Hi there,
In order to understand more about the MultiCore of the nRF5340, I'm trying to built the Multicore Hello World application, with nRF Connect SDK 2.3.0 as a "Workspace" application type.
Creating the files/application does work so far, but during the build process, it the the following failure bellow:
I have also tried it with the nRF Connect SDK 2.2.0, with the same result.
Patrick
Executing task: nRF Connect: Generate config nrf5340dk_nrf5340_cpuapp for c:\repos\MAT\Nordic\WorkSpace\MultiCore_WorkSpace\MultiCore_2-3-0\multicore
Building multicore
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:\repos\MAT\Nordic\WorkSpace\MultiCore_WorkSpace\MultiCore_2-3-0\multicore\build c:\repos\MAT\Nordic\WorkSpace\MultiCore_WorkSpace\MultiCore_2-3-0\multicore --pristine --board nrf5340dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y"
-- Application: C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore
-- Found Python3: C:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/zephyr/.cache
-- Zephyr version: 3.2.99 (C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.15.2 (C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.2 (C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/v2.3.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/zephyr/dts.cmake
Parsing C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/Kconfig
Loaded configuration 'C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/prj.conf'
Merged configuration 'C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/zephyr/.config'
Kconfig header saved to 'C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Error at aci/CMakeLists.txt:11 (add_child_image):
Unknown CMake command "add_child_image".
See also "C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/CMakeFiles/CMakeOutput.log".
See also "C:/repos/MAT/Nordic/WorkSpace/MultiCore_WorkSpace/MultiCore_2-3-0/multicore/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.3.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.3.0\opt\bin\python.exe' '-Bc:\repos\MAT\Nordic\WorkSpace\MultiCore_WorkSpace\MultiCore_2-3-0\multicore\build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y '-Sc:\repos\MAT\Nordic\WorkSpace\MultiCore_WorkSpace\MultiCore_2-3-0\multicore'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
