Translating previously working code to NCS v2.2.0
I'm working on a project with the AD5940, and it looks like this case did the job.
 nrf52832+SPI+AD5940 cannot get ad5940id
However, I am using NCS v2.2.0 and not nRF5 v17.1 - so code translation is required.
My current code is as follows:
Overlay:
    gpio_custom {
        compatible = "gpio-keys";
        gpiocu0: gpiocu0 {
            label = "GPIO_D2";
            gpios = <&gpio1 4 0>;/* D2 */
        gpiocu1: gpiocu1 {
            label = "GPIO_D5";
            gpios = <&gpio1 7 0>;/* D5 */
        gpiocu2: gpiocu2 {
            label = "GPIO_D6";
            gpios = <&gpio1 8 0>;/* D6 */
        ad5940reset: ad5940reset {
            label = "AD5940_RESET";
            gpios = <&gpio1 12 0>;/* D10 */
    aliases {
        gpiod2 = &gpiocu0;
        gpiod5 = &gpiocu1;
        gpiod6 = &gpiocu2;
        reset5940 = &ad5940reset;
&arduino_spi {
    status = "okay";
    ad5940:ad5940@0{
        compatible = "adi,adxl345";
        // compatible = "adi,adxl372";
        reg = <0>;
        spi-max-frequency = <DT_FREQ_M(4)>;
        friendly-name = "ad5940";
        // int1-gpios = <&gpio1 8 0>;
nRF adjustment(nRF_MCU_Port.c):
#include "ad5940.h"
#include "nRF_MCU_Port.h"
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#include <inttypes.h>
#include <dk_buttons_and_leds.h>
LOG_MODULE_REGISTER(BIA_AD5940);
volatile static uint32_t ucInterrupted = 0; /* Flag to indicate interrupt occurred */
#define AD5940_SPI DT_NODELABEL(ad5940)
static const struct spi_dt_spec dev_spi = SPI_DT_SPEC_GET(AD5940_SPI, SPI_WORD_SET(8) | SPI_MODE_GET(0), 0);
/* GPIO Configuration*/
#define D6 DT_ALIAS(gpiod6)
#if !DT_NODE_HAS_STATUS(D6, okay)
#error "Unsupported board: gpiod6 devicetree alias is not defined"
/*For the XXRst functions*/
#define R5940 DT_ALIAS(reset5940)
#if !DT_NODE_HAS_STATUS(R5940, okay)
#error "Unsupported board: reset_5940 devicetree alias is not defined"
uint8_t selector = 0;
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(D6, gpios, {0});
/*AD5940 Reset Pin*/
static const struct gpio_dt_spec reset_dev = GPIO_DT_SPEC_GET_OR(R5940, gpios, {0});
/*Interrupt Special settings*/
static struct gpio_callback button_cb_data;
bool AD5940_SPI_SETUP(void)
    if (!device_is_ready(dev_spi.bus))
        // LOG_ERR("Couldn't find %s\n", dev_spi.bus->name);
        printk("Couldn't find %s\n", dev_spi.bus->name);
        return false;
        // LOG_WRN("SPI Initialized\n\r");
        bool success = (AD5940_ReadReg(REG_AFECON_ADIID) == AD5940_ADIID) ? true : false;
        if(success)
        printk("SPI Initialized\n\r");
        // printk("SPI Initialization failed\n\r");
        return success;
void Ext_Int0_Handler(const struct device *dev, struct gpio_callback *cb,
                      uint32_t pins)
    //    /* Clear interrupt flag */
    ucInterrupted = 1;
    // LOG_INF("Ext_Int0_Handler\n\r");
    // todo: ADD BLE and EMG interrupt handling here - or not - depends on the application
    /* This example just set the flag and deal with interrupt in AD5940Main function. It's your choice to choose how to process interrupt. */
//GPIO Free "interrupt"
void set_interrupt(void)
    ucInterrupted = 1;
void AD5940_INT_SETUP(void)
    int ret;
    if (!device_is_ready(button.port))
        printk("Error: button device %s is not ready\n",
               button.port->name);
        return;
    ret = gpio_pin_configure_dt(&button, GPIO_INPUT);
    if (ret != 0)
        printk("Error %d: failed to configure %s pin %d\n",
               ret, button.port->name, button.pin);
        return;
    ret = gpio_pin_interrupt_configure_dt(&button,
                                          GPIO_INT_EDGE_TO_ACTIVE);
    if (ret != 0)
        printk("Error %d: failed to configure interrupt on %s pin %d\n",
        return;
    gpio_init_callback(&button_cb_data, Ext_Int0_Handler, BIT(button.pin));
    gpio_add_callback(button.port, &button_cb_data);
    printk("Set up button at %s pin %d\n", button.port->name, button.pin);
    // LOG_INF("Set up button at %s pin %d\n", button.port->name, button.pin);
// void AD5940_GUI_SETUP(void)
//     if (!device_is_ready(dev_led0.port->name))
//         // LOG_ERR("Couldn't find %s\n", dev_led0.port->name);
//         printk("Couldn't find %s\n", dev_led0.port->name);
//         return;
//     else
//         // LOG_WRN("GPIO Initialized\n\r");
//         printk("GPIO Initialized\n\r");
//         gpio_pin_configure_dt(&dev_led0, GPIO_OUTPUT_INIT_LOW);
void AD5940_RESET_SETUP(void)
    if (!device_is_ready(reset_dev.port))
        // LOG_ERR("Couldn't find %s\n", reset_dev.port->name);
        printk("Couldn't find %s\n", reset_dev.port->name);
        return;
        gpio_pin_configure_dt(&reset_dev, GPIO_OUTPUT);
void AD5940_ReadWriteNBytes(unsigned char *pSendBuffer, unsigned char *pRecvBuff, unsigned long length)
    const struct spi_buf tx_buf = {
        .buf = pSendBuffer,
        .len = length};
    const struct spi_buf_set tx = {
        .buffers = &tx_buf,
        .count = 1};
    const struct spi_buf rx_buf = {
        .buf = pRecvBuff,
        .len = length};
    const struct spi_buf_set rx = {
        .buffers = &rx_buf,
        .count = 1};
    if (spi_transceive_dt(&dev_spi, &tx, &rx))
        // LOG_ERR("SPI transceive failed\n");
        printk("SPI transceive failed\n");
        return;
void AD5940_CsClr(void)
    //   Do nothing - built in inside SPI API
void AD5940_CsSet(void)
void AD5940_RstSet(void)
    // Check it - maybe it has special flag
    if (gpio_pin_get_dt(&reset_dev) == 0)
        // LOG_INF("Reset pin set\n");
        printk("nRF_MCU_Port: Reset pin set\n");
        gpio_pin_set_dt(&reset_dev, 1);
void AD5940_RstClr(void)
    if (gpio_pin_get_dt(&reset_dev) == 1)
        // LOG_INF("nRF_MCU_Port: Reset pin clear\n");
        printk("nRF_MCU_Port: Reset pin clear\n");
        gpio_pin_set_dt(&reset_dev, 0);
void AD5940_DATA_GUI(void)
    // gpio_pin_toggle_dt(&dev_led0);
void AD5940_Delay10us(uint32_t time)
    k_usleep(time * 10);
uint32_t AD5940_GetMCUIntFlag(void)
    return ucInterrupted;
uint32_t AD5940_ClrMCUIntFlag(void)
    ucInterrupted = 0;
    return 1;
uint32_t AD5940_MCUResourceInit(void)
    // LOG_WRN("AD5940_MCUResourceInit\n\r");
    printk("nRF_MCU_Port: AD5940_MCUResourceInit\n\r");
    AD5940_INT_SETUP();
    // AD5940_GUI_SETUP();
    AD5940_RESET_SETUP();
    AD5940_RstSet();
    if(!AD5940_SPI_SETUP())
        // LOG_ERR("SPI Initialization failed\n\r");
        while(1);
    return 0;
nRF_MCU_Port.h
#ifndef NRF_MCU_PORT_H_
#define NRF_MCU_PORT_H_
uint32_t AD5940_MCUResourceInit(void);
void AD5940_DATA_GUI(void);
void set_interrupt(void);
#endif /* NRF_MCU_PORT_H_ */
Currently, it looks like the reset and interrupts are initializing well. The spi instance is "initialized," but I can't use the spi port as a sensor.
The evaluation board for this component is based on the Arduino R3 pinout.
The component is functioning ( I tested with the native MCU)
This is urgent for our project schedule; please help!
Thanks to all the helpers!
