I need some clarification around Active / Passive mode and have read through most questions and docs for the Thingy91 Asset Tracker Example.
I am using the https://github.com/NordicSemiconductor/asset-tracker-cloud-firmware-aws v4.1.24 on a v1.4.0 Thingy:91 SDK v2.3.0 with updated connectivity_bridge and latest Modem Firmware (1.3.4) and everything works great sending data to AWS etc.
My goal is to have a device that use as low power as possible and wakes up if it is being moved and sends data every X minutes (for example 120 sec) if being moved until it stops and goes back to low power mode but I also need it to send a "heartbeat" packet even if it is not in motion at specific intervals to understand that the device is alive and works in case there is no movement for several hours/days/weeks.
So far my findings are as follows:
Setting it to Passive Mode:
1. In Passive Mode the device goes to sleep and can only be woken up by movement e.g external physical movement makes it wake up. Is this correct? My testing so far is that it detect movement and sends updates as configured, but if it is not being moved it goes into sleep until moved again (tested over 24 hours).
2. The CONFIG_DATA_MOVEMENT_TIMEOUT_SECONDS state that it should send a publication every X (default 3600 sec) in passive mode. I am not seeing this and my device is dead on LTE network (verified in LTE M2M provider console) and does not send any MQTT packets. What is the purpose of this setting?
In Active Mode:
I am able to tune it to send updates at a specific interval using CONFIG_DATA_DEVICE_MODE_ACTIVE=y and for example every 15 min CONFIG_DATA_ACTIVE_TIMEOUT_SECONDS=900 and it sends a heartbeat every 15 minutes. However it will not detect any movement with this configuration.
Thanks in advance for clarification and suggested config parameters.
