Flash area error while doing DFU using nRF Connect
Dear support team,
I am getting an error while performing DFU using nRF Connect.
[00:02:39.702,697] <inf> mcuboot_util: Swap type: none
[00:02:39.702,972] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
My SDK version is 2.4.2, I need to do DFU using BLE simultaneously, for that i tried to modify Example mcuboot_smp_ble_simultaneous , but without modifying anything, while performing DFU by compiling this code i am getting this error, Even after getting this error new imaged is flashed successfully after DFU. i don't know the reason. my complete serial log is attached bellow.
D: RDSR 40 QE 1 need 1: no-change
I: Starting bootloader
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0xc000
*** Booting Zephyr OS build 28a3fca7da5c ***
Change this to see it change.
[00:00:00.030,853] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,883] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,914] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,623] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,653] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,653] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
Bluetooth initialized
Advertising successfully started
[00:02:39.978,576] <inf> mcuboot_util: Swap type: none
I: Swap type: perm
I: Swap type: perm
I: Image upgrade secondary slot -> primary slot
I: Erasing the primary slot
I: Copying the secondary slot to the primary slot: 0x1af50 bytes
D: writing magic; fa_id=4 off=0xf3ff0 (0xffff0)
D: erasing secondary header
D: erasing secondary trailer
I: Copying the secondary slot to the primary slot: 0x2e8d4 bytes
D: writing magic; fa_id=1 off=0x3fff0 (0x3fff0)
I: Turned on network core
I: Turned off network core
ÿ*** Booting Zephyr OS build 28a3fca7da5c ***
Krishnachandran_Test....
[00:00:00.030,883] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,914] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,944] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,653] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,684] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,684] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
If any idea regarding this, please help. Thanks in advance.
