I have an nrf52833-dk and adapted the light_bulb example in order to handle two endpoints. The second endpoint is a copy from the first and the same as in the light_bulb example. When I send a level control command everything works as expected and the default handler relays the information to the zcl_device_cb function. However with the color command this does not happen. For debugging purposes I temporarily created a custom endpoint handler and looked at the command that is received by the device:
This is the command that is not relayed to the zcl_device_cb function by the default handler. Is this standard behaviour?
