nRF Connect SDK- NRF5340 Audio DK Python script build problems
I'm using the doc at https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html For the nrf5340_audio DK and I'm having problems building with the Python script in the building in the programming section https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html#
BUILDING AND PROGRAMMING the AUDIO Example
Development platform used
Windows10
nRFConnect SDK version v2.4.0
nRF Connect for VS Code Extension Pack  v2022.9.6
I'm getting an error
  • west' is not recognized as an internal or external command
I'm using the toolbox manager bash command and I'm able to get past some of the tools and installed them with PIP . what do I need to do to assure that the tools for West and others in the script are visible?
  • Hi
    i’m sorry,  but I have used this document for days now. I have tried documenting my steps and tried the recover argument and it does not work as specified.
    Can you be more specific with giving me the correct command line to recover Please…
    again, I have found the document to have errors with the recover argument .
    Regards Steve
  • Hi Stephen,
    In the link I have mentioned in the previous comment, it highlights to this:
    Have you tried this?
    -Priyanka
  • Yes I have tried this. but a get the following error all the time?
    buildprog.py: error: unrecognized arguments: --recover-on-fail
    It appears that It doesn't know about the argument " --recover-on-fail"
  • The App doc page is incorrect the program command has an incorrect argument “--recover-on-fail”! It should be defined with underscores not dashes.
    THIS NEEDS TO BE FIXED ON THE DOC PAGE TO STOP CONFUSION WHEN USING THE AUDIO EXAMPLE TO BUILD & PROGRAM the KIT
    Using the command:
    python buildprog.py -c both -b debug -d both -p --recover_on_fail
    Results:
    1. Still get the use recover argument error in the output, even though I ran the command with “--recover_on_fail” ? Please refer to the output of the command at the end of this reply.
    2. Received some other errors refer to “s4_program_sucess_with_recover.txt”
    3. I’m assuming the 2 boards are programmed because the script reports that they are as follows:
    |    snr     | snr conn |  device | only reboot             | core app programmed | core net programmed |
    | 1050171701 |   True   | headset | Not selected    |         Done                              Done
    | 1050131916 |   True   | gateway | Not selected    |         Done                              Done
    The output of the command:
    skrug@DESKTOP-KJBLMH9 MINGW64 /c/A/s4/tools/buildprog
    $ python buildprog.py -c both -b debug -d both -p --recover_on_fail
    | 1050171701 |   ←[32mTrue←[0m   | headset | Not selected |     Selected TBD    |     Selected TBD    |
    | 1050131916 |   ←[32mTrue←[0m   | gateway | Not selected |     Selected TBD    |     Selected TBD    |
    |     10     |  ←[33mFalse←[0m   | headset | Not selected |     Selected TBD    |     Selected TBD    |
    Invoking build step
    Net core uses precompiled hex
    Run: west build C:\A\s4 -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\A\s4\build\dev_headset\build_debug
    [0/14] Performing build step for 'empty_net_core_subimage'
    [0/5] Performing build step for 'b0n_subimage'
    ninja: no work to do.
    [1/10] Performing build step for 'mcuboot_subimage'
    [4/6] Generating ../../zephyr/net_core_app_test_update.hex
    image.py: sign the payload
    [6/6] Running post-build ble5-ctr signing step...
    0x00000001
    input hex name C:\ncs\v2.4.0\nrf\lib\bin\bt_ll_acs_nrf53\bin\ble5-ctr-rpmsg_shifted_3349.hex
    relative path
    Run: west build C:\A\s4 -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\A\s4\build\dev_gateway\build_debug
    [2/10] Generating ../../zephyr/net_core_app_test_update.hex
    0x00000001
    relative path
    Using NET hex: C:\lib\bin\bt_ll_acs_nrf53\bin\ble5-ctr-rpmsg_3349.hex for 1050171701 headset left
    Using NET hex: C:\lib\bin\bt_ll_acs_nrf53\bin\ble5-ctr-rpmsg_3349.hex for 1050131916 gateway
    Programming net core on: 1050171701 headset left
    Programming net core on: 1050131916 gateway
    ERROR: The operation attempted is unavailable due to readback protection in
    ERROR: your device. Please use --recover to unlock the device.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    Recovering device: 1050171701 headset left
    Recovering device: 1050131916 gateway
    [error] [ Client] - Encountered error -90: Command enable_coprocessor executed for 14 milliseconds with result -90
    [error] [ Worker] - Application core access protection is enabled, can't enable coprocessor.
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    Writing image to disable ap protect.
    Programming app core on: 1050131916 gateway
    Programming app core on: 1050171701 headset left
    Programming UICR
    Parsing parameters.
    Writing.
    Parsing parameters.
    Writing.
    Resetting 1050131916 gateway
    Parsing parameters.
    Writing.
    Resetting 1050171701 headset left
    Applying system reset.
    Run.
    Run.
    build_prog.py finished. Report:
    | 1050171701 |   True   | headset | Not selected |         Done        |         Done        |
    | 1050131916 |   True   | gateway | Not selected |         Done        |         Done        |
    |     10     |  False   | headset | Not selected |     Not selected    |     Not selected    |
  • I had 2 issues with the doc page
    1. west' is not recognized as an internal or external command
      1. Solution: use the bash command line tool accessible from the SDK version tab in the Tool Manger.
    2. programming the devices. I cannot program the net core on both devices? Due to readback protection?
      1. Solution:
        Use the command:    python buildprog.py -c both -b debug -d both -p --recover_on_fail
      2. The App doc page is incorrect the program command has an incorrect argument “--recover-on-fail”! It should be defined with underscores not dashes.
    Be aware the doc page has some buggy information
    RESULTS of running the command.
    Invoking build step
    0x00000001
    relative path
    0x00000001
    relative path
    Programming UICR
    Parsing parameters.
    Writing.
    Parsing parameters.
    Writing.
    Parsing parameters.
    Writing.
    Run.
    Run.
