY_ENABLED == 1)
bool hi_accuracy; /**< True if GPIOTE high accuracy (IN_EVENT) is used. */
nrf_gpio_pin_pull_t pull_cfg; /**< Pull-up or -down configuration. */
app_button_handler_t button_handler; /**< Handler to be called when button is pushed. */
} app_button_cfg_t;
when the button push switch the analog input from 0 to 1 have to be initialized as follows :
#ifdef BSP_BUTTON_0
{BSP_BUTTON_0, true, BUTTON_PULL, bsp_button_event_handler},
#endif // BUTTON_0
and when the button push switch the analog input from 1 to 0 have to be initialized as follows :
#ifdef BSP_BUTTON_0
{BSP_BUTTON_0, false, BUTTON_PULL, bsp_button_event_handler},
#endif // BUTTON_0
    BSP depends on a module named app_button, and BSP does not send the PUSH and RELEASE event, but app_button does.
    I would recommend that you, instead of using BSP, implement app_button directly in your application. Here's an example:
    static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case MY_BUTTON:
                if (button_action == APP_BUTTON_PUSH)
                    /* Button pushed */
                    do_something();
                else
                    /* APP_BUTTON_RELEASE */
                    do_something_else();
            default:
    static void buttons_init(void)
       // The array must be static because a pointer to it will be saved in the button library.
        static app_button_cfg_t buttons[] =
            {MY_BUTTON, true, BUTTON_PULL, button_evt_handler},
        ret_code_t err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
        /* You can call this other places as well, for instance when you get BLE_GAP_EVT_CONNECTED */
        err_code = app_button_enable();
    Håkon
  • Hi Hakan,
    thanks for your reply.
    I will ask my question in other way
    when i configure my button as
    {MY_BUTTON, true, BUTTON_PULL, button_evt_handler},  ?
    and when I configure it as :
    {MY_BUTTON, false, BUTTON_PULL, button_evt_handler}, ?
  • What you are setting there is the sense of the button:
    #define APP_BUTTON_ACTIVE_HIGH 1                               /**< Indicates that a button is active high. */
    #define APP_BUTTON_ACTIVE_LOW  0                               /**< Indicates that a button is active low. */
    If your button is active low, set it to "false". If active high, set it to "true".
    To address your question: The app_button library will provide an event when button is pushed, and when it is released. No need to do anything else than what is provided underneath.
    Håkon
