simple gpio to control external FEM in NCS 2.7.0 & nrf5340
Hi Nordic team,
I am facing an issue about using simple gpio to control external FEM(custom FEM model) in NCS 2.7.0 & nrf5340.
Here is background:
1. Our project is using nRF5340, and based on NCS version before 2.7.0
2. For the network core, we copied NCS 2.6.1\zephyr\samples\bluetooth\hci_ipc, and modified a bit of code in oder to support simple gpio to control external FEM. by adding       macros and functions below:
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_POWER_MODEL=y
CONFIG_MPSL_FEM_SIMPLE_GPIO=y
CONFIG_MPSL_FEM_DEVICE_CONFIG_254=n
mpsl_fem_power_model_to_use_get()
model_fetch()
model_init()
3. it works fine on NCS 2.6.1, but it failed when I migrated it to NCS to 2.7.0 (still use 'no sysbuild', so net core child image is built from zephyr\samples\bluetooth\hci_ipc ).
    The netcore always gets BUS Fault and crashes when app core wants to set RF power. see the UART log from net core
[00:00:16.316,131] ^[[0m<inf> hci_ipc: Sent message of 12 bytes.^[[0m
[00:00:16.319,763] ^[[0m<inf> hci_ipc: Received message of 6 bytes.^[[0m
[00:00:16.320,068] ^[[0m<inf> hci_ipc: Sent message of 7 bytes.^[[0m
[00:00:16.340,515] ^[[0m<inf> hci_ipc: Received message of 8 bytes.^[[0m
[00:00:16.340,606] ^[[1;31m<err> os: ***** BUS FAULT *****^[[0m
[00:00:16.340,637] ^[[1;31m<err> os:   Precise data bus error^[[0m
[00:00:16.340,637] ^[[1;31m<err> os:   BFAR Address: 0x1^[[0m
[00:00:16.340,667] ^[[1;31m<err> os: r0/a1:  0x0000000d  r1/a2:  0x80000000  r2/a3:  0x00000001^[[0m
[00:00:16.340,728] ^[[1;31m<err> os: r3/a4:  0x00000000 r12/ip:  0x0101ea1d r14/lr:  0x0101d1c9^[[0m
[00:00:16.340,728] ^[[1;31m<err> os:  xpsr:  0x81004400^[[0m
[00:00:16.340,728] ^[[1;31m<err> os: Faulting instruction address (r15/pc): 0x0101d1d4^[[0m
[00:00:16.340,789] ^[[1;31m<err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0^[[0m
[00:00:16.340,820] ^[[1;31m<err> os: Current thread: 0x21002210 (HCI ipc TX)^[[0m
[00:00:16.439,147] ^[[1;31m<err> os: Halting system^[[0m
In oder to simplify the problem, I tried the NCS sample code under C:\ncs\v2.7.0\zephyr\samples\bluetooth\hci_pwr_ctrl on 5340DK, because in this sample, application code is also sending HCI cmd to net core to get/set RF power.  I observed lots of errors about the HCI command sending thru IPC  in function bt_hci_cmd_send_sync(),
Below is the UART log printed out from 5340DK app core:
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
Starting Dynamic Tx Power Beacon Demo
Get Tx power level ->[00:00:00.445,922] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x0c03 timeout with err 0
--- 10 messages dropped ---
[00:00:00.451,751] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2018 timeout with err 0
[00:00:00.452,362] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2018 timeout with err 0
[00:00:00.454,895] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x0c33 timeout with err 0
[00:00:00.455,291] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x0c31 timeout with err 0
[00:00:00.455,657] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2003 timeout with err 0
[00:00:00.456,024] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2002 timeout with err 0
[00:00:00.456,390] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x201c timeout with err 0
[00:00:00.456,756] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x202f timeout with err 0
[00:00:00.457,122] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2024 timeout with err 0
[00:00:00.457,519] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2001 timeout with err 0
[00:00:00.457,885] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x0c01 timeout with err 0
[00:00:00.458,251] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc01 timeout with err 0
[00:00:00.458,282] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.458,312] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.458,312] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 214.51162 Build 1926957230
[00:00:00.458,709] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc02 timeout with err 0
[00:00:00.459,106] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x1009 timeout with err 0
[00:00:00.459,472] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc09 timeout with err 0
[00:00:00.459,869] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2005 timeout with err 0
[00:00:00.460,021] <inf> bt_hci_core: Identity: F2:D1:8F:D5:69:8A (random)
[00:00:00.460,052] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x21fb, manufacturer 0x0059
[00:00:00.460,083] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x21fb
Bluetooth initialized
[00:00:00.460,540] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2006 timeout with err 0
[00:00:00.460,968] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2008 timeout with err 0
[00:00:00.461,364] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x2009 timeout with err 0
[00:00:00.461,914] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0x200a timeout with err 0
Dynamic Tx power Beacon started
Set Tx power level to 4
[00:00:05.446,838] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0e timeout with err 0
[00:00:05.446,868] <wrn> bt_hci_core: opcode 0xfc0e status 0x01
Set Tx power err: -5 reason 0x00
Get Tx power level -> [00:00:10.447,357] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0f timeout with err 0
[00:00:10.447,387] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
Read Tx power err: -5 reason 0x00
TXP = -1
Set Tx power level to 0
[00:00:10.447,814] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0e timeout with err 0
[00:00:10.447,814] <wrn> bt_hci_core: opcode 0xfc0e status 0x01
Get Tx power level -> [00:00:15.448,364] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0f timeout with err 0
[00:00:15.448,364] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
TXP = -1
Set Tx power level to -3
[00:00:15.448,791] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0e timeout with err 0
[00:00:15.448,822] <wrn> bt_hci_core: opcode 0xfc0e status 0x01
Get Tx power level -> [00:00:20.449,310] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0f timeout with err 0
[00:00:20.449,340] <wrn> bt_hci_core: opcode 0xfc0f status 0x01
TXP = -1
Set Tx power level to -8
[00:00:20.449,829] <wrn> bt_hci_core: bt_hci_cmd_send_sync: command opcode 0xfc0e timeout with err 0
[00:00:20.449,829] <wrn> bt_hci_core: opcode 0xfc0e status 0x01
Note: I used 'No sysbuild' in VsCode when building this sample so that net core child image is built from zephyr\samples\bluetooth\hci_ipc
Can you look at this issue?
If you need any more info, please let me know.
Thanks
    • Here is the generated .config file for net core's hci_ipc child image, under C:\ncs\v2.7.0\zephyr\samples\bluetooth\hci_pwr_ctrl\build\hci_ipc\zephyr
      # CONFIG_INPUT is not set
      # CONFIG_WIFI is not set
      # CONFIG_MIPI_DSI is not set
      # CONFIG_MODEM is not set
      # CONFIG_UART_INTERRUPT_DRIVEN is not set
      # CONFIG_SPI is not set
      CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
      CONFIG_BT_HCI_VS=y
      CONFIG_FLASH_LOAD_SIZE=0
      CONFIG_SRAM_SIZE=64
      CONFIG_FLASH_LOAD_OFFSET=0
      CONFIG_MBOX_NRFX_IPC=y
      CONFIG_BT_CTLR=y
      CONFIG_NUM_IRQS=30
      CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
      CONFIG_FLASH_SIZE=256
      CONFIG_FLASH_BASE_ADDRESS=0x1000000
      CONFIG_MP_MAX_NUM_CPUS=1
      CONFIG_PLATFORM_SPECIFIC_INIT=y
      CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
      CONFIG_ROM_START_OFFSET=0
      CONFIG_PINCTRL=y
      CONFIG_BUILD_OUTPUT_BIN=y
      CONFIG_XIP=y
      CONFIG_MAIN_STACK_SIZE=512
      CONFIG_IDLE_STACK_SIZE=256
      CONFIG_HAS_FLASH_LOAD_OFFSET=y
      # CONFIG_SRAM_VECTOR_TABLE is not set
      CONFIG_CPU_HAS_ARM_MPU=y
      # CONFIG_COUNTER is not set
      # CONFIG_SHARED_INTERRUPTS is not set
      # CONFIG_PM_DEVICE is not set
      CONFIG_TICKLESS_KERNEL=y
      CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
      # CONFIG_USE_DT_CODE_PARTITION is not set
      CONFIG_HW_STACK_PROTECTION=y
      # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
      CONFIG_SERIAL_INIT_PRIORITY=50
      CONFIG_GPIO=y
      CONFIG_SERIAL=y
      # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
      CONFIG_TINYCRYPT=y
      # CONFIG_MBEDTLS is not set
      # CONFIG_MEMC is not set
      CONFIG_KERNEL_ENTRY="__start"
      # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
      # CONFIG_DYNAMIC_INTERRUPTS is not set
      # CONFIG_CACHE is not set
      # CONFIG_LOG is not set
      # CONFIG_CODE_DATA_RELOCATION is not set
      CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
      CONFIG_DCACHE_LINE_SIZE=32
      CONFIG_GEN_IRQ_VECTOR_TABLE=y
      CONFIG_SOC="nrf5340"
      # CONFIG_RESET is not set
      CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
      CONFIG_NRF_RTC_TIMER=y
      # CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET is not set
      CONFIG_LOG_DOMAIN_NAME="net"
      CONFIG_BUILD_OUTPUT_HEX=y
      CONFIG_CLOCK_CONTROL=y
      CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
      CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
      # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
      # CONFIG_SYSCON is not set
      CONFIG_ENTROPY_INIT_PRIORITY=50
      CONFIG_GEN_ISR_TABLES=y
      CONFIG_GEN_IRQ_START_VECTOR=0
      CONFIG_GEN_SW_ISR_TABLE=y
      CONFIG_SRAM_OFFSET=0
      # CONFIG_REBOOT is not set
      # CONFIG_POWER_DOMAIN is not set
      CONFIG_CONSOLE=y
      CONFIG_SOC_SERIES="nrf53"
      CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
      CONFIG_ISR_STACK_SIZE=2048
      # CONFIG_SCHED_CPU_MASK is not set
      # CONFIG_WATCHDOG is not set
      CONFIG_ICACHE_LINE_SIZE=32
      CONFIG_PRIVILEGED_STACK_SIZE=1024
      # Devicetree Info
      CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
      CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
      CONFIG_DT_HAS_ARM_CORTEX_M33_ENABLED=y
      CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
      CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
      CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
      CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
      CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
      CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
      CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
      CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
      CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
      CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
      CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
      # end of Devicetree Info
      # Modules
      # Available modules.
      # nrf (C:/ncs/v2.7.0/nrf)
      CONFIG_MBOX=y
      CONFIG_NUM_METAIRQ_PRIORITIES=0
      # CONFIG_INIT_STACKS is not set
      CONFIG_MPSL_WORK_STACK_SIZE=1024
      # CONFIG_SHURE_QSPI_DMA_ENCRYPTION is not set
      # CONFIG_SHURE_QSPI_XIP_ENCRYPTION is not set
      # Nordic nRF Connect
      CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
      CONFIG_WARN_EXPERIMENTAL=y
      CONFIG_BT_BUF_CMD_TX_COUNT=10
      CONFIG_INIT_ARCH_HW_AT_BOOT=y
      CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=2048
      # CONFIG_GETOPT is not set
      # CONFIG_NCS_SAMPLES_DEFAULTS is not set
      # CONFIG_NCS_SAMPLE_EMPTY_APP_CORE_CHILD_IMAGE is not set
      # CONFIG_NCS_SAMPLE_DTM_REMOTE_HCI_CHILD_IMAGE is not set
      # Image build variants
      # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
      # end of Image build variants
      # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
      CONFIG_BT_BUF_ACL_TX_SIZE=27
      CONFIG_BT_BUF_ACL_RX_SIZE=27
      CONFIG_BT_CTLR_DATA_LENGTH_MAX=27
      # Subsystems
      # Bootloader
      # CONFIG_BUILD_S1_VARIANT is not set
      # CONFIG_SECURE_BOOT is not set
      CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
      # CONFIG_B0_MIN_PARTITION_SIZE is not set
      CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800
      # CONFIG_IS_SECURE_BOOTLOADER is not set
      # Secure Boot firmware validation
      CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
      CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
      CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
      CONFIG_SB_VALIDATION_INFO_VERSION=2
      CONFIG_SB_VALIDATION_METADATA_OFFSET=0
      CONFIG_SB_VALIDATE_FW_HASH=y
      # end of Secure Boot firmware validation
      # CONFIG_SECURE_BOOT_STORAGE is not set
      # end of Bootloader
      # Bluetooth Low Energy
      CONFIG_BT_COMPANY_ID_NORDIC=0x0059
      CONFIG_BT_COMPANY_ID=0x0059
      CONFIG_BT_MAX_CONN=16
      CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
      CONFIG_BT_LL_SOFTDEVICE=y
      CONFIG_BT_CTLR_DF_SUPPORT=y
      # SoftDevice Controller
      CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
      CONFIG_BT_HCI_TX_STACK_SIZE=1536
      CONFIG_BT_RX_STACK_SIZE=768
      # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
      # CONFIG_BT_CTLR_SDC_ALLOW_PARALLEL_SCANNING_AND_INITIATING is not set
      CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
      # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
      CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
      CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
      CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
      # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
      CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
      CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
      CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
      CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
      CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
      CONFIG_BT_CTLR_SDC_RX_PRIO=6
      # CONFIG_BT_CTLR_DF is not set
      CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
      CONFIG_BT_CTLR_FAL_SIZE=8
      CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
      # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
      CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
      CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK=y
      # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
      CONFIG_BT_CTLR_SDC_BIG_RESERVED_TIME_US=1600
      CONFIG_BT_CTLR_SDC_CIG_RESERVED_TIME_US=1300
      CONFIG_BT_CTLR_SDC_CIS_SUBEVENT_LENGTH_US=0
      # end of SoftDevice Controller
      # BLE Libraries
      # CONFIG_BT_GATT_POOL is not set
      # CONFIG_BT_GATT_DM is not set
      # CONFIG_BT_ADV_PROV is not set
      # CONFIG_BT_SCAN is not set
      # CONFIG_BT_CONN_CTX is not set
      # Bluetooth Services
      # CONFIG_BT_AMS_CLIENT is not set
      # CONFIG_BT_ANCS_CLIENT is not set
      # CONFIG_BT_BAS_CLIENT is not set
      # CONFIG_BT_BMS is not set
      # CONFIG_BT_CTS_CLIENT is not set
      # CONFIG_BT_DFU_SMP is not set
      # CONFIG_BT_GATTP is not set
      # CONFIG_BT_HIDS is not set
      # CONFIG_BT_HOGP is not set
      # CONFIG_BT_LBS is not set
      # CONFIG_BT_NSMS is not set
      # CONFIG_BT_NUS is not set
      # CONFIG_BT_NUS_CLIENT is not set
      # CONFIG_BT_RSCS is not set
      # CONFIG_BT_THROUGHPUT is not set
      # CONFIG_BT_LATENCY is not set
      # CONFIG_BT_LATENCY_CLIENT is not set
      # CONFIG_BT_HRS_CLIENT is not set
      # CONFIG_BT_DDFS is not set
      # CONFIG_BT_MDS is not set
      # CONFIG_BT_CGMS is not set
      # CONFIG_BT_FAST_PAIR is not set
      CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
      # end of Bluetooth Services
      # BLE over nRF RPC
      CONFIG_HEAP_MEM_POOL_SIZE=8192
      # CONFIG_BT_RPC_STACK is not set
      CONFIG_BT_CENTRAL=y
      CONFIG_BT_PERIPHERAL=y
      CONFIG_BT_OBSERVER=y
      CONFIG_BT_BROADCASTER=y
      CONFIG_BT_CONN=y
      CONFIG_BT_REMOTE_VERSION=y
      CONFIG_BT_PHY_UPDATE=y
      CONFIG_BT_DATA_LEN_UPDATE=y
      # CONFIG_BT_EXT_ADV is not set
      CONFIG_BT_BUF_ACL_TX_COUNT=7
      CONFIG_BT_BUF_ACL_RX_COUNT=6
      CONFIG_BT_BUF_EVT_RX_SIZE=68
      CONFIG_BT_BUF_EVT_RX_COUNT=10
      CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
      CONFIG_BT_BUF_CMD_TX_SIZE=65
      CONFIG_BT_HAS_HCI_VS=y
      # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
      # CONFIG_BT_HCI_MESH_EXT is not set
      # CONFIG_BT_WAIT_NOP is not set
      CONFIG_BT_RPA=y
      CONFIG_BT_ASSERT=y
      CONFIG_BT_ASSERT_VERBOSE=y
      # CONFIG_BT_ASSERT_PANIC is not set
      CONFIG_BT_DEBUG_NONE=y
      # CONFIG_BT_DEBUG_LOG is not set
      # CONFIG_BT_DEBUG_MONITOR_UART is not set
      # CONFIG_BT_LONG_WQ is not set
      # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
      CONFIG_BT_HCI_TX_PRIO=7
      # CONFIG_BT_RECV_WORKQ_SYS is not set
      CONFIG_BT_RECV_WORKQ_BT=y
      CONFIG_BT_RX_PRIO=8
      CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
      # CONFIG_BT_ECC is not set
      # CONFIG_BT_HOST_CCM is not set
      # CONFIG_BT_LOG_SNIFFER_INFO is not set
      # CONFIG_BT_TESTING is not set
      # CONFIG_BT_HCI_VS_EVT_USER is not set
      # end of BLE over nRF RPC
      # end of Bluetooth Low Energy
      # DFU
      # CONFIG_DFU_MULTI_IMAGE is not set
      # CONFIG_DFU_TARGET is not set
      # end of DFU
      # CONFIG_ESB is not set
      # Peripheral CPU DFU (PCD)
      # CONFIG_PCD is not set
      # CONFIG_PCD_APP is not set
      CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
      # CONFIG_PCD_NET is not set
      # end of Peripheral CPU DFU (PCD)
      # Networking
      # Application protocols
      # nRF Cloud
      # Client ID (nRF Cloud Device ID)
      CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
      CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
      # end of Client ID (nRF Cloud Device ID)
      # CONFIG_NRF_CLOUD_MQTT is not set
      # CONFIG_NRF_CLOUD_FOTA is not set
      CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
      CONFIG_FOTA_DL_TIMEOUT_MIN=15
      # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
      # CONFIG_NRF_CLOUD_REST is not set
      # CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
      # CONFIG_NRF_CLOUD_ALERT is not set
      CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
      # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
      CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
      # CONFIG_NRF_CLOUD_COAP is not set
      # Send shadow info sections on initial connect (MQTT/CoAP)
      # end of Send shadow info sections on initial connect (MQTT/CoAP)
      # CONFIG_NRF_CLOUD_GATEWAY is not set
      # end of nRF Cloud
      # CONFIG_REST_CLIENT is not set
      # CONFIG_DOWNLOAD_CLIENT is not set
      # CONFIG_AWS_IOT is not set
      # CONFIG_AWS_JOBS is not set
      # CONFIG_AZURE_IOT_HUB is not set
      # Self-Registration (Zi ZHu Ce)
      # end of Self-Registration (Zi ZHu Ce)
      # CONFIG_ICAL_PARSER is not set
      # CONFIG_FTP_CLIENT is not set
      # CONFIG_LWM2M_CLIENT_UTILS is not set
      # CONFIG_WIFI_CREDENTIALS is not set
      # CONFIG_WIFI_CREDENTIALS_STATIC is not set
      # CONFIG_MQTT_HELPER is not set
      # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
      # end of Application protocols
      # end of Networking
      # NFC
      # CONFIG_NFC_NDEF is not set
      # CONFIG_NFC_NDEF_PARSER is not set
      # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
      # CONFIG_NFC_T2T_PARSER is not set
      # CONFIG_NFC_T4T_NDEF_FILE is not set
      # CONFIG_NFC_T4T_ISODEP is not set
      # CONFIG_NFC_T4T_APDU is not set
      # CONFIG_NFC_T4T_CC_FILE is not set
      # CONFIG_NFC_T4T_HL_PROCEDURE is not set
      # CONFIG_NFC_PLATFORM is not set
      # CONFIG_NFC_TNEP_TAG is not set
      # CONFIG_NFC_TNEP_POLLER is not set
      # CONFIG_NFC_TNEP_CH is not set
      # end of NFC
      # CONFIG_APP_EVENT_MANAGER is not set
      # CONFIG_NRF_PROFILER is not set
      # CONFIG_FW_INFO is not set
      # Debug
      # CONFIG_CPU_LOAD is not set
      # CONFIG_PPI_TRACE is not set
      # end of Debug
      # CONFIG_SHELL_BT_NUS is not set
      # CONFIG_SHELL_IPC is not set
      # Multiprotocol service layer (MPSL)
      # CONFIG_MPSL_FEM_ONLY is not set
      CONFIG_MPSL_FEM_API_AVAILABLE=y
      # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
      CONFIG_MPSL_THREAD_COOP_PRIO=6
      CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
      # CONFIG_MPSL_ASSERT_HANDLER is not set
      # CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START is not set
      CONFIG_MPSL_LOW_PRIO_IRQN=26
      # CONFIG_MPSL_PIN_DEBUG is not set
      # end of Multiprotocol service layer (MPSL)
      # Partition Manager
      CONFIG_PARTITION_MANAGER_ENABLED=y
      CONFIG_FLASH_MAP_CUSTOM=y
      CONFIG_SRAM_BASE_ADDRESS=0x21000000
      # Zephyr subsystem configurations
      # end of Zephyr subsystem configurations
      # NCS subsystem configurations
      # CONFIG_PM_SINGLE_IMAGE is not set
      CONFIG_PM_EXTERNAL_FLASH_BASE=0
      CONFIG_PM_EXTERNAL_FLASH_PATH=""
      CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
      # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
      CONFIG_PM_SRAM_BASE=0x21000000
      CONFIG_PM_SRAM_SIZE=0x10000
      # end of Partition Manager
      # nRF RPC (Remote Procedure Call) library
      # end of nRF RPC (Remote Procedure Call) library
      # Full Modem Firmware Update Management(FMFU)
      # end of Full Modem Firmware Update Management(FMFU)
      # SUIT-based Firmware Update Management
      CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS=100
      CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS=y
      CONFIG_MGMT_SUITFU_GRP_IMG=y
      CONFIG_MGMT_SUITFU_IMAGE_NUMBER=0
      # CONFIG_MGMT_SUITFU_GRP_SUIT is not set
      # end of SUIT-based Firmware Update Management
      # CONFIG_CAF is not set
      # Nordic IEEE 802.15.4
      # end of Nordic IEEE 802.15.4
      # CONFIG_DM_MODULE is not set
      # nRF Security
      # CONFIG_NORDIC_SECURITY_BACKEND is not set
      # CONFIG_NRF_SECURITY is not set
      # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
      # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
      # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
      # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
      # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
      # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
      # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
      # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
      # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
      # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
      # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
      # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
      # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
      # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
      # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
      # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
      # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
      # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
      # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
      # CONFIG_PSA_WANT_ALG_CCM is not set
      # CONFIG_PSA_WANT_ALG_GCM is not set
      # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
      # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
      # CONFIG_PSA_WANT_ALG_CMAC is not set
      # CONFIG_PSA_WANT_ALG_HMAC is not set
      # CONFIG_PSA_WANT_ALG_SHA_1 is not set
      # CONFIG_PSA_WANT_ALG_SHA_224 is not set
      # CONFIG_PSA_WANT_ALG_SHA_384 is not set
      # CONFIG_PSA_WANT_ALG_SHA_512 is not set
      # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
      # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
      # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
      # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
      # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
      # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
      # CONFIG_PSA_WANT_ALG_SM3 is not set
      # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
      # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
      # CONFIG_PSA_WANT_ALG_MD2 is not set
      # CONFIG_PSA_WANT_ALG_MD4 is not set
      # CONFIG_PSA_WANT_ALG_MD5 is not set
      # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
      # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
      # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
      # CONFIG_PSA_WANT_ALG_CFB is not set
      # CONFIG_PSA_WANT_ALG_CTR is not set
      # CONFIG_PSA_WANT_ALG_OFB is not set
      # CONFIG_PSA_WANT_ALG_XTS is not set
      # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
      # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
      # CONFIG_PSA_WANT_ALG_ECDH is not set
      # CONFIG_PSA_WANT_ALG_FFDH is not set
      # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
      # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
      # CONFIG_PSA_WANT_ALG_ECDSA is not set
      # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
      # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
      # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
      # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
      # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
      # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
      # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
      # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
      # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
      # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
      # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
      # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
      # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
      # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
      # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
      # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
      # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
      # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
      # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
      # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
      # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
      # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
      # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
      # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
      # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
      # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
      # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
      # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
      # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
      # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
      # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
      # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
      # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
      # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
      # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
      # CONFIG_PSA_WANT_ALG_JPAKE is not set
      # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
      # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
      # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
      # CONFIG_PSA_WANT_ALG_SRP_6 is not set
      # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
      # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
      # CONFIG_PSA_WANT_ALG_ED25519PH is not set
      # CONFIG_PSA_WANT_ALG_ED448PH is not set
      # end of nRF Security
      # CONFIG_NET_CORE_MONITOR is not set
      # Audio Module
      # CONFIG_AUDIO_MODULE_TEST is not set
      CONFIG_AUDIO_MODULE_NAME_SIZE=20
      # end of Audio Module
      # CONFIG_UART_ASYNC_ADAPTER is not set
      # CONFIG_TRUSTED_STORAGE is not set
      # SUIT provisioning
      # CONFIG_SUIT_MPI_GENERATE is not set
      # end of SUIT provisioning
      # CONFIG_SUIT is not set
      # CONFIG_DULT is not set
      # end of Subsystems
      # CONFIG_WPA_SUPP is not set
      CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
      CONFIG_POSIX_MAX_FDS=4
      # CONFIG_WFA_QT_CONTROL_APP is not set
      CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
      CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
      CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
      CONFIG_WPAS_READY_TIMEOUT_MS=10000
      # Libraries
      # Binary libraries
      # end of Binary libraries
      # CONFIG_AT_MONITOR is not set
      # CONFIG_LTE_LINK_CONTROL is not set
      CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x800
      CONFIG_FPROTECT_BLOCK_SIZE=0x800
      # CONFIG_FPROTECT is not set
      # CONFIG_AT_CMD_CUSTOM is not set
      # CONFIG_DK_LIBRARY is not set
      # CONFIG_AT_CMD_PARSER is not set
      # CONFIG_MODEM_INFO is not set
      CONFIG_MULTITHREADING_LOCK=y
      # CONFIG_RESET_ON_FATAL_ERROR is not set
      # CONFIG_SMS is not set
      # CONFIG_DATE_TIME is not set
      # CONFIG_HW_ID_LIBRARY is not set
      # CONFIG_WAVE_GEN_LIB is not set
      CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x800
      # CONFIG_MODEM_JWT is not set
      # CONFIG_LOCATION is not set
      # CONFIG_QOS is not set
      # CONFIG_SFLOAT is not set
      # CONFIG_CONTIN_ARRAY is not set
      # CONFIG_PCM_MIX is not set
      # CONFIG_TONE is not set
      # CONFIG_PSCM is not set
      # CONFIG_DATA_FIFO is not set
      # CONFIG_FEM_AL_LIB is not set
      # CONFIG_SAMPLE_RATE_CONVERTER is not set
      CONFIG_NCS_BOOT_BANNER=y
      CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
      CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
      # end of Libraries
      # Device Drivers
      # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
      # CONFIG_ETH_RTT is not set
      # CONFIG_SENSOR is not set
      # CONFIG_NRF_SW_LPUART is not set
      CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
      # CONFIG_IPC_UART is not set
      # CONFIG_FLASH_RPC is not set
      CONFIG_CLOCK_CONTROL_MPSL=y
      CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
      # end of Device Drivers
      # External libraries
      # end of External libraries
      # Test
      CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
      # CONFIG_UNITY is not set
      # Mocks
      # CONFIG_MOCK_NRF_MODEM_AT is not set
      # end of Mocks
      # end of Test
      # end of Nordic nRF Connect
      CONFIG_ZEPHYR_NRF_MODULE=y
      # end of nrf (C:/ncs/v2.7.0/nrf)
      # mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
      CONFIG_ZEPHYR_MBEDTLS_MODULE=y
      # PSA RNG support
      # end of PSA RNG support
      # PSA key type support
      # end of PSA key type support
      # PSA AEAD support
      # end of PSA AEAD support
      # PSA MAC support
      # end of PSA MAC support
      # PSA Hash support
      # end of PSA Hash support
      # PSA Cipher support
      # end of PSA Cipher support
      # PSA Key agreement support
      # end of PSA Key agreement support
      # PSA Key derivation support
      # end of PSA Key derivation support
      # PSA Asymmetric support
      # Elliptic Curve type support
      # end of Elliptic Curve type support
      # end of PSA Asymmetric support
      # end of mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
      # oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
      CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
      # end of oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
      # trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
      # CONFIG_BOOTLOADER_MCUBOOT is not set
      CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
      # end of trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
      CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
      CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
      # cjson (C:/ncs/v2.7.0/modules/lib/cjson)
      # CONFIG_CJSON_LIB is not set
      CONFIG_ZEPHYR_CJSON_MODULE=y
      # end of cjson (C:/ncs/v2.7.0/modules/lib/cjson)
      # azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
      # CONFIG_AZURE_SDK is not set
      CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
      # end of azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
      # cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
      # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
      CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
      # end of cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
      # openthread (C:/ncs/v2.7.0/modules/lib/openthread)
      # CONFIG_OPENTHREAD is not set
      CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
      # end of openthread (C:/ncs/v2.7.0/modules/lib/openthread)
      # suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
      CONFIG_SUIT_ENVELOPE_TEMPLATE=""
      CONFIG_SUIT_ENVELOPE_TARGET=""
      CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
      CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
      # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
      CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
      # end of suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
      # suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
      # CONFIG_SUIT_PROCESSOR is not set
      CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
      CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
      # end of suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
      # memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
      # CONFIG_MEMFAULT is not set
      CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
      # end of memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
      # coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
      # CONFIG_COREMARK is not set
      CONFIG_ZEPHYR_COREMARK_MODULE=y
      # end of coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
      # canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
      CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
      # end of canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
      # chre (C:/ncs/v2.7.0/modules/lib/chre)
      CONFIG_ZEPHYR_CHRE_MODULE=y
      # CONFIG_CHRE is not set
      # end of chre (C:/ncs/v2.7.0/modules/lib/chre)
      # lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
      CONFIG_ZEPHYR_LZ4_MODULE=y
      # CONFIG_LZ4 is not set
      # end of lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
      # nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
      CONFIG_ZEPHYR_NANOPB_MODULE=y
      # CONFIG_NANOPB is not set
      # end of nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
      CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
      # zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
      # CONFIG_ZSL is not set
      CONFIG_ZEPHYR_ZSCILIB_MODULE=y
      # end of zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
      # cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
      CONFIG_ZEPHYR_CMSIS_MODULE=y
      CONFIG_HAS_CMSIS_CORE=y
      CONFIG_HAS_CMSIS_CORE_M=y
      # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
      # end of cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
      # cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
      CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
      # CONFIG_CMSIS_DSP is not set
      # end of cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
      # cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
      CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
      # CONFIG_CMSIS_NN is not set
      # end of cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
      # fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
      CONFIG_ZEPHYR_FATFS_MODULE=y
      # end of fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
      # hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
      CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
      CONFIG_HAS_NORDIC_DRIVERS=y
      # Nordic drivers
      # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
      # CONFIG_NRF_802154_RADIO_DRIVER is not set
      # CONFIG_NRF_802154_SER_RADIO is not set
      # end of Nordic drivers
      CONFIG_HAS_NRFX=y
      # nrfx drivers
      CONFIG_MPSL=y
      # CONFIG_NRFX_CLOCK is not set
      CONFIG_NRFX_DPPI=y
      # CONFIG_NRFX_EGU0 is not set
      CONFIG_NRFX_GPIOTE=y
      CONFIG_NRFX_GPIOTE0=y
      CONFIG_NRFX_IPC=y
      # CONFIG_NRFX_NVMC is not set
      # CONFIG_NRFX_POWER is not set
      # CONFIG_NRFX_RNG is not set
      # CONFIG_NRFX_RTC0 is not set
      # CONFIG_NRFX_RTC1 is not set
      # CONFIG_NRFX_SPIM0 is not set
      # CONFIG_NRFX_SYSTICK is not set
      # CONFIG_NRFX_TEMP is not set
      # CONFIG_NRFX_TIMER0 is not set
      # CONFIG_NRFX_TIMER1 is not set
      # CONFIG_NRFX_TIMER2 is not set
      # CONFIG_NRFX_TWIM0 is not set
      # CONFIG_NRFX_UARTE0 is not set
      # CONFIG_NRFX_WDT0 is not set
      # Peripheral Resource Sharing module
      # CONFIG_NRFX_PRS_BOX_0 is not set
      # CONFIG_NRFX_PRS_BOX_1 is not set
      # CONFIG_NRFX_PRS_BOX_2 is not set
      # CONFIG_NRFX_PRS_BOX_3 is not set
      # CONFIG_NRFX_PRS_BOX_4 is not set
      # end of Peripheral Resource Sharing module
      # end of nrfx drivers
      # end of hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
      # hal_st (C:/ncs/v2.7.0/modules/hal/st)
      CONFIG_ZEPHYR_HAL_ST_MODULE=y
      # end of hal_st (C:/ncs/v2.7.0/modules/hal/st)
      CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
      CONFIG_ZEPHYR_LIBMETAL_MODULE=y
      # liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
      CONFIG_ZEPHYR_LIBLC3_MODULE=y
      # end of liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
      # littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
      CONFIG_ZEPHYR_LITTLEFS_MODULE=y
      # end of littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
      # loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
      CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
      # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
      # end of loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
      # lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
      CONFIG_ZEPHYR_LVGL_MODULE=y
      # end of lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
      CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
      CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
      CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
      # picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
      # CONFIG_PICOLIBC_MODULE is not set
      CONFIG_ZEPHYR_PICOLIBC_MODULE=y
      # end of picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
      # segger (C:/ncs/v2.7.0/modules/debug/segger)
      CONFIG_ZEPHYR_SEGGER_MODULE=y
      CONFIG_HAS_SEGGER_RTT=y
      # CONFIG_USE_SEGGER_RTT is not set
      # end of segger (C:/ncs/v2.7.0/modules/debug/segger)
      CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
      # uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
      CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
      # end of uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
      # zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
      CONFIG_ZEPHYR_ZCBOR_MODULE=y
      # CONFIG_ZCBOR is not set
      # end of zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
      # mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
      # MCUboot
      CONFIG_BOOT_SIGNATURE_KEY_FILE=""
      CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
      # end of MCUboot
      CONFIG_ZEPHYR_MCUBOOT_MODULE=y
      # end of mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
      # nrfxlib (C:/ncs/v2.7.0/nrfxlib)
      # Nordic nrfxlib
      # nrf_modem (Modem library)
      # end of nrf_modem (Modem library)
      CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
      # CONFIG_NFC_T2T_NRFXLIB is not set
      # CONFIG_NFC_T4T_NRFXLIB is not set
      CONFIG_MPSL_BUILD_TYPE_LIB=y
      CONFIG_MPSL_LIB_DIR="cortex-m33+nodsp"
      CONFIG_MPSL_LIB_FLOAT_ABI_DIR="soft-float"
      # Crypto libraries for nRF5x SOCs.
      CONFIG_NRFXLIB_CRYPTO=y
      CONFIG_NRF_OBERON=y
      # CONFIG_NRF_CC310_BL is not set
      # end of Crypto libraries for nRF5x SOCs.
      # CONFIG_NRF_RPC is not set
      CONFIG_NRF_802154_SOURCE_NRFXLIB=y
      # CONFIG_GZLL is not set
      # CONFIG_NRF_DM is not set
      # CONFIG_NRF_FUEL_GAUGE is not set
      # end of Nordic nrfxlib
      CONFIG_ZEPHYR_NRFXLIB_MODULE=y
      # end of nrfxlib (C:/ncs/v2.7.0/nrfxlib)
      # connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
      # CONFIG_CHIP is not set
      CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
      # end of connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
      CONFIG_LIBMETAL=y
      CONFIG_LIBMETAL_SRC_PATH="libmetal"
      # CONFIG_LVGL is not set
      # CONFIG_HAS_MEC_HAL is not set
      # CONFIG_HAS_MPFS_HAL is not set
      # CONFIG_HAS_MEC5_HAL is not set
      CONFIG_OPENAMP=y
      CONFIG_OPENAMP_SRC_PATH="open-amp"
      CONFIG_OPENAMP_MASTER=y
      CONFIG_OPENAMP_SLAVE=y
      # CONFIG_MIPI_SYST_LIB is not set
      # CONFIG_HAS_TELINK_DRIVERS is not set
      # CONFIG_TINYCRYPT_CTR_PRNG is not set
      # CONFIG_TINYCRYPT_SHA256 is not set
      # CONFIG_TINYCRYPT_ECC_DH is not set
      # CONFIG_TINYCRYPT_ECC_DSA is not set
      CONFIG_TINYCRYPT_AES=y
      # CONFIG_TINYCRYPT_AES_CBC is not set
      # CONFIG_TINYCRYPT_AES_CTR is not set
      # CONFIG_TINYCRYPT_AES_CCM is not set
      # CONFIG_TINYCRYPT_AES_CMAC is not set
      # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
      # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
      # Unavailable modules, please install those via the project manifest.
      # hal_gigadevice module not available.
      # Trusted-firmware-a module not available.
      # THRIFT module not available.
      # CONFIG_ACPI is not set
      # end of Modules
      CONFIG_BOARD="nrf5340dk"
      CONFIG_BOARD_REVISION=""
      CONFIG_BOARD_TARGET="nrf5340dk/nrf5340/cpunet"
      # CONFIG_NET_DRIVERS is not set
      CONFIG_BOARD_NRF5340DK=y
      CONFIG_BOARD_NRF5340DK_NRF5340_CPUNET=y
      CONFIG_BOARD_QUALIFIERS="nrf5340/cpunet"
      # Board Options
      CONFIG_DOMAIN_CPUAPP_BOARD="nrf5340dk/nrf5340/cpuapp"
      # end of Board Options
      # Hardware Configuration
      CONFIG_SOC_FAMILY="nordic_nrf"
      CONFIG_SOC_FAMILY_NORDIC_NRF=y
      CONFIG_SOC_SERIES_NRF53X=y
      CONFIG_SOC_NRF5340_CPUNET=y
      CONFIG_SOC_NRF5340_CPUNET_QKAA=y
      # CONFIG_MFD is not set
      # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
      CONFIG_HAS_HW_NRF_ACL=y
      CONFIG_HAS_HW_NRF_CCM=y
      CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
      CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
      CONFIG_HAS_HW_NRF_CLOCK=y
      CONFIG_HAS_HW_NRF_DPPIC=y
      CONFIG_HAS_HW_NRF_ECB=y
      CONFIG_HAS_HW_NRF_EGU0=y
      CONFIG_HAS_HW_NRF_GPIO0=y
      CONFIG_HAS_HW_NRF_GPIO1=y
      CONFIG_HAS_HW_NRF_GPIOTE0=y
      CONFIG_HAS_HW_NRF_IPC=y
      CONFIG_HAS_HW_NRF_NVMC_PE=y
      CONFIG_HAS_HW_NRF_POWER=y
      CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
      CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
      CONFIG_HAS_HW_NRF_RADIO_DFE=y
      CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
      CONFIG_HAS_HW_NRF_RNG=y
      CONFIG_HAS_HW_NRF_SWI0=y
      CONFIG_HAS_HW_NRF_SWI1=y
      CONFIG_HAS_HW_NRF_SWI2=y
      CONFIG_HAS_HW_NRF_SWI3=y
      CONFIG_HAS_HW_NRF_TEMP=y
      CONFIG_HAS_HW_NRF_UARTE0=y
      CONFIG_HAS_HW_NRF_VMC=y
      CONFIG_HAS_HW_NRF_WDT0=y
      CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
      CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
      CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
      CONFIG_SOC_NRF53_RTC_PRETICK=y
      CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
      CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
      CONFIG_NRF_ENABLE_CACHE=y
      # CONFIG_NRF53_SYNC_RTC is not set
      CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
      CONFIG_NRF_SOC_SECURE_SUPPORTED=y
      CONFIG_NRF_APPROTECT_USE_UICR=y
      # CONFIG_NRF_APPROTECT_LOCK is not set
      # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
      # CONFIG_NRF_TRACE_PORT is not set
      CONFIG_GPIO_INIT_PRIORITY=40
      # end of Hardware Configuration
      CONFIG_SOC_COMPATIBLE_NRF=y
      CONFIG_SOC_COMPATIBLE_NRF53X=y
      CONFIG_SOC_COMPATIBLE_NRF5340_CPUNET=y
      CONFIG_ARCH="arm"
      CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
      # CONFIG_EXTRA_EXCEPTION_INFO is not set
      CONFIG_CPU_CORTEX=y
      CONFIG_KOBJECT_TEXT_AREA=256
      CONFIG_ARM_MPU=y
      CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
      # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
      # ARM Options
      CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
      CONFIG_ARM_ON_ENTER_CPU_IDLE_PREPARE_HOOK=y
      CONFIG_ARM_ON_EXIT_CPU_IDLE=y
      CONFIG_CPU_CORTEX_M=y
      # CONFIG_ARM_ZIMAGE_HEADER is not set
      CONFIG_ISA_THUMB2=y
      CONFIG_ASSEMBLER_ISA_THUMB2=y
      CONFIG_COMPILER_ISA_THUMB2=y
      CONFIG_STACK_ALIGN_DOUBLE_WORD=y
      # CONFIG_RUNTIME_NMI is not set
      CONFIG_FAULT_DUMP=2
      CONFIG_BUILTIN_STACK_GUARD=y
      CONFIG_ARM_STACK_PROTECTION=y
      CONFIG_FP16=y
      CONFIG_FP16_IEEE=y
      # CONFIG_FP16_ALT is not set
      CONFIG_CPU_CORTEX_M33=y
      CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
      CONFIG_CPU_CORTEX_M_HAS_DWT=y
      CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
      CONFIG_CPU_CORTEX_M_HAS_VTOR=y
      CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
      CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
      CONFIG_CPU_CORTEX_M_HAS_CMSE=y
      CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
      CONFIG_ARMV8_M_MAINLINE=y
      # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
      CONFIG_ZERO_LATENCY_IRQS=y
      CONFIG_ZERO_LATENCY_LEVELS=1
      # CONFIG_SW_VECTOR_RELAY is not set
      # CONFIG_CORTEX_M_DWT is not set
      # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
      # CONFIG_TRAP_UNALIGNED_ACCESS is not set
      # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
      CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
      # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
      # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
      # CONFIG_MPU_STACK_GUARD is not set
      # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
      # CONFIG_CUSTOM_SECTION_ALIGN is not set
      CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
      CONFIG_HAS_SWO=y
      # end of ARM Options
      CONFIG_ARM=y
      CONFIG_ARCH_IS_SET=y
      # General Architecture Options
      # CONFIG_SEMIHOST is not set
      CONFIG_LITTLE_ENDIAN=y
      # CONFIG_USERSPACE is not set
      CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
      CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
      CONFIG_GEN_PRIV_STACKS=y
      # CONFIG_STACK_GROWS_UP is not set
      # Interrupt Configuration
      CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
      # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
      CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
      # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
      CONFIG_EXCEPTION_DEBUG=y
      # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
      # end of Interrupt Configuration
      # end of General Architecture Options
      CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
      CONFIG_ARCH_HAS_STACK_PROTECTION=y
      CONFIG_ARCH_HAS_USERSPACE=y
      CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
      CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
      CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
      CONFIG_ARCH_SUPPORTS_COREDUMP=y
      CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
      CONFIG_ARCH_SUPPORTS_ROM_START=y
      CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
      CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
      CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
      CONFIG_ARCH_HAS_THREAD_ABORT=y
      CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
      CONFIG_CPU_HAS_MPU=y
      CONFIG_MPU=y
      CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
      CONFIG_MPU_GAP_FILLING=y
      CONFIG_SRAM_REGION_PERMISSIONS=y
      # DSP Options
      # end of DSP Options
      # Floating Point Options
      # end of Floating Point Options
      # Cache Options
      # end of Cache Options
      CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
      # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
      # General Kernel Options
      CONFIG_MULTITHREADING=y
      CONFIG_NUM_COOP_PRIORITIES=16
      CONFIG_NUM_PREEMPT_PRIORITIES=15
      CONFIG_MAIN_THREAD_PRIORITY=0
      CONFIG_COOP_ENABLED=y
      CONFIG_PREEMPT_ENABLED=y
      CONFIG_PRIORITY_CEILING=-127
      # CONFIG_SCHED_DEADLINE is not set
      CONFIG_THREAD_STACK_INFO=y
      # CONFIG_THREAD_CUSTOM_DATA is not set
      # CONFIG_DYNAMIC_THREAD is not set
      CONFIG_SCHED_DUMB=y
      # CONFIG_SCHED_SCALABLE is not set
      # CONFIG_SCHED_MULTIQ is not set
      # CONFIG_WAITQ_SCALABLE is not set
      CONFIG_WAITQ_DUMB=y
      # Misc Kernel related options
      CONFIG_LIBC_ERRNO=y
      CONFIG_ERRNO=y
      CONFIG_CURRENT_THREAD_USE_TLS=y
      # end of Misc Kernel related options
      # Kernel Debugging and Metrics
      CONFIG_BOOT_DELAY=0
      # CONFIG_THREAD_MONITOR is not set
      # CONFIG_THREAD_NAME is not set
      # CONFIG_THREAD_RUNTIME_STATS is not set
      # end of Kernel Debugging and Metrics
      # CONFIG_OBJ_CORE is not set
      # System Work Queue Options
      # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
      # end of System Work Queue Options
      # Barrier Operations
      CONFIG_BARRIER_OPERATIONS_ARCH=y
      # end of Barrier Operations
      # Atomic Operations
      CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
      # end of Atomic Operations
      # Timer API Options
      CONFIG_TIMESLICING=y
      CONFIG_TIMESLICE_SIZE=0
      CONFIG_TIMESLICE_PRIORITY=0
      # CONFIG_TIMESLICE_PER_THREAD is not set
      # end of Timer API Options
      # Other Kernel Object Options
      CONFIG_POLL=y
      # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
      CONFIG_NUM_MBOX_ASYNC_MSGS=10
      # CONFIG_EVENTS is not set
      # CONFIG_PIPES is not set
      CONFIG_KERNEL_MEM_POOL=y
      # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
      # end of Other Kernel Object Options
      CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
      CONFIG_SWAP_NONATOMIC=y
      CONFIG_SYS_CLOCK_EXISTS=y
      CONFIG_TIMEOUT_64BIT=y
      CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
      # Security Options
      # CONFIG_STACK_CANARIES is not set
      CONFIG_STACK_POINTER_RANDOM=0
      # end of Security Options
      # Memory Domains
      CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
      CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
      # end of Memory Domains
      # SMP Options
      CONFIG_MP_NUM_CPUS=1
      # CONFIG_TICKET_SPINLOCKS is not set
      # end of SMP Options
      CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
      CONFIG_THREAD_LOCAL_STORAGE=y
      # end of General Kernel Options
      # Device Options
      # CONFIG_DEVICE_DEPS is not set
      # CONFIG_DEVICE_MUTABLE is not set
      # end of Device Options
      # Initialization Priorities
      CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
      CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
      CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
      CONFIG_APPLICATION_INIT_PRIORITY=90
      # end of Initialization Priorities
      # Virtual Memory Support
      # end of Virtual Memory Support
      # Device Drivers
      # CONFIG_ADC is not set
      # CONFIG_AUDIO is not set
      # CONFIG_AUXDISPLAY is not set
      # CONFIG_BBRAM is not set
      # CONFIG_CAN is not set
      # CONFIG_CHARGER is not set
      CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
      CONFIG_CLOCK_CONTROL_NRF=y
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
      CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
      CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
      # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
      CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
      # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
      CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
      CONFIG_CONSOLE_HAS_DRIVER=y
      # CONFIG_CONSOLE_HANDLER is not set
      CONFIG_CONSOLE_INIT_PRIORITY=60
      CONFIG_UART_CONSOLE=y
      # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
      # CONFIG_UART_CONSOLE_MCUMGR is not set
      # CONFIG_RAM_CONSOLE is not set
      # CONFIG_IPM_CONSOLE_SENDER is not set
      # CONFIG_IPM_CONSOLE_RECEIVER is not set
      # CONFIG_UART_MCUMGR is not set
      # CONFIG_GSM_MUX is not set
      # CONFIG_EFI_CONSOLE is not set
      # CONFIG_COREDUMP_DEVICE is not set
      # CONFIG_CRYPTO is not set
      # CONFIG_DAC is not set
      # CONFIG_DAI is not set
      # CONFIG_DISK_DRIVERS is not set
      # CONFIG_DISPLAY is not set
      # CONFIG_DMA is not set
      # CONFIG_EDAC is not set
      # CONFIG_EEPROM is not set
      CONFIG_ENTROPY_GENERATOR=y
      CONFIG_ENTROPY_NRF5_RNG=y
      # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
      CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
      CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
      CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
      CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
      CONFIG_ENTROPY_HAS_DRIVER=y
      # CONFIG_ESPI is not set
      # CONFIG_FLASH is not set
      # CONFIG_FPGA is not set
      # CONFIG_FUEL_GAUGE is not set
      # CONFIG_GNSS is not set
      # CONFIG_GPIO_GET_DIRECTION is not set
      # CONFIG_GPIO_GET_CONFIG is not set
      # CONFIG_GPIO_HOGS is not set
      # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
      CONFIG_GPIO_NRFX=y
      CONFIG_GPIO_NRFX_INTERRUPT=y
      # CONFIG_HWINFO is not set
      # CONFIG_HWSPINLOCK is not set
      # CONFIG_I2C is not set
      # CONFIG_I2S is not set
      # CONFIG_I3C is not set
      # Interrupt controller drivers
      CONFIG_INTC_INIT_PRIORITY=40
      # CONFIG_INTC_ESP32 is not set
      # end of Interrupt controller drivers
      # CONFIG_IPM is not set
      # CONFIG_KSCAN is not set
      # CONFIG_LED is not set
      # CONFIG_LED_STRIP is not set
      # CONFIG_LORA is not set
      CONFIG_MBOX_INIT_PRIORITY=40
      # CONFIG_MDIO is not set
      # CONFIG_MIPI_DBI is not set
      # Miscellaneous Drivers
      # CONFIG_TIMEAWARE_GPIO is not set
      # end of Miscellaneous Drivers
      # CONFIG_MM_DRV is not set
      # CONFIG_PCIE is not set
      # CONFIG_PCIE_ENDPOINT is not set
      # CONFIG_PECI is not set
      CONFIG_PINCTRL_STORE_REG=y
      # CONFIG_PINCTRL_DYNAMIC is not set
      CONFIG_PINCTRL_NRF=y
      # CONFIG_PM_CPU_OPS is not set
      # CONFIG_PS2 is not set
      # CONFIG_PTP_CLOCK is not set
      # CONFIG_PWM is not set
      # CONFIG_REGULATOR is not set
      # CONFIG_RETAINED_MEM is not set
      # CONFIG_RTC is not set
      # CONFIG_SDHC is not set
      # Capabilities
      CONFIG_SERIAL_HAS_DRIVER=y
      CONFIG_SERIAL_SUPPORT_ASYNC=y
      CONFIG_SERIAL_SUPPORT_INTERRUPT=y
      # CONFIG_UART_ASYNC_API is not set
      # CONFIG_UART_LINE_CTRL is not set
      # CONFIG_UART_DRV_CMD is not set
      # CONFIG_UART_WIDE_DATA is not set
      # CONFIG_UART_PIPE is not set
      # CONFIG_UART_ASYNC_RX_HELPER is not set
      # Serial Drivers
      CONFIG_UART_NRFX=y
      CONFIG_UART_NRFX_UARTE=y
      CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
      CONFIG_UART_0_ENHANCED_POLL_OUT=y
      # CONFIG_UART_0_NRF_PARITY_BIT is not set
      CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
      # CONFIG_SMBUS is not set
      # Timer drivers
      # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
      # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
      CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
      CONFIG_TICKLESS_CAPABLE=y
      CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
      CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
      # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
      # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
      # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
      CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
      # end of Timer drivers
      # CONFIG_USB_BC12 is not set
      # CONFIG_UDC_DRIVER is not set
      # CONFIG_UHC_DRIVER is not set
      # CONFIG_UVB is not set
      # CONFIG_USB_DEVICE_DRIVER is not set
      # CONFIG_USBC_TCPC_DRIVER is not set
      # CONFIG_USBC_VBUS_DRIVER is not set
      # CONFIG_USBC_PPC_DRIVER is not set
      # CONFIG_VIDEO is not set
      # CONFIG_VIRTUALIZATION is not set
      # CONFIG_W1 is not set
      # CONFIG_REQUIRES_FULL_LIBC is not set
      # CONFIG_REQUIRES_FLOAT_PRINTF is not set
      CONFIG_FULL_LIBC_SUPPORTED=y
      CONFIG_MINIMAL_LIBC_SUPPORTED=y
      CONFIG_NEWLIB_LIBC_SUPPORTED=y
      CONFIG_PICOLIBC_SUPPORTED=y
      # C Library
      # CONFIG_MINIMAL_LIBC is not set
      CONFIG_PICOLIBC=y
      # CONFIG_NEWLIB_LIBC is not set
      # CONFIG_EXTERNAL_LIBC is not set
      CONFIG_HAS_NEWLIB_LIBC_NANO=y
      CONFIG_COMMON_LIBC_ABORT=y
      CONFIG_COMMON_LIBC_MALLOC=y
      CONFIG_COMMON_LIBC_CALLOC=y
      CONFIG_COMMON_LIBC_REALLOCARRAY=y
      # CONFIG_PICOLIBC_USE_MODULE is not set
      CONFIG_PICOLIBC_USE_TOOLCHAIN=y
      CONFIG_PICOLIBC_HEAP_SIZE=-2
      # CONFIG_PICOLIBC_IO_FLOAT is not set
      CONFIG_PICOLIBC_IO_LONG_LONG=y
      CONFIG_STDOUT_CONSOLE=y
      CONFIG_NEED_LIBC_MEM_PARTITION=y
      # end of C Library
      # C++ Language Support
      # CONFIG_CPP is not set
      # Deprecated
      # CONFIG_CPLUSPLUS is not set
      # CONFIG_LIB_CPLUSPLUS is not set
      # end of Deprecated
      # end of C++ Language Support
      # CONFIG_CRC is not set
      # Additional libraries
      # Hash Function Support
      # CONFIG_SYS_HASH_FUNC32 is not set
      # end of Hash Function Support
      # Hashmap (Hash Table) Support
      # CONFIG_SYS_HASH_MAP is not set
      # end of Hashmap (Hash Table) Support
      # Heap and Memory Allocation
      # CONFIG_SYS_HEAP_VALIDATE is not set
      # CONFIG_SYS_HEAP_STRESS is not set
      # CONFIG_SYS_HEAP_INFO is not set
      CONFIG_SYS_HEAP_ALLOC_LOOPS=3
      # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
      # CONFIG_SYS_HEAP_LISTENER is not set
      # CONFIG_SYS_HEAP_SMALL_ONLY is not set
      # CONFIG_SYS_HEAP_BIG_ONLY is not set
      CONFIG_SYS_HEAP_AUTO=y
      # CONFIG_MULTI_HEAP is not set
      # CONFIG_SHARED_MULTI_HEAP is not set
      # end of Heap and Memory Allocation
      # Memory Blocks
      # CONFIG_SYS_MEM_BLOCKS is not set
      # end of Memory Blocks
      # OS Support Library
      # CONFIG_FDTABLE is not set
      # CONFIG_PRINTK_SYNC is not set
      # CONFIG_MPSC_PBUF is not set
      # CONFIG_SPSC_PBUF is not set
      CONFIG_CBPRINTF_COMPLETE=y
      # CONFIG_CBPRINTF_NANO is not set
      CONFIG_CBPRINTF_FULL_INTEGRAL=y
      # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
      # CONFIG_CBPRINTF_FP_SUPPORT is not set
      # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
      # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
      # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
      # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
      CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
      # end of OS Support Library
      # POSIX API Support
      # POSIX Options
      # CONFIG_POSIX_API is not set
      # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
      # CONFIG_POSIX_CLOCK is not set
      # CONFIG_POSIX_CONFSTR is not set
      # CONFIG_POSIX_ENV is not set
      # CONFIG_EVENTFD is not set
      # File descriptor table options
      # end of File descriptor table options
      # CONFIG_FNMATCH is not set
      # CONFIG_GETENTROPY is not set
      # CONFIG_POSIX_MQUEUE is not set
      # sem_t support
      CONFIG_SEM_VALUE_MAX=32767
      CONFIG_SEM_NAMELEN_MAX=16
      # end of sem_t support
      # Signal support
      CONFIG_POSIX_RTSIG_MAX=0
      # CONFIG_POSIX_SIGNAL is not set
      # end of Signal support
      # CONFIG_POSIX_PUTMSG is not set
      # Sysconf support
      # CONFIG_POSIX_SYSCONF is not set
      CONFIG_POSIX_PAGE_SIZE_BITS=6
      # end of Sysconf support
      # CONFIG_POSIX_SYSLOG is not set
      # CONFIG_TIMER is not set
      # CONFIG_POSIX_UNAME is not set
      # end of POSIX Options
      # POSIX Shell Utilities
      # end of POSIX Shell Utilities
      # end of POSIX API Support
      # CONFIG_OPENAMP_RSC_TABLE is not set
      # CONFIG_SMF is not set
      CONFIG_LIBGCC_RTLIB=y
      # Utility Library
      # CONFIG_JSON_LIBRARY is not set
      # CONFIG_RING_BUFFER is not set
      CONFIG_NOTIFY=y
      # CONFIG_BASE64 is not set
      CONFIG_ONOFF=y
      # CONFIG_WINSTREAM is not set
      # CONFIG_UTF8 is not set
      # end of Utility Library
      # end of Additional libraries
      # Subsystems and OS Services
      # CONFIG_BINDESC is not set
      CONFIG_BT=y
      CONFIG_BT_HCI=y
      # CONFIG_BT_CUSTOM is not set
      CONFIG_BT_HCI_RAW=y
      # CONFIG_BT_HCI_RAW_H4 is not set
      # CONFIG_BT_HCI_RAW_CMD_EXT is not set
      CONFIG_BT_CONN_TX=y
      # CONFIG_BT_SCA_UPDATE is not set
      # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
      # CONFIG_BT_ISO_PERIPHERAL is not set
      # CONFIG_BT_ISO_CENTRAL is not set
      # CONFIG_BT_ISO_BROADCASTER is not set
      # CONFIG_BT_ISO_SYNC_RECEIVER is not set
      # Bluetooth buffer configuration
      # end of Bluetooth buffer configuration
      # Bluetooth Host
      # Bluetooth Classic Options
      # end of Bluetooth Classic Options
      # end of Bluetooth Host
      CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
      CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
      CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
      CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
      CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
      CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
      CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
      CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
      CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
      CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
      CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
      CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
      CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
      CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
      CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
      CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
      CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
      CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
      CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
      CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
      CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
      CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
      CONFIG_BT_CTLR_ECDH_SUPPORT=y
      CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
      # CONFIG_BT_LL_SW_SPLIT is not set
      CONFIG_BT_CTLR_HCI=y
      # BLE Controller configuration
      CONFIG_BT_CTLR_CRYPTO=y
      CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
      # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
      # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
      # CONFIG_BT_CTLR_TX_PWR_PLUS_1 is not set
      CONFIG_BT_CTLR_TX_PWR_0=y
      # CONFIG_BT_CTLR_TX_PWR_MINUS_1 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_2 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_3 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_5 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_6 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_7 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
      # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
      CONFIG_BT_CTLR_TX_PWR_DBM=0
      CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
      # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
      # BLE Controller features
      CONFIG_BT_CTLR_LE_ENC=y
      CONFIG_BT_CTLR_ECDH=y
      CONFIG_BT_CTLR_EXT_REJ_IND=y
      CONFIG_BT_CTLR_LE_PING=y
      CONFIG_BT_CTLR_DATA_LENGTH=y
      CONFIG_BT_CTLR_PHY=y
      CONFIG_BT_CTLR_CONN_RSSI=y
      # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
      CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
      CONFIG_BT_CTLR_PRIVACY=y
      CONFIG_BT_CTLR_RL_SIZE=8
      CONFIG_BT_CTLR_EXT_SCAN_FP=y
      CONFIG_BT_CTLR_PHY_2M=y
      CONFIG_BT_CTLR_PHY_CODED=y
      CONFIG_BT_CTLR_CHAN_SEL_2=y
      # CONFIG_BT_CTLR_ADV_EXT is not set
      # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
      # CONFIG_BT_CTLR_CENTRAL_ISO is not set
      # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
      # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
      CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
      # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
      # CONFIG_BT_CTLR_VS_SCAN_REQ_RX is not set
      # CONFIG_BT_SHELL is not set
      # CONFIG_BT_EAD is not set
      # Controller Area Network (CAN) bus subsystem
      # end of Controller Area Network (CAN) bus subsystem
      # CONFIG_CONSOLE_SUBSYS is not set
      # System Monitoring Options
      # CONFIG_THREAD_ANALYZER is not set
      # end of System Monitoring Options
      # Debugging Options
      # CONFIG_DEBUG is not set
      # CONFIG_STACK_USAGE is not set
      # CONFIG_STACK_SENTINEL is not set
      CONFIG_PRINTK=y
      CONFIG_EARLY_CONSOLE=y
      # CONFIG_ASSERT is not set
      # CONFIG_FORCE_NO_ASSERT is not set
      CONFIG_ASSERT_VERBOSE=y
      # CONFIG_ASSERT_NO_FILE_INFO is not set
      # CONFIG_ASSERT_NO_COND_INFO is not set
      # CONFIG_ASSERT_NO_MSG_INFO is not set
      # CONFIG_ASSERT_TEST is not set
      # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
      # CONFIG_DEBUG_INFO is not set
      # CONFIG_DEBUG_THREAD_INFO is not set
      # CONFIG_DEBUG_COREDUMP is not set
      # end of Debugging Options
      # CONFIG_MIPI_STP_DECODER is not set
      # CONFIG_DISK_ACCESS is not set
      # CONFIG_DSP is not set
      # CONFIG_EMUL is not set
      # CONFIG_CHARACTER_FRAMEBUFFER is not set
      # File Systems
      # CONFIG_FILE_SYSTEM is not set
      # end of File Systems
      # Inter Processor Communication
      # CONFIG_RPMSG_SERVICE is not set
      CONFIG_IPC_SERVICE=y
      CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
      CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
      CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
      CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
      CONFIG_IPC_SERVICE_RPMSG=y
      CONFIG_IPC_SERVICE_STATIC_VRINGS=y
      CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
      # CONFIG_IPC_SERVICE_ICMSG is not set
      # CONFIG_IPC_SERVICE_ICMSG_ME is not set
      # end of Inter Processor Communication
      # CONFIG_JWT is not set
      # CONFIG_LLEXT is not set
      # Linkable loadable Extension Development Kit (EDK)
      CONFIG_LLEXT_EDK_NAME="llext-edk"
      # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
      # end of Linkable loadable Extension Development Kit (EDK)
      # Logging
      # CONFIG_LOG_OUTPUT is not set
      # end of Logging
      CONFIG_MEM_ATTR=y
      # CONFIG_MEM_ATTR_HEAP is not set
      # Device Management
      # Host command handler subsystem
      # CONFIG_EC_HOST_CMD is not set
      # end of Host command handler subsystem
      # CONFIG_OSDP is not set
      # end of Device Management
      # CONFIG_MODBUS is not set
      # CONFIG_MODEM_MODULES is not set
      # Networking
      CONFIG_NET_BUF=y
      # CONFIG_NET_BUF_LOG is not set
      # CONFIG_NET_BUF_POOL_USAGE is not set
      CONFIG_NET_BUF_ALIGNMENT=0
      # CONFIG_NETWORKING is not set
      # end of Networking
      # Power Management
      # end of Power Management
      # Portability
      # end of Portability
      # Random Number Generators
      # CONFIG_TEST_RANDOM_GENERATOR is not set
      CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
      CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
      # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
      CONFIG_CSPRNG_ENABLED=y
      CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
      # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
      # end of Random Number Generators
      # CONFIG_RTIO is not set
      # SD
      # CONFIG_MMC_STACK is not set
      # CONFIG_SDMMC_STACK is not set
      # CONFIG_SDIO_STACK is not set
      # end of SD
      # CONFIG_SETTINGS is not set
      # CONFIG_SHELL is not set
      # CONFIG_STATS is not set
      # Storage
      # CONFIG_STREAM_FLASH is not set
      # end of Storage
      # CONFIG_TASK_WDT is not set
      # Testing
      # CONFIG_ZTEST is not set
      # CONFIG_ZTEST_MOCKING is not set
      # CONFIG_ZTRESS is not set
      # CONFIG_TEST is not set
      CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
      # CONFIG_FORCE_COVERAGE is not set
      # CONFIG_TEST_USERSPACE is not set
      # end of Testing
      # CONFIG_TIMING_FUNCTIONS is not set
      # CONFIG_TRACING is not set
      # CONFIG_USB_DEVICE_STACK is not set
      # CONFIG_USB_DEVICE_STACK_NEXT is not set
      # CONFIG_USB_HOST_STACK is not set
      # CONFIG_USBC_STACK is not set
      # CONFIG_ZBUS is not set
      # CONFIG_MODULES is not set
      # end of Subsystems and OS Services
      CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
      CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
      # Build and Link Features
      # Linker Options
      # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
      CONFIG_LINKER_ORPHAN_SECTION_WARN=y
      # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
      CONFIG_ROM_END_OFFSET=0
      CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
      CONFIG_LD_LINKER_TEMPLATE=y
      # CONFIG_CMAKE_LINKER_GENERATOR is not set
      # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
      CONFIG_LINKER_SORT_BY_ALIGNMENT=y
      # Linker Sections
      # CONFIG_LINKER_USE_BOOT_SECTION is not set
      # CONFIG_LINKER_USE_PINNED_SECTION is not set
      CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
      CONFIG_LINKER_LAST_SECTION_ID=y
      CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
      CONFIG_LINKER_USE_RELAX=y
      # end of Linker Sections
      CONFIG_LINKER_ITERABLE_SUBALIGN=4
      CONFIG_LINKER_DEVNULL_SUPPORT=y
      # CONFIG_LINKER_DEVNULL_MEMORY is not set
      # end of Linker Options
      # Compiler Options
      # CONFIG_STD_C90 is not set
      CONFIG_STD_C99=y
      # CONFIG_STD_C11 is not set
      # CONFIG_STD_C17 is not set
      # CONFIG_STD_C23 is not set
      CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
      # CONFIG_GNU_C_EXTENSIONS is not set
      # CONFIG_CODING_GUIDELINE_CHECK is not set
      # CONFIG_COMPILER_FREESTANDING is not set
      CONFIG_SIZE_OPTIMIZATIONS=y
      # CONFIG_SPEED_OPTIMIZATIONS is not set
      # CONFIG_DEBUG_OPTIMIZATIONS is not set
      # CONFIG_NO_OPTIMIZATIONS is not set
      # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
      # CONFIG_COMPILER_SAVE_TEMPS is not set
      CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
      CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
      # CONFIG_FORTIFY_SOURCE_NONE is not set
      CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
      # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
      CONFIG_COMPILER_OPT=""
      # CONFIG_MISRA_SANE is not set
      # end of Compiler Options
      # CONFIG_ASSERT_ON_ERRORS is not set
      # CONFIG_NO_RUNTIME_CHECKS is not set
      CONFIG_RUNTIME_ERROR_CHECKS=y
      # Build Options
      CONFIG_KERNEL_BIN_NAME="zephyr"
      CONFIG_OUTPUT_STAT=y
      # CONFIG_OUTPUT_SYMBOLS is not set
      # CONFIG_OUTPUT_DISASSEMBLY is not set
      CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
      # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
      # CONFIG_BUILD_NO_GAP_FILL is not set
      # CONFIG_BUILD_OUTPUT_EXE is not set
      # CONFIG_BUILD_OUTPUT_S19 is not set
      # CONFIG_BUILD_OUTPUT_UF2 is not set
      # CONFIG_BUILD_OUTPUT_STRIPPED is not set
      # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
      # CONFIG_BUILD_ALIGN_LMA is not set
      # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
      # CONFIG_MAKEFILE_EXPORTS is not set
      # CONFIG_BUILD_OUTPUT_META is not set
      CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
      CONFIG_CHECK_INIT_PRIORITIES=y
      # CONFIG_EMIT_ALL_SYSCALLS is not set
      # end of Build Options
      CONFIG_WARN_DEPRECATED=y
      CONFIG_ENFORCE_ZEPHYR_STDINT=y
      # end of Build and Link Features
      # Boot Options
      # CONFIG_IS_BOOTLOADER is not set
      # CONFIG_BOOTLOADER_BOSSA is not set
      # end of Boot Options
  • And here is the generated .config file for app core, under C:\ncs\v2.7.0\zephyr\samples\bluetooth\hci_pwr_ctrl\build\zephyr
    CONFIG_BT_HCI_VS=y
    CONFIG_SRAM_SIZE=448
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_BOARD=4096
    # CONFIG_BT_CTLR is not set
    CONFIG_NUM_IRQS=69
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_PINCTRL=y
    CONFIG_XIP=y
    CONFIG_MAIN_STACK_SIZE=1024
    CONFIG_IDLE_STACK_SIZE=320
    # CONFIG_BT_STM32WBA is not set
    # CONFIG_BT_USER_PHY_UPDATE is not set
    # CONFIG_FPU is not set
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_TINYCRYPT=y
    CONFIG_LOG=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_CONSOLE=y
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    # Modules
    CONFIG_MBOX=y
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=y
    CONFIG_NCS_SAMPLE_HCI_IPC_CHILD_IMAGE=y
    CONFIG_BT_L2CAP_TX_MTU=23
    # Subsystems
    # Bootloader
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Bootloader
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    CONFIG_BT_RX_STACK_SIZE=1200
    # BLE Libraries
    # CONFIG_BT_DIS is not set
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_BT_DRIVERS=y
    # CONFIG_BT_CENTRAL is not set
    # CONFIG_BT_OBSERVER is not set
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    # CONFIG_BT_BAS is not set
    CONFIG_BT_HRS=y
    CONFIG_BT_HRS_DEFAULT_PERM_RW=y
    # CONFIG_BT_HRS_DEFAULT_PERM_RW_ENCRYPT is not set
    # CONFIG_BT_HRS_DEFAULT_PERM_RW_AUTHEN is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_ZEPHYR_NUS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    # CONFIG_BT_HCI_VS_EXT_DETECT is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    CONFIG_BT_RX_PRIO=8
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_HOST_CRYPTO=y
    CONFIG_BT_HOST_CRYPTO_PRNG=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    CONFIG_BT_AUTO_PHY_UPDATE=y
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    # CONFIG_BT_REMOTE_INFO is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_RESCHED_MS=1000
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    CONFIG_BT_ATT_TX_COUNT=3
    CONFIG_BT_ATT_PREPARE_COUNT=0
    # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="Dynamic test beacon"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=833
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_DF is not set
    # CONFIG_BT_CLASSIC is not set
    # DFU
    # end of DFU
    # Networking
    # nRF Cloud
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # end of Networking
    # NFC
    # end of NFC
    # Debug
    # end of Debug
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # Partition Manager
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # CONFIG_ZIGBEE is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_SUITFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_SUITFU_LOG_LEVEL=3
    # nRF Security
    # Audio Module
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=3
    # SUIT provisioning
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # Libraries
    # Binary libraries
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    # end of Libraries
    # Device Drivers
    CONFIG_HW_CC3XX=y
    # Test
    # Mocks
    # end of Mocks
    # end of Test
    # PSA RNG support
    # PSA AEAD support
    # PSA MAC support
    # PSA Hash support
    CONFIG_TFM_BOARD="C:/ncs/v2.7.0/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
    # Nordic drivers
    # CONFIG_NRF_802154_SER_HOST is not set
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_IPC_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    # CONFIG_NRFX_GPIOTE1 is not set
    # CONFIG_NRFX_I2S0 is not set
    CONFIG_NRFX_IPC=y
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SPIM4 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBREG is not set
    # CONFIG_NRFX_WDT1 is not set
    # MCUboot
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    # CONFIG_XIP_SPLIT_IMAGE is not set
    # Nordic nrfxlib
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    CONFIG_LIBMETAL=y
    CONFIG_OPENAMP=y
    CONFIG_TINYCRYPT_SHA256=y
    CONFIG_TINYCRYPT_SHA256_HMAC=y
    CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
    CONFIG_TINYCRYPT_AES_CMAC=y
    # end of Modules
    CONFIG_BOARD_TARGET="nrf5340dk/nrf5340/cpuapp"
    CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPP=y
    CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp"
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_BOARD_ENABLE_CPUNET=y
    CONFIG_DOMAIN_CPUNET_BOARD="nrf5340dk/nrf5340/cpunet"
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x4000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000
    CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340=y
    CONFIG_SOC_NRF53_CPUNET_MGMT=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF53_SYNC_RTC=y
    # CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
    CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y
    CONFIG_SYNC_RTC_LOG_LEVEL=3
    CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
    CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
    CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
    CONFIG_NRF53_SYNC_RTC_IPM_IN=8
    CONFIG_IPM_MSG_CH_8_ENABLE=y
    CONFIG_IPM_MSG_CH_8_RX=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    CONFIG_ARM_MPU=y
    # ARM Options
    CONFIG_ISA_THUMB2=y
    CONFIG_FAULT_DUMP=2
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_HAS_SWO=y
    CONFIG_ARM=y
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    # DSP Options
    # Cache Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_SCHED_DUMB=y
    CONFIG_WAITQ_DUMB=y
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_BOOT_DELAY=0
    # Atomic Operations
    # Timer API Options
    CONFIG_POLL=y
    # Security Options
    # Memory Domains
    # SMP Options
    # Device Options
    # Device Drivers
    # Bluetooth HCI Driver Options
    # CONFIG_BT_H4 is not set
    # CONFIG_BT_H5 is not set
    # CONFIG_BT_RPMSG is not set
    CONFIG_BT_HCI_IPC=y
    # CONFIG_BT_SPI is not set
    # CONFIG_BT_STM32_IPM is not set
    # CONFIG_BT_ESP32 is not set
    # CONFIG_BT_B91 is not set
    # CONFIG_BT_PSOC6_BLESS is not set
    # CONFIG_BT_DA1469X is not set
    # CONFIG_BT_NO_DRIVER is not set
    # CONFIG_BT_AMBIQ_HCI is not set
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=256
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    CONFIG_GPIO_NRFX=y
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MBOX_LOG_LEVEL_OFF is not set
    # CONFIG_MBOX_LOG_LEVEL_ERR is not set
    # CONFIG_MBOX_LOG_LEVEL_WRN is not set
    # CONFIG_MBOX_LOG_LEVEL_INF is not set
    # CONFIG_MBOX_LOG_LEVEL_DBG is not set
    CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
    CONFIG_MBOX_LOG_LEVEL=3
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    # Capabilities
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # Serial Drivers
    CONFIG_UART_NRFX=y
    # Timer drivers
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # C Library
    CONFIG_PICOLIBC=y
    # end of C Library
    # Deprecated
    # end of Deprecated
    # Memory Blocks
    CONFIG_MPSC_PBUF=y
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
    CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
    CONFIG_POSIX_ENV_LOG_LEVEL=3
    # sem_t support
    # Signal support
    # Sysconf support
    # Utility Library
    CONFIG_NOTIFY=y
    CONFIG_ONOFF=y
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_HCI_RAW is not set
    CONFIG_BT_CONN_TX=y
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # CONFIG_BT_CTLR_DEBUG_PINS_CPUAPP is not set
    CONFIG_BT_LOG=y
    # Bluetooth logging
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    CONFIG_BT_RPA_LOG_LEVEL=3
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    # Audio
    CONFIG_BT_AICS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AICS_LOG_LEVEL=3
    # CONFIG_BT_AICS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_STREAM_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_STREAM_LOG_LEVEL=3
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BASE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_BASE_LOG_LEVEL=3
    # CONFIG_BT_BAP_BASE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BASE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BASE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BASE_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BASE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BASE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL=3
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ASCS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ASCS_LOG_LEVEL=3
    # CONFIG_BT_ASCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL=3
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL=3
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL=3
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL=3
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL=3
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_ISO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_ISO_LOG_LEVEL=3
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL=3
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL=3
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_COMMANDER_LOG_LEVEL=3
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_COMMON_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_COMMON_LOG_LEVEL=3
    # CONFIG_BT_CAP_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_COMMON_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_COMMON_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_STREAM_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_STREAM_LOG_LEVEL=3
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL=3
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL=3
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL=3
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HAS_LOG_LEVEL=3
    # CONFIG_BT_HAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MCS_LOG_LEVEL=3
    # CONFIG_BT_MCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCC_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MCC_LOG_LEVEL=3
    # CONFIG_BT_MCC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCC_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCTL_LOG_LEVEL_INHERIT=y
    CONFIG_MCTL_LOG_LEVEL=3
    # CONFIG_MCTL_LOG_LEVEL_OFF is not set
    # CONFIG_MCTL_LOG_LEVEL_ERR is not set
    # CONFIG_MCTL_LOG_LEVEL_WRN is not set
    # CONFIG_MCTL_LOG_LEVEL_INF is not set
    # CONFIG_MCTL_LOG_LEVEL_DBG is not set
    # CONFIG_MCTL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL=3
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL=3
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MPL_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MPL_LOG_LEVEL=3
    # CONFIG_BT_MPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_PACS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_PACS_LOG_LEVEL=3
    # CONFIG_BT_PACS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_PACS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_PACS_LOG_LEVEL_INF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_TBS_LOG_LEVEL=3
    # CONFIG_BT_TBS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INHERIT=y
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL=3
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INHERIT=y
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL=3
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_VOCS_LOG_LEVEL=3
    # CONFIG_BT_VOCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_PBP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_PBP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_PBP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_PBP_LOG_LEVEL_INF is not set
    # CONFIG_BT_PBP_LOG_LEVEL_DBG is not set
    CONFIG_BT_PBP_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_PBP_LOG_LEVEL=3
    # end of Audio
    # Others
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ATT_LOG_LEVEL=3
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_GATT_LOG_LEVEL=3
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_EAD_LOG_LEVEL_INHERIT=y
    CONFIG_BT_EAD_LOG_LEVEL=3
    # CONFIG_BT_EAD_LOG_LEVEL_OFF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_ERR is not set
    # CONFIG_BT_EAD_LOG_LEVEL_WRN is not set
    # CONFIG_BT_EAD_LOG_LEVEL_INF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DBG is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_DF_LOG_LEVEL_INHERIT=y
    CONFIG_BT_DF_LOG_LEVEL=3
    # CONFIG_BT_DF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_DF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_DF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_DF_LOG_LEVEL_INF is not set
    # CONFIG_BT_DF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SETTINGS_LOG_LEVEL=3
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_CORE_LOG_LEVEL=3
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CONN_LOG_LEVEL=3
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ISO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ISO_LOG_LEVEL=3
    # CONFIG_BT_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_KEYS_LOG_LEVEL=3
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SMP_LOG_LEVEL=3
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL=3
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DEFAULT is not set
    # end of Others
    # BR/EDR
    CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT=y
    CONFIG_BT_RFCOMM_LOG_LEVEL=3
    # CONFIG_BT_RFCOMM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_INF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HFP_HF_LOG_LEVEL=3
    # CONFIG_BT_HFP_HF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_INF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HFP_AG_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HFP_AG_LOG_LEVEL=3
    # CONFIG_BT_HFP_AG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HFP_AG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HFP_AG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HFP_AG_LOG_LEVEL_INF is not set
    # CONFIG_BT_HFP_AG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HFP_AG_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AVDTP_LOG_LEVEL=3
    # CONFIG_BT_AVDTP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_INF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_A2DP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_A2DP_LOG_LEVEL=3
    # CONFIG_BT_A2DP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_INF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SDP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SDP_LOG_LEVEL=3
    # CONFIG_BT_SDP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SDP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SDP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DEFAULT is not set
    # end of BR/EDR
    # Mesh
    CONFIG_BT_MESH_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_LOG_LEVEL=3
    # CONFIG_BT_MESH_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_NET_LOG_LEVEL=3
    # CONFIG_BT_MESH_NET_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_RPL_LOG_LEVEL=3
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_TRANS_LOG_LEVEL=3
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_BEACON_LOG_LEVEL=3
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL=3
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_KEYS_LOG_LEVEL=3
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROV_LOG_LEVEL=3
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL=3
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL=3
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL=3
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_MODEL_LOG_LEVEL=3
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_DFU_LOG_LEVEL=3
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_ADV_LOG_LEVEL=3
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL=3
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL=3
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROXY_LOG_LEVEL=3
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL=3
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_CDB_LOG_LEVEL=3
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_CFG_LOG_LEVEL=3
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DEFAULT is not set
    # end of Mesh
    # Services
    # CONFIG_BT_BAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_BAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_BAS_LOG_LEVEL=3
    # CONFIG_BT_HRS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HRS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HRS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_DBG is not set
    CONFIG_BT_HRS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_HRS_LOG_LEVEL=3
    # CONFIG_BT_TPS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TPS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TPS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_DBG is not set
    CONFIG_BT_TPS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_TPS_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_IAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_IAS_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_OTS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_DBG is not set
    CONFIG_BT_OTS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_OTS_LOG_LEVEL=3
    # end of Services
    # end of Bluetooth logging
    # Debugging Options
    CONFIG_PRINTK=y
    # File Systems
    # CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
    CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_IPC_SERVICE_LOG_LEVEL=3
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_SWO is not set
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
    CONFIG_LOG_BACKEND_UART_AUTOSTART=y
    CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # end of Networking
    # Power Management
    # Portability
    # SD
    # end of SD
    # Storage
    # end of Storage
    # Testing
    # end of Testing
    # Linker Options
    # Linker Sections
    # Compiler Options
    CONFIG_STD_C99=y
    # Build Options
    # Boot Options
  • In oder to simplify the problem, I tried the NCS sample code under C:\ncs\v2.7.0\zephyr\samples\bluetooth\hci_pwr_ctrl on 5340DK, because in this sample, application code is also sending HCI cmd to net core to get/set RF power
    Did you make any changes to the sample before testing it?
    Sigurd Hellesvik
  • No, I did not change anything, it is the AS-IS sample code
  • I realize  "# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set" in this .config file, which is generated from C:\ncs\v2.7.0\zephyr\samples\bluetooth\hci_ipc\prj.conf. Should this config be set y?
