nRF9160 DK problem registering to network
I have recently started an evaluation on nRF9160 DK in the UK.
I tried to run the Serial LTE or AT Client examples but I was not lucky to register to a network.
Using the NB IoT mode (since the UK has no LTE) I could see a tower (Vodafone) on the LTE Link Monitor and I could get the MNCMCC of the country.
But the kit never registered and it kept searching (LTE box blinking red and yellow).
I have used 3 different SIM cards. iBasis which came with the kit , Hologram Global SIM, and a Vodaphone Pay as you go.
All the 3 SIMs are activated and have credit.
Is there any one knows if there a coverage problem in the UK !
Is this normal ?
Kindly advice.
    From provided board examples, please use at_client sample application on your board and run the following AT commands:
    Turn off the modem AT+CFUN=0
    Provide more information about the modem with these AT commands
    AT+CGMR
    AT+CEREG=5
    AT+CMEE=1
    AT+CNEC=24
    AT%CESQ=1
    Turn on the modem AT+CFUN=1
    Run AT+CFUN?
    If these sequence does not work for you, please open, save and upload the log. Log file can be opened by clicking on Open Log File in LTE Link Monitor application.
    Dejan
  • 2021-12-30T16:33:28.989Z INFO Application data folder: C:\Users\MuhammadAbdulfattah\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2021-12-30T16:33:29.062Z DEBUG App pc-nrfconnect-linkmonitor v2.0.0 official
    2021-12-30T16:33:29.062Z DEBUG App path: C:\Users\MuhammadAbdulfattah\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2021-12-30T16:33:29.062Z DEBUG nRFConnect 3.9.1, required by the app is (^3.8.0)
    2021-12-30T16:33:29.062Z DEBUG nRFConnect path: C:\Users\MuhammadAbdulfattah\AppData\Local\Programs\nrfconnect\resources\app.asar
    2021-12-30T16:33:29.062Z DEBUG HomeDir: C:\Users\MuhammadAbdulfattah
    2021-12-30T16:33:29.062Z DEBUG TmpDir: C:\Users\MUHAMM~1\AppData\Local\Temp
    2021-12-30T16:33:33.203Z INFO Modem port is opened
    2021-12-30T16:33:33.214Z DEBUG modem >> AT+CFUN?
    2021-12-30T16:33:33.236Z DEBUG modem << +CFUN: 0
    2021-12-30T16:33:33.241Z DEBUG modem << OK
    2021-12-30T16:33:45.171Z DEBUG modem << *** Booting Zephyr OS build v2.6.99-ncs1  ***
    2021-12-30T16:33:45.186Z DEBUG modem << I: Starting bootloader
    2021-12-30T16:33:45.188Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2021-12-30T16:33:45.190Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2021-12-30T16:33:45.192Z DEBUG modem << I: Boot source: none
    2021-12-30T16:33:45.195Z DEBUG modem << I: Swap type: none
    2021-12-30T16:33:45.243Z DEBUG modem << I: Bootloader chainload address offset: 0x10000
    2021-12-30T16:33:45.247Z DEBUG modem << I: Jumping to the first image slot
    2021-12-30T16:33:45.467Z DEBUG modem << *** Booting Zephyr OS build v2.6.99-ncs1  ***
    2021-12-30T16:33:45.471Z DEBUG modem << Flash regionsDomainPermissions
    2021-12-30T16:33:45.474Z DEBUG modem << 00 03 0x00000 0x20000 Securerwxl
    2021-12-30T16:33:45.477Z DEBUG modem << 04 31 0x20000 0x100000 Non-Securerwxl
    2021-12-30T16:33:45.484Z DEBUG modem << Non-secure callable region 0 placed in flash region 3 with size 32.
    2021-12-30T16:33:45.534Z DEBUG modem << SRAM regionDomainPermissions
    2021-12-30T16:33:45.538Z DEBUG modem << 00 07 0x00000 0x10000 Securerwxl
    2021-12-30T16:33:45.541Z DEBUG modem << 08 31 0x10000 0x40000 Non-Securerwxl
    2021-12-30T16:33:45.545Z DEBUG modem << PeripheralDomainStatus
    2021-12-30T16:33:45.552Z DEBUG modem << 00 NRF_P0               Non-SecureOK
    2021-12-30T16:33:45.555Z DEBUG modem << 01 NRF_CLOCK            Non-SecureOK
    2021-12-30T16:33:45.559Z DEBUG modem << 02 NRF_RTC0             Non-SecureOK
    2021-12-30T16:33:45.561Z DEBUG modem << 03 NRF_RTC1             Non-SecureOK
    2021-12-30T16:33:45.567Z DEBUG modem << 04 NRF_NVMC             Non-SecureOK
    2021-12-30T16:33:45.572Z DEBUG modem << 05 NRF_UARTE1           Non-SecureOK
    2021-12-30T16:33:45.574Z DEBUG modem << 06 NRF_UARTE2           SecureSKIP
    2021-12-30T16:33:45.577Z DEBUG modem << 07 NRF_TWIM2            Non-SecureOK
    2021-12-30T16:33:45.580Z DEBUG modem << 08 NRF_SPIM3            Non-SecureOK
    2021-12-30T16:33:45.586Z DEBUG modem << 09 NRF_TIMER0           Non-SecureOK
    2021-12-30T16:33:45.587Z DEBUG modem << 10 NRF_TIMER1           Non-SecureOK
    2021-12-30T16:33:45.592Z DEBUG modem << 11 NRF_TIMER2           Non-SecureOK
    2021-12-30T16:33:45.593Z DEBUG modem << 12 NRF_SAADC            Non-SecureOK
    2021-12-30T16:33:45.595Z DEBUG modem << 13 NRF_PWM0             Non-SecureOK
    2021-12-30T16:33:45.601Z DEBUG modem << 14 NRF_PWM1             Non-SecureOK
    2021-12-30T16:33:45.603Z DEBUG modem << 15 NRF_PWM2             Non-SecureOK
    2021-12-30T16:33:45.608Z DEBUG modem << 16 NRF_PWM3             Non-SecureOK
    2021-12-30T16:33:45.609Z DEBUG modem << 17 NRF_WDT              Non-SecureOK
    2021-12-30T16:33:45.610Z DEBUG modem << 18 NRF_IPC              Non-SecureOK
    2021-12-30T16:33:45.612Z DEBUG modem << 19 NRF_VMC              Non-SecureOK
    2021-12-30T16:33:45.620Z DEBUG modem << 20 NRF_FPU              Non-SecureOK
    2021-12-30T16:33:45.622Z DEBUG modem << 21 NRF_EGU1             Non-SecureOK
    2021-12-30T16:33:45.624Z DEBUG modem << 22 NRF_EGU2             Non-SecureOK
    2021-12-30T16:33:45.627Z DEBUG modem << 23 NRF_DPPIC            Non-SecureOK
    2021-12-30T16:33:45.628Z DEBUG modem << 24 NRF_REGULATORS       Non-SecureOK
    2021-12-30T16:33:45.635Z DEBUG modem << 25 NRF_PDM              Non-SecureOK
    2021-12-30T16:33:45.637Z DEBUG modem << 26 NRF_I2S              Non-SecureOK
    2021-12-30T16:33:45.641Z DEBUG modem << 27 NRF_GPIOTE1          Non-SecureOK
    2021-12-30T16:33:45.642Z DEBUG modem << SPM: NS image at 0x20200
    2021-12-30T16:33:45.643Z DEBUG modem << SPM: NS MSP at 0x2001c738
    2021-12-30T16:33:45.650Z DEBUG modem << SPM: NS reset vector at 0x225c9
    2021-12-30T16:33:45.652Z DEBUG modem << SPM: prepare to jump to Non-Secure image.
    2021-12-30T16:33:45.860Z DEBUG modem << *** Booting Zephyr OS build v2.6.99-ncs1  ***
    2021-12-30T16:33:45.865Z DEBUG modem << The AT host sample started
    2021-12-30T16:33:53.644Z DEBUG modem >> AT+CFUN=0
    2021-12-30T16:33:53.659Z DEBUG modem << OK
    2021-12-30T16:34:05.701Z DEBUG modem >> AT+CGMR
    2021-12-30T16:34:05.714Z DEBUG modem << mfw_nrf9160_1.3.0
    2021-12-30T16:34:05.716Z DEBUG modem << OK
    2021-12-30T16:34:15.067Z DEBUG modem >> AT+CEREG=5
    2021-12-30T16:34:15.079Z DEBUG modem << OK
    2021-12-30T16:34:23.042Z DEBUG modem >> AT+CMEE=1
    2021-12-30T16:34:23.057Z DEBUG modem << OK
    2021-12-30T16:34:30.423Z DEBUG modem >> AT+CNEC=24
    2021-12-30T16:34:30.433Z DEBUG modem << OK
    2021-12-30T16:34:38.012Z DEBUG modem >> AT%CESQ=1
    2021-12-30T16:34:38.023Z DEBUG modem << OK
    2021-12-30T16:35:40.405Z DEBUG modem >> AT%XSYSTEMMODE?
    2021-12-30T16:35:40.421Z DEBUG modem << %XSYSTEMMODE: 0,1,0,0
    2021-12-30T16:35:40.422Z DEBUG modem << OK
    2021-12-30T16:35:56.852Z DEBUG modem >> AT+CFUN=1
    2021-12-30T16:35:56.886Z DEBUG modem << OK
    2021-12-30T16:36:19.388Z DEBUG modem >> AT+CFUN?
    2021-12-30T16:36:19.394Z DEBUG modem << +CFUN: 1
    2021-12-30T16:36:19.422Z DEBUG modem << OK
    2021-12-30T16:36:19.426Z DEBUG modem >> AT+CGSN=1
    2021-12-30T16:36:19.438Z DEBUG modem << +CGSN: "352656109830904"
    2021-12-30T16:36:19.441Z DEBUG modem << OK
    2021-12-30T16:36:19.445Z DEBUG modem >> AT+CGMI
    2021-12-30T16:36:19.453Z DEBUG modem << Nordic Semiconductor ASA
    2021-12-30T16:36:19.455Z DEBUG modem << OK
    2021-12-30T16:36:19.459Z DEBUG modem >> AT+CGMM
    2021-12-30T16:36:19.470Z DEBUG modem << nRF9160-SICA
    2021-12-30T16:36:19.476Z DEBUG modem << OK
    2021-12-30T16:36:19.479Z DEBUG modem >> AT+CGMR
    2021-12-30T16:36:19.490Z DEBUG modem << mfw_nrf9160_1.3.0
    2021-12-30T16:36:19.491Z DEBUG modem << OK
    2021-12-30T16:36:19.493Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.0] SerNr: 352656109830904
    2021-12-30T16:36:19.506Z DEBUG modem >> AT+CEMODE?
    2021-12-30T16:36:19.513Z DEBUG modem << +CEMODE: 0
    2021-12-30T16:36:19.517Z DEBUG modem << OK
    2021-12-30T16:36:19.528Z DEBUG modem >> AT%XCBAND=?
    2021-12-30T16:36:19.538Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2021-12-30T16:36:19.541Z DEBUG modem << OK
    2021-12-30T16:36:19.557Z DEBUG modem >> AT+CMEE?
    2021-12-30T16:36:19.563Z DEBUG modem << +CMEE: 1
    2021-12-30T16:36:19.570Z DEBUG modem << OK
    2021-12-30T16:36:19.574Z DEBUG modem >> AT+CNEC?
    2021-12-30T16:36:19.585Z DEBUG modem << +CNEC: 24
    2021-12-30T16:36:19.587Z DEBUG modem << OK
    2021-12-30T16:36:19.590Z DEBUG modem >> AT+CGEREP?
    2021-12-30T16:36:19.595Z DEBUG modem << +CGEREP: 0,0
    2021-12-30T16:36:19.603Z DEBUG modem <<
    2021-12-30T16:36:19.604Z DEBUG modem << OK
    2021-12-30T16:36:19.608Z DEBUG modem >> AT+CGDCONT?
    2021-12-30T16:36:19.612Z DEBUG modem << OK
    2021-12-30T16:36:19.619Z DEBUG modem >> AT+CGACT?
    2021-12-30T16:36:19.624Z DEBUG modem << OK
    2021-12-30T16:36:19.629Z DEBUG modem >> AT+CGEREP=1
    2021-12-30T16:36:19.636Z DEBUG modem << OK
    2021-12-30T16:36:19.640Z DEBUG modem >> AT+CIND=1,1,1
    2021-12-30T16:36:19.645Z DEBUG modem << OK
    2021-12-30T16:36:19.653Z DEBUG modem >> AT+CEREG=5
    2021-12-30T16:36:19.659Z DEBUG modem << OK
    2021-12-30T16:36:19.663Z DEBUG modem >> AT+CEREG?
    2021-12-30T16:36:19.672Z DEBUG modem << +CEREG: 5,4
    2021-12-30T16:36:19.674Z DEBUG modem << OK
    2021-12-30T16:36:19.691Z DEBUG modem >> AT%CESQ=1
    2021-12-30T16:36:19.697Z DEBUG modem << OK
    2021-12-30T16:36:19.702Z DEBUG modem >> AT+CESQ
    2021-12-30T16:36:19.709Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2021-12-30T16:36:19.710Z DEBUG modem << OK
    2021-12-30T16:36:19.721Z DEBUG modem >> AT%XSIM=1
    2021-12-30T16:36:19.725Z DEBUG modem << OK
    2021-12-30T16:36:19.730Z DEBUG modem >> AT%XSIM?
    2021-12-30T16:36:19.737Z DEBUG modem << %XSIM: 1
    2021-12-30T16:36:19.739Z DEBUG modem << OK
    2021-12-30T16:36:19.756Z DEBUG modem >> AT+CPIN?
    2021-12-30T16:36:19.762Z DEBUG modem << +CPIN: READY
    2021-12-30T16:36:19.764Z DEBUG modem << OK
    2021-12-30T16:36:19.774Z DEBUG modem >> AT+CPINR="SIM PIN"
    2021-12-30T16:36:19.787Z DEBUG modem << +CPINR: "SIM PIN",3
    2021-12-30T16:36:19.788Z DEBUG modem << OK
    2021-12-30T16:36:19.800Z DEBUG modem >> AT+CIMI
    2021-12-30T16:36:19.807Z DEBUG modem << 234500007202551
    2021-12-30T16:36:19.809Z DEBUG modem << OK
    2021-12-30T16:36:19.810Z INFO IMSIdentity: 234500007202551
    2021-12-30T16:37:56.890Z DEBUG modem << %CESQ: 61,3,20,2
    2021-12-30T16:37:56.911Z DEBUG modem << +CEREG: 2,"63EE","00072B15",9
    2021-12-30T16:37:57.395Z DEBUG modem << +CNEC_EMM: 13
    2021-12-30T16:37:57.400Z DEBUG modem << +CEREG: 2,"63EE","00072B15",9,0,13
    2021-12-30T16:37:57.700Z DEBUG modem << %CESQ: 255,0,255,0
    2021-12-30T16:37:57.707Z DEBUG modem << +CEREG: 2
    2021-12-30T16:37:58.367Z DEBUG modem << %CESQ: 58,2,15,2
    2021-12-30T16:38:46.669Z DEBUG modem << %CESQ: 61,3,20,2
    2021-12-30T16:51:29.563Z DEBUG modem << %CESQ: 58,2,15,2
    2021-12-30T16:52:10.522Z DEBUG modem << %CESQ: 60,3,20,2
    2021-12-30T16:58:01.241Z DEBUG modem << %CESQ: 58,2,15,2
    2021-12-30T16:58:16.581Z DEBUG modem << %CESQ: 60,3,20,2
    2021-12-30T16:58:34.520Z DEBUG modem << %CESQ: 55,2,14,2
    2021-12-30T16:58:39.620Z DEBUG modem << %CESQ: 59,2,19,2
    2021-12-30T17:07:14.198Z DEBUG modem << %CESQ: 57,2,13,1
    2021-12-30T17:07:26.997Z DEBUG modem << %CESQ: 59,2,18,2
    2021-12-30T17:10:49.237Z DEBUG modem << %CESQ: 57,2,13,1
    2021-12-30T17:13:04.916Z DEBUG modem << %CESQ: 58,2,18,2
    2021-12-30T17:15:12.914Z DEBUG modem << %CESQ: 61,3,23,3
    2021-12-30T17:15:43.601Z DEBUG modem << %CESQ: 60,3,18,2
    2021-12-30T17:26:35.794Z DEBUG modem << +CNEC_EMM: 13
    2021-12-30T17:26:35.806Z DEBUG modem << +CEREG: 2,"63EE","00072B15",9,0,13
    Hello
    Thanks for your reply.
    I have attached the log file.
    I used the NB Mode and the Hologram SIM card.
    I guess Error #13 means the network did not allow roaming ?
    Error cause number 13 is related to roaming not being allowed in a specific tracking area.
    It seems that there is no support for NB IoT in iBasis and Hologram cards. It might be similar for Vodafone.
    I suggest that you contact your network operator and check with them which cards, if any, can be used in your case.
    Dejan
  • Hi, Vodafone provide NB-IoT coverage in the UK.
    You will need an LPWA specific SIM to connect to the network (not an off-the-shelf PAYG SIM) and configure the correct APN name on the device.
    Are there any updates with regard to connectivity issue that you had experienced?
    Have you tried any other SIM card?
    Dejan
