W: conn failed to establish. RF noise? (reopened ticket)
I was talking to Susheel Nuguru about the multiconnection problem that i had in my other ticket about multiconnections for Channel Sounding, which had the same title as this one.
I verified his answer and the ticket was closed it said, but my problem was actually not solved yet. I need this problem to be fixed pretty soon and i was worried that he maybe could not see my reply on his verified answer...
Here is my problem again:
somethimes i get this Warning when connecting with devices without getting any errors (which stops my code) and this happens at this moment in my main code:
I followed the suggestion to give a semaphore also when a connection fails (in connected_cb() ) to get in this SKIP part after 4 seconds, but this still doesn't make my code to skip this device and go on to the next one...
Nick De Leenheer
#include <zephyr/kernel.h>
#include <zephyr/types.h>
#include <zephyr/bluetooth/cs.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/conn.h>
#include <bluetooth/scan.h>
#include <bluetooth/services/ras.h>
#include <bluetooth/gatt_dm.h>
#include "distance_estimation.h"
#include <dk_buttons_and_leds.h>
LOG_MODULE_DECLARE(app_main, LOG_LEVEL_INF);
#define CON_STATUS_LED DK_LED1
#define CS_CONFIG_ID	       0
#define NUM_MODE_0_STEPS       3
#define PROCEDURE_COUNTER_NONE (-1)
#define LOCAL_PROCEDURE_MEM        \
	((BT_RAS_MAX_STEPS_PER_PROCEDURE * sizeof(struct bt_le_cs_subevent_step)) +                \
	(BT_RAS_MAX_STEPS_PER_PROCEDURE * BT_RAS_MAX_STEP_DATA_LEN))
static K_SEM_DEFINE(sem_remote_capabilities_obtained, 0, 1);
static K_SEM_DEFINE(sem_config_created, 0, 1);
static K_SEM_DEFINE(sem_cs_security_enabled, 0, 1);
static K_SEM_DEFINE(sem_procedure_done, 0, 1);
static K_SEM_DEFINE(sem_connected, 0, 1);
static K_SEM_DEFINE(sem_rd_ready, 0, 1);
static K_SEM_DEFINE(sem_discovery_done, 0, 1);
static K_SEM_DEFINE(sem_mtu_exchange_done, 0, 1);
static K_SEM_DEFINE(sem_rd_complete, 0, 1);
static K_SEM_DEFINE(sem_security, 0, 1);
static K_SEM_DEFINE(sem_disconnected, 0, 1);
/* For scanning & connecting with multiple devices */
#define MAX_DEVICES 3
static bt_addr_le_t addresses[MAX_DEVICES];
static int num_found = 0;
static bool scanning_for_initial_devices = true;
static bool connection_in_progress = false;
static struct bt_conn *connection = NULL;
static struct bt_conn *connections[MAX_DEVICES];
/* For parsing the name of devices */
#define NAME_LEN 30
char reflector_names[MAX_DEVICES][NAME_LEN];
char reflector_name[NAME_LEN] = "(onbekend)";
/* For the ranging process */
#define RANGING_ROUNDS 1
static uint8_t n_ap;
NET_BUF_SIMPLE_DEFINE_STATIC(latest_local_steps, LOCAL_PROCEDURE_MEM);
NET_BUF_SIMPLE_DEFINE_STATIC(latest_peer_steps, BT_RAS_PROCEDURE_MEM);
static int32_t most_recent_peer_ranging_counter = PROCEDURE_COUNTER_NONE;
static int32_t most_recent_local_ranging_counter = PROCEDURE_COUNTER_NONE;
static int32_t dropped_ranging_counter = PROCEDURE_COUNTER_NONE;
static bool distance_estimation_in_progress;
static void subevent_result_cb(struct bt_conn *conn, struct bt_conn_le_cs_subevent_result *result)
	if (distance_estimation_in_progress) {
		dropped_ranging_counter = result->header.procedure_counter;
		return;
	if (result->header.subevent_done_status == BT_CONN_LE_CS_SUBEVENT_ABORTED) {
		net_buf_simple_reset(&latest_local_steps);
		return;
	if (dropped_ranging_counter == result->header.procedure_counter) {
		return;
	if (result->step_data_buf) {
		if (result->step_data_buf->len <= net_buf_simple_tailroom(&latest_local_steps)) {
			uint16_t len = result->step_data_buf->len;
			uint8_t *step_data = net_buf_simple_pull_mem(result->step_data_buf, len);
			net_buf_simple_add_mem(&latest_local_steps, step_data, len);
		} else {
			return;
	n_ap = result->header.num_antenna_paths;
	if (result->header.procedure_done_status == BT_CONN_LE_CS_PROCEDURE_COMPLETE) {
		most_recent_local_ranging_counter = result->header.procedure_counter;
		distance_estimation_in_progress = true;
		k_sem_give(&sem_procedure_done);
	} else if (result->header.procedure_done_status == BT_CONN_LE_CS_PROCEDURE_ABORTED) {
static void ranging_data_get_complete_cb(struct bt_conn *conn, uint16_t ranging_counter, int err)
	ARG_UNUSED(conn);
	if (err) {
		return;
	k_sem_give(&sem_rd_complete);
static void ranging_data_ready_cb(struct bt_conn *conn, uint16_t ranging_counter)
	most_recent_peer_ranging_counter = ranging_counter;
	k_sem_give(&sem_rd_ready);
static void ranging_data_overwritten_cb(struct bt_conn *conn, uint16_t ranging_counter)
static void mtu_exchange_cb(struct bt_conn *conn, uint8_t err,
				struct bt_gatt_exchange_params *params)
	if (err) {
		return;
	k_sem_give(&sem_mtu_exchange_done);
static void discovery_completed_cb(struct bt_gatt_dm *dm, void *context)
	int err;
	struct bt_conn *conn = bt_gatt_dm_conn_get(dm);
	bt_gatt_dm_data_print(dm);
	err = bt_ras_rreq_alloc_and_assign_handles(dm, conn);
	if (err) {
	err = bt_gatt_dm_data_release(dm);
	if (err) {
	k_sem_give(&sem_discovery_done);
static void discovery_service_not_found_cb(struct bt_conn *conn, void *context)
	bt_conn_disconnect(connection, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
static void discovery_error_found_cb(struct bt_conn *conn, int err, void *context)
static struct bt_gatt_dm_cb discovery_cb = {
	.completed = discovery_completed_cb,
	.service_not_found = discovery_service_not_found_cb,
	.error_found = discovery_error_found_cb,
static void security_changed(struct bt_conn *conn, bt_security_t level, enum bt_security_err err)
	if (err) {
		return;
	k_sem_give(&sem_security);
static bool le_param_req(struct bt_conn *conn, struct bt_le_conn_param *param)
	return false;
static void connected_cb(struct bt_conn *conn, uint8_t err)
    if (err) {
        LOG_ERR("Connection failed (err 0x%02x)", err);
        bt_conn_unref(conn);
		k_sem_give(&sem_connected);	// NEEDED to get to the error instead of "W: conn failed to establish. RF noise?"
        return;
    // When not in the scanning process we give a semaphore for being detected
    if (!scanning_for_initial_devices) {
        for (int i = 0; i < MAX_DEVICES; i++) {
            if (connections[i] == NULL) {
                connections[i] = bt_conn_ref(conn);
        dk_set_led_on(CON_STATUS_LED);
    // When still in the scanning process we disconnect
    if (scanning_for_initial_devices) {
        k_sleep(K_MSEC(200));
        bt_conn_disconnect(conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
static void disconnected_cb(struct bt_conn *conn, uint8_t reason)
    connection = NULL;
    dk_set_led_off(CON_STATUS_LED);
    // Handle disconnection during initial device scan
        k_sem_give(&sem_disconnected);
		// When more devices need to get detected we continue scanning
        if (num_found < MAX_DEVICES) {
            bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
		// When all devices has been found we stop scanning
        } else {
            scanning_for_initial_devices = false;
	// Handle disconnection during ranging phases
    } else {
        // LOG_INF("Disconnection occurred during configuration or ranging phase");
static void remote_capabilities_cb(struct bt_conn *conn, struct bt_conn_le_cs_capabilities *params)
	ARG_UNUSED(params);
	k_sem_give(&sem_remote_capabilities_obtained);
static void config_created_cb(struct bt_conn *conn, struct bt_conn_le_cs_config *config)
	k_sem_give(&sem_config_created);
static void security_enabled_cb(struct bt_conn *conn)
	k_sem_give(&sem_cs_security_enabled);
static void procedure_enabled_cb(struct bt_conn *conn,
				struct bt_conn_le_cs_procedure_enable_complete *params)
static bool ad_parse_cb(struct bt_data *data, void *user_data)
    char *name = user_data;
    if (data->type == BT_DATA_NAME_COMPLETE || data->type == BT_DATA_NAME_SHORTENED) {
        size_t len = MIN(data->data_len, NAME_LEN - 1);
        memcpy(name, data->data, len);
        name[len] = '\0';
        return false;
    return true;
static void scan_filter_match(struct bt_scan_device_info *device_info,
                              struct bt_scan_filter_match *filter_match, bool connectable)
	// Not scanning for devices OR already connected to a device
    if (!scanning_for_initial_devices || connection_in_progress) {
        return;
    // Device has already been detected
    for (int i = 0; i < num_found; i++) {
        if (!bt_addr_le_cmp(&addresses[i], device_info->recv_info->addr)) {
            return;
	// End scanning when ALL devices detected
    if (num_found >= MAX_DEVICES) {
        return;
    // Retreiving data from the scanned device
    struct net_buf_simple ad_copy = *device_info->adv_data;
    snprintf(reflector_names[num_found], NAME_LEN, "(onbekend)");
    bt_data_parse(&ad_copy, ad_parse_cb, reflector_names[num_found]);
    bt_addr_le_copy(&addresses[num_found], device_info->recv_info->addr);
    bt_scan_stop();
    k_msleep(50);
	// Setup a quick connection with the device
    struct bt_conn *conn = NULL;
    const struct bt_conn_le_create_param *create_param = BT_CONN_LE_CREATE_PARAM(BT_CONN_LE_OPT_NONE, 0x0060, 0x0030);
    const struct bt_le_conn_param *conn_param = BT_LE_CONN_PARAM_DEFAULT;
	connection_in_progress = true;
    int err = bt_conn_le_create(&addresses[num_found], create_param, conn_param, &conn);
    if (err) {
        return;
	// LOG the information about the device
    char addr_str[BT_ADDR_LE_STR_LEN];
    bt_addr_le_to_str(&addresses[num_found], addr_str, sizeof(addr_str));
    LOG_INF("Device %d/%d verbonden: \"%s\" (%s)", num_found + 1, MAX_DEVICES, reflector_names[num_found], addr_str);
    num_found++;
static void scan_connecting_error(struct bt_scan_device_info *device_info)
	int err;
	err = bt_scan_start(BT_SCAN_TYPE_SCAN_PASSIVE);
	if (err) {
		return;
static void scan_connecting(struct bt_scan_device_info *device_info, struct bt_conn *conn)
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL, scan_connecting_error, scan_connecting);
static int scan_init(void)
	int err;
	struct bt_scan_init_param param = {
		.scan_param = NULL,
		.conn_param = BT_LE_CONN_PARAM_DEFAULT,
		.connect_if_match = 0};
	bt_scan_init(&param);
	bt_scan_cb_register(&scan_cb);
	// /** Filter for names. */
	// BT_SCAN_FILTER_TYPE_NAME,
	// /** Filter for short names. */
	// BT_SCAN_FILTER_TYPE_SHORT_NAME,
	// /** Filter for addresses. */
	// BT_SCAN_FILTER_TYPE_ADDR,
	// /** Filter for UUIDs. */
	// BT_SCAN_FILTER_TYPE_UUID,
	// /** Filter for appearances. */
	// BT_SCAN_FILTER_TYPE_APPEARANCE,
	// /** Filter for manufacturer data. */
	// BT_SCAN_FILTER_TYPE_MANUFACTURER_DATA,
	// err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME, TARGET_NAME);
	// if (err) {
	// 	return err;
	err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_RANGING_SERVICE);
	if (err) {
		return err;
	err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);	//false: 1 match required | true: ALL matches required
	if (err) {
		return err;
	return 0;
/* This Zephyr macro registers callbacks which act when certain steps are made in the system */
BT_CONN_CB_DEFINE(conn_cb) = {
	.connected = connected_cb,			// When Zephyr makes a connection between devices it calls this cb-function
	.disconnected = disconnected_cb,	// When Zephyr makes a disconnection between devices it calls this function
	.le_param_req = le_param_req,
	.security_changed = security_changed,
	.le_cs_remote_capabilities_available = remote_capabilities_cb,
	.le_cs_config_created = config_created_cb,
	.le_cs_security_enabled = security_enabled_cb,
	.le_cs_procedure_enabled = procedure_enabled_cb,
	.le_cs_subevent_data_available = subevent_result_cb,
int main(void){
	int err;
	dk_leds_init();
	err = bt_enable(NULL);
	if (err) {
		return 0;
	/* Start Scanning for Multiple Devices */
	err = scan_init();
	if (err) {
		return 0;
	if (err) {
		return 0;
		k_sem_take(&sem_disconnected, K_FOREVER);
	LOG_INF("All devices detected => stop scanning");
	/* Reconnect one by one with previously detected devices */
	while (true){
			const bt_addr_le_t *peer_addr = &addresses[i];
			bt_addr_le_to_str(peer_addr, addr_str, sizeof(addr_str));
			const char *reflector_name = reflector_names[i];
			int device_nr = i+1;
			if (connections[i]) {
				bt_conn_disconnect(connections[i], BT_HCI_ERR_REMOTE_USER_TERM_CONN);
				bt_conn_unref(connections[i]);
				connections[i] = NULL;
			err = bt_conn_le_create(peer_addr, create_param, conn_param, &connections[i]);
			if (err) {
				LOG_ERR("Kon niet verbinden met %s (%s), foutcode: %d", reflector_name, addr_str, err);
				continue;
			if (k_sem_take(&sem_connected, K_SECONDS(4)) != 0) {
				LOG_INF("W: Connection to device %d timed out. Skipping...", i);
				continue; // Move on to the next device
			/* Add a small delay to allow the connection to stabilize */
			// Security
			err = bt_conn_set_security(connections[i], BT_SECURITY_L2);
			if (err) {
				LOG_ERR("Security failed for %s", reflector_name);
				continue;
			k_sem_take(&sem_security, K_FOREVER);
			// MTU Exchange
			static struct bt_gatt_exchange_params mtu_exchange_params = { .func = mtu_exchange_cb };
			err = bt_gatt_exchange_mtu(connections[i], &mtu_exchange_params);
			if (err) {
				LOG_ERR("MTU exchange failed for %s", reflector_name);
				continue;
			k_sem_take(&sem_mtu_exchange_done, K_FOREVER);
			// GATT Discovery
			err = bt_gatt_dm_start(connections[i], BT_UUID_RANGING_SERVICE, &discovery_cb, NULL);
			if (err) {
				LOG_ERR("GATT discovery failed for %s", reflector_name);
				continue;
			k_sem_take(&sem_discovery_done, K_FOREVER);
			// Default settings
			const struct bt_le_cs_set_default_settings_param default_settings = {
				.enable_initiator_role = true,
				.enable_reflector_role = false,
				.cs_sync_antenna_selection = BT_LE_CS_ANTENNA_SELECTION_OPT_REPETITIVE,
				.max_tx_power = BT_HCI_OP_LE_CS_MAX_MAX_TX_POWER,
			err = bt_le_cs_set_default_settings(connections[i], &default_settings);
			if (err) {
				LOG_ERR("Default settings failed for %s", reflector_name);
				continue;
			// Subscriptions
			err  = bt_ras_rreq_rd_overwritten_subscribe(connections[i], ranging_data_overwritten_cb);
			err |= bt_ras_rreq_rd_ready_subscribe(connections[i], ranging_data_ready_cb);
			err |= bt_ras_rreq_on_demand_rd_subscribe(connections[i]);
			err |= bt_ras_rreq_cp_subscribe(connections[i]);
			if (err) {
				LOG_ERR("Subscriptions failed for %s", reflector_name);
				continue;
			// Capabilities
			err = bt_le_cs_read_remote_supported_capabilities(connections[i]);
			if (err) {
				LOG_ERR("Capabilities read failed for %s", reflector_name);
				continue;
			k_sem_take(&sem_remote_capabilities_obtained, K_FOREVER);
			// CS Config
			struct bt_le_cs_create_config_params config_params = {
				.id = CS_CONFIG_ID,
				.main_mode_type = BT_CONN_LE_CS_MAIN_MODE_2,
				.sub_mode_type = BT_CONN_LE_CS_SUB_MODE_UNUSED,
				.min_main_mode_steps = 2,
				.max_main_mode_steps = 5,
				.main_mode_repetition = 0,
				.mode_0_steps = NUM_MODE_0_STEPS,
				.role = BT_CONN_LE_CS_ROLE_INITIATOR,
				.rtt_type = BT_CONN_LE_CS_RTT_TYPE_AA_ONLY,
				.cs_sync_phy = BT_CONN_LE_CS_SYNC_1M_PHY,
				.channel_map_repetition = 1,
				.channel_selection_type = BT_CONN_LE_CS_CHSEL_TYPE_3B,
				.ch3c_shape = BT_CONN_LE_CS_CH3C_SHAPE_HAT,
				.ch3c_jump = 2,
			bt_le_cs_set_valid_chmap_bits(config_params.channel_map);
			err = bt_le_cs_create_config(connections[i], &config_params, BT_LE_CS_CREATE_CONFIG_CONTEXT_LOCAL_AND_REMOTE);
			if (err) {
				LOG_ERR("Config creation failed for %s", reflector_name);
				continue;
			k_sem_take(&sem_config_created, K_FOREVER);
			// Enable CS security
			err = bt_le_cs_security_enable(connections[i]);
			if (err) {
				LOG_ERR("CS security enable failed for %s", reflector_name);
				continue;
			k_sem_take(&sem_cs_security_enabled, K_FOREVER);
			// Procedure params
			const struct bt_le_cs_set_procedure_parameters_param procedure_params = {
				.config_id = CS_CONFIG_ID,
				.max_procedure_len = 1000,
				.min_procedure_interval = 10,
				.max_procedure_interval = 10,
				.max_procedure_count = 0,
				.min_subevent_len = 60000,
				.max_subevent_len = 60000,
				.tone_antenna_config_selection = BT_LE_CS_TONE_ANTENNA_CONFIGURATION_INDEX_ONE,
				.phy = BT_LE_CS_PROCEDURE_PHY_1M,
				.tx_power_delta = 0x80,
				.preferred_peer_antenna = BT_LE_CS_PROCEDURE_PREFERRED_PEER_ANTENNA_1,
				.snr_control_initiator = BT_LE_CS_INITIATOR_SNR_CONTROL_NOT_USED,
				.snr_control_reflector = BT_LE_CS_REFLECTOR_SNR_CONTROL_NOT_USED,
			err = bt_le_cs_set_procedure_parameters(connections[i], &procedure_params);
			if (err) {
				LOG_ERR("Procedure params failed for %s", reflector_name);
				continue;
			// Enable procedure
			struct bt_le_cs_procedure_enable_param enable_params = {
				.enable = 1,
			err = bt_le_cs_procedure_enable(connections[i], &enable_params);
			if (err) {
				LOG_ERR("Procedure enable failed for %s", reflector_name);
				continue;
			LOG_INF("Device %d: %s", device_nr, reflector_name);
			// Ranging process
			for (int round = 0; round < RANGING_ROUNDS; round++) {
				k_sem_take(&sem_procedure_done, K_FOREVER);
				err = k_sem_take(&sem_rd_ready, K_SECONDS(1));
				if (err) {
					LOG_WRN("Timeout waiting for rd_ready from %s", reflector_name);
					continue;
				if (most_recent_peer_ranging_counter != most_recent_local_ranging_counter) {
					LOG_WRN("Mismatched counters on %s", reflector_name);
					continue;
				err = bt_ras_rreq_cp_get_ranging_data(connections[i], &latest_peer_steps,
					most_recent_peer_ranging_counter, ranging_data_get_complete_cb);
				if (err) {
					LOG_ERR("Failed to get ranging data from %s (err %d)", reflector_name, err);
					continue;
				err = k_sem_take(&sem_rd_complete, K_SECONDS(5));
				if (err) {
					LOG_ERR("Timeout waiting for rd_complete from %s", reflector_name);
					continue;
				estimate_distance(&latest_local_steps, &latest_peer_steps, n_ap,
					BT_CONN_LE_CS_ROLE_INITIATOR, reflector_name);
				net_buf_simple_reset(&latest_peer_steps);
				distance_estimation_in_progress = false;
  • Hi
    So this message should only occur when your device disconnects, so there is something going wrong before you see this "failed to establish. RF noise?" message. I see that the ranging is quite a bit larger just before the disconnect. Could this disconnect be due to the devices being too far away from each other? At what distance between the devices do you see this disconnect exactly? Did it work for a while since you verified the answer before seeing this error again?
    Simon
  • Well, this error occurs when reconnecting with a new device, so I don't think it has anything to do with the distance between them. Sometimes it can take a long time before he gives me this message, sometimes it happens pretty quick...
    So i shard my whole code, and here is where it happens:
    I thought i had found something... after i received my ranging data, i disconnect... But the time to disconnect is still longer then i expected and the loop is already trying to connect to the next device...
    But this has no influence on my problem where i connect but then the connection disconnects from its own, without giving an error. So i should find a solution in the disconnected_cb, where i can define: go to next device...
    I will think of a solution
    I think i can just solve it via this reason code. If there is a disconnection with this reason, i give a semaphore which then takes this semaphore in the main to go the the next device? Or is there another solution?
  • Hi Simon,
    So I got something, but now i get these assertion fails. Do you know why this can happen and what causes these?
    as you can see i solved the "nrf Noise disconnect" problem i think by doing this:
    wait, while typing this, i think the assertion fail is because the connection was gotten corrupt, so maybe i still need to unref this properly before trying to reconnect
    Kind regards
  • This assertion fail, still happens. So if you know the cause of this, it would help me a lot.
    Thank you
