Default handler doesn't relay set color command
I have an nrf52833-dk and adapted the light_bulb example in order to handle two endpoints. The second endpoint is a copy from the first and the same as in the light_bulb example. When I send a level control command everything works as expected and the default handler relays the information to the zcl_device_cb function. However with the color command this does not happen. For debugging purposes I temporarily created a custom endpoint handler and looked at the command that is received by the device:
This is the command that is not relayed to the zcl_device_cb function by the default handler. Is this standard behaviour?
    The developers have made a fix for this. Please try replacing the files zcl_main.c and zcl_color_control_commands.c in nrfxlib/zboss/production/src/zcl with the ones I have attached here.
    Here are the changes between the files:
    diff --git a/zboss/production/src/zcl/zcl_main.c b/zboss/production/src/zcl/zcl_main.c
    index a560f4d0..29f0e72f 100644
    --- a/zboss/production/src/zcl/zcl_main.c
    +++ b/zboss/production/src/zcl/zcl_main.c
    @@ -364,7 +364,7 @@ zb_zcl_cluster_check_value_t zb_zcl_get_cluster_check_value(zb_uint16_t cluster_
       zb_uindex_t i = 0;
       ZVUNUSED(cluster_role);
    -  TRACE_MSG(TRACE_ERROR, "zb_zcl_get_cluster_check_value: cluster_id %d cluster_role %hd",
    +  TRACE_MSG(TRACE_ZCL3, "zb_zcl_get_cluster_check_value: cluster_id %d cluster_role %hd",
                 (FMT__D_H, cluster_id, cluster_role));
       /* Search if we already have handler */
    @@ -389,7 +389,7 @@ zb_zcl_cluster_write_attr_hook_t zb_zcl_get_cluster_write_attr_hook(zb_uint16_t
       zb_uindex_t i = 0;
    -  TRACE_MSG(TRACE_ERROR, "zb_zcl_get_cluster_write_attr_hook: cluster_id %d cluster_role %hd",
    +  TRACE_MSG(TRACE_ZCL3, "zb_zcl_get_cluster_write_attr_hook: cluster_id %d cluster_role %hd",
    diff --git a/zboss/production/src/zcl/zcl_color_control_commands.c b/zboss/production/src/zcl/zcl_color_control_commands.c
    index b9f110b5..59a2c55a 100644
    --- a/zboss/production/src/zcl/zcl_color_control_commands.c
    +++ b/zboss/production/src/zcl/zcl_color_control_commands.c
    @@ -1004,7 +1004,11 @@ static void zb_zcl_process_color_control_move_to_loop(zb_uint8_t param)
       if (rm_time_unit!=0)
         zb_int32_t unit_max = is_16bit ? ZB_UINT16_MAX : ZB_UINT8_MAX;
    -    zb_int32_t all_delta = (loop_data.finish_value - loop_data.start_value);
    +    zb_int32_t all_delta =
    +      (loop_data.finish_value > loop_data.start_value) ?
    +      (loop_data.finish_value - loop_data.start_value) :
    +      (loop_data.start_value - loop_data.finish_value);
    +    zb_int32_t step_value;
         if((loop_data.attr_id == ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID)
             || (loop_data.attr_id == ZB_ZCL_ATTR_COLOR_CONTROL_ENHANCED_CURRENT_HUE_ID)
    @@ -1020,8 +1024,17 @@ static void zb_zcl_process_color_control_move_to_loop(zb_uint8_t param)
    -    val = (zb_int32_t)(all_delta * delta_time / loop_data.transition_time + loop_data.start_value);
    -    if(val > unit_max)
    +    step_value =
    +      (delta_time == 0U) ?
    +      (all_delta) :
    +      (zb_int32_t)(all_delta * delta_time / loop_data.transition_time);
    +    val =
    +      (loop_data.start_value + step_value) :
    +      (loop_data.start_value - step_value);
    +    if (val > unit_max)
           val -= unit_max;
    @@ -1045,8 +1058,20 @@ static void zb_zcl_process_color_control_move_to_loop(zb_uint8_t param)
    -      zb_int32_t all_delta = (loop_data.finish_value2 - loop_data.start_value2);
    -      val = (zb_int32_t)(all_delta * delta_time / loop_data.transition_time + loop_data.start_value2);
    +        (loop_data.finish_value2 > loop_data.start_value2) ?
    +        (loop_data.finish_value2 - loop_data.start_value2) :
    +        (loop_data.start_value2 - loop_data.finish_value2);
    +      zb_int32_t step_value =
    +        (all_delta) :
    +      val =
    +        (loop_data.start_value2 + step_value) :
    +        (loop_data.start_value2 - step_value);
     * ZBOSS Zigbee 3.0
     * Copyright (c) 2012-2022 DSR Corporation, Denver CO, USA.
     * www.dsr-zboss.com
     * www.dsr-corporation.com
     * All rights reserved.
     * Use in source and binary forms, redistribution in binary form only, with
     * or without modification, are permitted provided that the following conditions
     * are met:
     * 1. Redistributions in binary form, except as embedded into a Nordic
     * 2. Neither the name of Nordic Semiconductor ASA nor the names of its
     * 3. This software, with or without modification, must only be used with a Nordic
     *    Semiconductor ASA integrated circuit.
     * 4. Any software provided in binary form under this license must not be reverse
     * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS OR
     * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
     * MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE
     * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE LIABLE
     * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
     * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
     * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
     * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
     * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
     * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /* PURPOSE: Zigbee cluster library, the main module
    #define ZB_TRACE_FILE_ID 2074
    #include "zb_common.h"
    /* #define ZB_ZCL_ENABLE_DEFAULT_ALARMS_PROCESSING */
    #if defined (ZB_ENABLE_ZCL)
    #include "zb_zcl.h"
    #include "zb_aps.h"
    #include "zcl/zb_zcl_common.h"
    #if !(defined ZB_ZCL_DISABLE_REPORTING)
    #include "zcl/zb_zcl_reporting.h"
    #include "zcl/zb_zcl_cvc_commands.h"
    #include "zcl/zcl_ota_upgrade_commands.h"
    #ifdef ZB_ENABLE_HA_SAS
    #include "ha/zb_ha_sas.h"
    #include "zb_bdb_internal.h"
    #include "zb_zdo.h"
    #include "zb_aps.h"
    #include "zdo_wwah_stubs.h"
    static zb_uint_t zb_zcl_get_header_size(zb_bufid_t buf)
      zb_uint8_t* zcl_packet = zb_buf_begin(buf);
      return ZB_ZCL_GET_HEADER_SIZE(*zcl_packet);
    #if defined HA_CERTIFICATION
    zb_bool_t zb_zcl_rejected_command(zb_uint8_t param);
    #endif /* HA_CERTIFICATION */
    void zb_zcl_init()
      TRACE_MSG(TRACE_ZCL1, ">>zcl_init", (FMT__0));
      ZB_BZERO(&ZCL_CTX(), sizeof(zb_zcl_globals_t));
      ZB_BZERO(&ZCL8_CTX(), sizeof(zb_zcl8_globals_t));
      min_interval and max_interval are set to ZERO value by BZERO call
      ZCL_CTX().reporting_ctx.min_interval == ZB_ZCL_TIMEOUT_ZERO;
      ZCL_CTX().reporting_ctx.max_interval == ZB_ZCL_TIMEOUT_ZERO;
      ZCL_CTX().runtime_buf = zb_buf_get_any();
      ZB_ASSERT(ZCL_CTX().runtime_buf);
      Initialize reporting context, allocate free out buffer for reporting.
      TODO: comment if reporting is not supported.
      zb_zcl_init_reporting_ctx();
    #if defined ZB_ENABLE_HA_SAS
      zb_ha_process_sas();
    #endif /* defined ZB_ENABLE_HA_SAS */
      TRACE_MSG(TRACE_ZCL1, "<<zcl_init", (FMT__0));
    zb_uint8_t zb_zcl_handle(zb_uint8_t param)     /* VS Fixed */
      zb_zcl_parsed_hdr_t *cmd_info_ptr =
        (zb_zcl_parsed_hdr_t *)ZB_BUF_GET_PARAM(param, zb_zcl_parsed_hdr_t);
      zb_uint8_t status; /* zcl_status */
      zb_bool_t processed = ZB_FALSE;
      TRACE_MSG(TRACE_ZCL1, ">> zb_zcl_handle param %hd", (FMT__H, param));
      TRACE_MSG(
          TRACE_ZCL2,
          "f type %d cmd %d",
          (FMT__D_D, cmd_info_ptr->is_common_command, cmd_info_ptr->cmd_id));
      status = zb_zcl_check_accept_command(param);
      if (status == ZB_ZCL_STATUS_SUCCESS)
        if (cmd_info_ptr->is_common_command)
          processed = zb_zcl_handle_general_commands(param);
          processed = zb_zcl_handle_specific_commands(param);
        if (!processed)
          /* TODO: return correct status by zb_zcl_handle_general_commands() */
          TRACE_MSG(TRACE_ZCL1, "command is not processed", (FMT__0));
          /* ZCL8: CCB 2477: use UNSUP_COMMAND instead of any other Unsupported command status */
          if (zb_zcl_get_backward_compatible_statuses_mode() == ZB_ZCL_STATUSES_ZCL8_MODE)
            status = ZB_ZCL_STATUS_UNSUP_CMD;
            if (cmd_info_ptr->is_manuf_specific)
              status = cmd_info_ptr->is_common_command ?
                ZB_ZCL_STATUS_UNSUP_MANUF_GEN_CMD : ZB_ZCL_STATUS_UNSUP_MANUF_CLUST_CMD;
                ZB_ZCL_STATUS_UNSUP_GEN_CMD : ZB_ZCL_STATUS_UNSUP_CLUST_CMD;
      } /* zb_zcl_check_accept_command() */
        if (zb_zcl_rejected_command(param) )
          processed = ZB_TRUE;
          TRACE_MSG(TRACE_ZCL1, "skip command processing", (FMT__0));
      if (processed)
        status = ZB_ZCL_STATUS_SUCCESS;
      TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_handle, ret %hd", (FMT__H, status));
      return status;
    void zb_zcl_deinit()
      TRACE_MSG(TRACE_ZCL1, ">>zcl_deinit", (FMT__0));
      TRACE_MSG(TRACE_ZCL1, "<<zcl_deinit", (FMT__0));
    /* FIXME: why is this routine in zcl_main.c while it used only once from zb_zcl_process_device_command which is in zcl_common.c?? */
    /* Function parses ZCL header and puts values to zb_zcl_parsed_hdr_t
     * structure. Also, it
     * 1) copies values APSDE data indication - it will be used during ZCL command handling
     * 2) check if command processing allowed by WWAH cluster */
    zb_zcl_status_t zb_zcl_parse_header(zb_uint8_t param, zb_zcl_parsed_hdr_t *cmd_info)
      zb_apsde_data_indication_t *ind = ZB_BUF_GET_PARAM(param, zb_apsde_data_indication_t);
      zb_uint8_t *zcl_header;
      zb_zcl_status_t ret = ZB_ZCL_STATUS_SUCCESS;
      zb_uint8_t frame_type;
      TRACE_MSG(
          TRACE_ZCL1,
          ">> zb_zcl_parse_header: param %hd h 0x%hx sz %hd, dst endp %hd",
          (FMT__H_H_H_H, param, zb_buf_get_handle(param), zb_buf_len(param), ind->dst_endpoint));
      /* buffer should have enough data for parsing command! */
      if (zb_buf_len(param) < zb_zcl_get_header_size(param))
        TRACE_MSG(TRACE_ERROR, "ERROR: buffer should have enough data for parsing command!", (FMT__0));
        return ZB_ZCL_STATUS_MALFORMED_CMD;
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).source.addr_type = ZB_ZCL_ADDR_TYPE_SHORT;
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).source.u.short_addr = ind->src_addr;
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).src_endpoint = ind->src_endpoint;
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).dst_addr = ind->dst_addr;
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).dst_endpoint = ind->dst_endpoint;
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).fc = ind->fc;
    #if (defined ZB_ENABLE_SE) || (defined ZB_ZCL_SUPPORT_CLUSTER_WWAH)
      ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).aps_key_from_tc = ind->aps_key_from_tc;
      cmd_info->cluster_id = ind->clusterid;
      cmd_info->profile_id = ind->profileid;
      zcl_header = zb_buf_begin(param);
      /* ZCL frame format */
      /* frame control 1b | manufacturer code 0/2b | TSN 1b | cmd id 1b | payload XXb */
      /* frame control */
      /* frame type | manufacturer specific | direction | disable default resp */
      /* Parse ZCL frame control */
      frame_type = ZB_ZCL_GET_FRAME_TYPE(*zcl_header);
      cmd_info->is_common_command = (frame_type == ZB_ZCL_FRAME_TYPE_CLUSTER_SPECIFIC ) ? ZB_FALSE : ZB_TRUE;
      if( frame_type != ZB_ZCL_FRAME_TYPE_CLUSTER_SPECIFIC && frame_type != ZB_ZCL_FRAME_TYPE_COMMON)
        ret = ZB_ZCL_STATUS_INVALID_FIELD;
      cmd_info->cmd_direction = ZB_ZCL_GET_DIRECTION(*zcl_header);
      cmd_info->disable_default_response = (ZB_ZCL_GET_DISABLE_DEFAULT_RESPONSE(*zcl_header) != 0U )?(ZB_TRUE ):(ZB_FALSE );
      if (ZB_ZCL_GET_MANUF_SPECIFIC(*zcl_header) != 0U)
        cmd_info->is_manuf_specific = ZB_TRUE;
        zcl_header++;
        ZB_ZCL_PACKET_GET_DATA16(&(cmd_info->manuf_specific), zcl_header);
        /* there is no manufacturer specific sub field, get TSN field */
        cmd_info->is_manuf_specific = ZB_FALSE;
        zcl_header++;
      /* Get TSN */
      cmd_info->seq_number = *zcl_header;
      zcl_header++;
      /* Get command ID */
      cmd_info->cmd_id = *zcl_header;
      /* Note: there was cut of ZCL header here. Moved to zb_zcl_process_device_command() - the only caller of this routine. */
      TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_parse_header ret = %hd", (FMT__H, ret));
      return ret;
    zb_ret_t zb_zcl_add_cluster_handlers(zb_uint16_t cluster_id,
                                         zb_uint8_t cluster_role,
                                         zb_zcl_cluster_check_value_t cluster_check_value,
                                         zb_zcl_cluster_write_attr_hook_t cluster_write_attr_hook,
                                         zb_zcl_cluster_handler_t cluster_handler)
      zb_ret_t ret = RET_EMPTY;
      TRACE_MSG(TRACE_ZCL1, ">> zb_zcl_add_cluster_handlers cluster 0x%x role %hd",
                (FMT__H_D, cluster_id, cluster_role));
      TRACE_MSG(TRACE_ZCL1, "check_value %p write_attr_hook %p handler %p",
                (FMT__P_P_P, cluster_check_value, cluster_write_attr_hook, cluster_handler));
      if ((cluster_handler != NULL || cluster_check_value != NULL || cluster_write_attr_hook != NULL)
          /*cstat !MISRAC2012-Rule-13.5 !MISRAC2012-Rule-13.6 */
          /* After some investigation, the following violations of Rule 13.5 and 13.6 seem to be false
           * positives. There are no side effect to 'ZCL_CTX()'. This violation seems to be caused by
           * the fact that 'ZCL_CTX()' is an external macro, which cannot be analyzed by C-STAT. */
          && ZCL_CTX().zcl_handlers_cnt < ZB_ARRAY_SIZE(ZCL_CTX().zcl_handlers))
        zb_uindex_t i = 0;
        while (i < ZCL_CTX().zcl_handlers_cnt)
          if (ZCL_CTX().zcl_handlers[i].cluster_id == cluster_id
              /*cstat !MISRAC2012-Rule-13.5 */
              /* After some investigation, the following violation of Rule 13.5 seems to be a false
               * positive. There are no side effect to 'ZCL_CTX()'. This violation seems to be caused by
              && ZCL_CTX().zcl_handlers[i].cluster_role == cluster_role)
          ++i;
        if (i == ZCL_CTX().zcl_handlers_cnt)
          /* add new entry */
          ZCL_CTX().zcl_handlers[i].cluster_id = cluster_id;
          ZCL_CTX().zcl_handlers[i].cluster_role = cluster_role;
          ZCL_CTX().zcl_handlers[i].cluster_handler = cluster_handler;
          ZCL_CTX().zcl_handlers[i].cluster_check_value = cluster_check_value;
          ZCL_CTX().zcl_handlers[i].cluster_write_attr_hook = cluster_write_attr_hook;
          ++ZCL_CTX().zcl_handlers_cnt;
          ret = RET_OK;
          ret = RET_ALREADY_EXISTS;
      TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_add_cluster_handlers cluster ret %d", (FMT__D, ret));
      return ret;
    zb_zcl_cluster_handler_t zb_zcl_get_cluster_handler(zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      zb_uindex_t i = 0;
      zb_zcl_cluster_handler_t ret = NULL;
      TRACE_MSG(TRACE_ZCL1, ">> zb_zcl_get_cluster_handler: cluster_id 0x%x cluster_role %hd",
            && (ZCL_CTX().zcl_handlers[i].cluster_role == cluster_role
                /* || ZCL_CTX().zcl_handlers[i].cluster_role == ZB_ZCL_CLUSTER_MIXED_ROLE */))
          ret = ZCL_CTX().zcl_handlers[i].cluster_handler;
        ++i;
      TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_get_cluster_handler ret %p", (FMT__P, ret));
      return ret;
    zb_zcl_cluster_check_value_t zb_zcl_get_cluster_check_value(zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      zb_uindex_t i = 0;
          return ZCL_CTX().zcl_handlers[i].cluster_check_value;
        ++i;
      return NULL;
    zb_zcl_cluster_write_attr_hook_t zb_zcl_get_cluster_write_attr_hook(zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      zb_uindex_t i = 0;
          return ZCL_CTX().zcl_handlers[i].cluster_write_attr_hook;
        ++i;
      return NULL;
    #ifdef ZB_CONTROL4_NETWORK_SUPPORT
    zb_ret_t zb_zcl_add_control4_cluster_handlers(zb_uint16_t cluster_id, zb_uint8_t cluster_role,
      TRACE_MSG(TRACE_ZCL1, "zb_zcl_add_control4_cluster_handlers cluster 0x%x role %hd",
      if (cluster_handler || cluster_check_value || cluster_write_attr_hook)
        zb_uindex_t i = (cluster_role == ZB_ZCL_CLUSTER_SERVER_ROLE ? 0 : 1);
        /* add new entry */
        ZCL_CTX().control4_zcl_handlers[i].cluster_id = cluster_id;
        ZCL_CTX().control4_zcl_handlers[i].cluster_role = cluster_role;
        ZCL_CTX().control4_zcl_handlers[i].cluster_handler = cluster_handler;
        ZCL_CTX().control4_zcl_handlers[i].cluster_check_value = cluster_check_value;
        ZCL_CTX().control4_zcl_handlers[i].cluster_write_attr_hook = cluster_write_attr_hook;
        ret = RET_OK;
      return ret;
    zb_zcl_cluster_handler_t zb_zcl_get_control4_cluster_handler(zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      TRACE_MSG(TRACE_ZCL1, "zb_zcl_get_control4_cluster_handler: cluster_id 0x%x cluster_role %hd",
      if (ZCL_CTX().control4_zcl_handlers[i].cluster_id == cluster_id &&
          ZCL_CTX().control4_zcl_handlers[i].cluster_role == cluster_role)
        return ZCL_CTX().control4_zcl_handlers[i].cluster_handler;
      return NULL;
    zb_zcl_cluster_check_value_t zb_zcl_get_control4_cluster_check_value(zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      TRACE_MSG(TRACE_ERROR, "zb_zcl_get_control4_cluster_check_value: cluster_id %d cluster_role %hd",
          && ZCL_CTX().control4_zcl_handlers[i].cluster_role == cluster_role)
        return ZCL_CTX().control4_zcl_handlers[i].cluster_check_value;
      return NULL;
    zb_zcl_cluster_write_attr_hook_t zb_zcl_get_control4_cluster_write_attr_hook(zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      TRACE_MSG(TRACE_ERROR, "zb_zcl_get_control4_cluster_write_attr_hook: cluster_id %d cluster_role %hd",
        return ZCL_CTX().control4_zcl_handlers[i].cluster_write_attr_hook;
      return NULL;
    static zb_bool_t zb_zcl_check_control4_cluster_handler(zb_uint8_t endpoint)
      zb_bool_t res = ZB_FALSE;
      ZVUNUSED(endpoint);
    #ifdef ZB_ED_FUNC
      res = (zb_bool_t )(zb_control4_network_permitted() && endpoint == ZB_CONTROL4_NETWORK_ENDPOINT);
    #endif /* ZB_ED_FUNC */
      return res;
    #endif /* ZB_CONTROL4_NETWORK_SUPPORT */
    zb_zcl_cluster_handler_t zb_zcl_get_cluster_handler_internal(zb_uint8_t endpoint, zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      zb_zcl_cluster_handler_t cluster_handler;
      ZVUNUSED(endpoint);
      if (zb_zcl_check_control4_cluster_handler(endpoint))
        cluster_handler = zb_zcl_get_control4_cluster_handler(cluster_id, cluster_role);
        cluster_handler = zb_zcl_get_cluster_handler(cluster_id, cluster_role);
      return cluster_handler;
    zb_zcl_cluster_check_value_t zb_zcl_internal_get_cluster_check_value(zb_uint8_t endpoint, zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      zb_zcl_cluster_check_value_t cluster_check_value;
      ZVUNUSED(endpoint);
        cluster_check_value = zb_zcl_get_control4_cluster_check_value(cluster_id, cluster_role);
        cluster_check_value = zb_zcl_get_cluster_check_value(cluster_id, cluster_role);
      return cluster_check_value;
    zb_zcl_cluster_write_attr_hook_t zb_zcl_internal_get_cluster_write_attr_hook(zb_uint8_t endpoint, zb_uint16_t cluster_id, zb_uint8_t cluster_role)
      zb_zcl_cluster_write_attr_hook_t cluster_write_attr_hook;
      ZVUNUSED(endpoint);
        cluster_write_attr_hook = zb_zcl_get_control4_cluster_write_attr_hook(cluster_id, cluster_role);
        cluster_write_attr_hook = zb_zcl_get_cluster_write_attr_hook(cluster_id, cluster_role);
      return cluster_write_attr_hook;
    zb_bool_t zb_zcl_handle_specific_commands(zb_uint8_t param)
      zb_bool_t processed;
      zb_zcl_parsed_hdr_t *cmd_info = ZB_BUF_GET_PARAM(param, zb_zcl_parsed_hdr_t);
      TRACE_MSG(TRACE_ZCL1, "> zb_zcl_handle_specific_commands param %hd", (FMT__H, param));
        cluster_handler = zb_zcl_get_cluster_handler_internal(cmd_info->addr_data.common_data.dst_endpoint,
                                                              cmd_info->cluster_id,
                                                              cmd_info->cmd_direction == ZB_ZCL_FRAME_DIRECTION_TO_SRV ?
                                                              ZB_ZCL_CLUSTER_SERVER_ROLE :
                                                              ZB_ZCL_CLUSTER_CLIENT_ROLE);
        if (cluster_handler != NULL)
          processed = cluster_handler(param);
          TRACE_MSG(TRACE_ZCL1, "Cluster 0x%04x was not processed", (FMT__D, cmd_info->cluster_id));
      TRACE_MSG(TRACE_ZCL1, "< zb_zcl_handle_specific_commands processed %hd", (FMT__H, processed));
      return processed;
    }/* zb_uint8_t zb_zcl_handle_specific_commands(zb_uint8_t param) */
    /* During HA certification came out that for some commands which
     * should not be handled (command with direction "to server" is sent
     * to client for example) we need to send a response anyway, but with
     * "empty" body */
      zb_zcl_cluster_desc_t *cluster_desc;
      zb_af_endpoint_desc_t *endpoint_desc;
      zb_bool_t ret = ZB_FALSE;
      TRACE_MSG(TRACE_ZCL1, ">> zb_zcl_rejected_command %hd", (FMT__H, param));
      endpoint_desc = zb_af_get_endpoint_desc(ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).dst_endpoint);
      cluster_desc = get_cluster_desc(ep_desc, cmd_info->cluster_id,
                                      (cmd_info->cmd_direction == ZB_ZCL_FRAME_DIRECTION_TO_SRV) ?
                                      ZB_ZCL_CLUSTER_SERVER_ROLE : ZB_ZCL_CLUSTER_CLIENT_ROLE);
      ZB_ZCL_DEBUG_DUMP_HEADER(cmd_info);
      /* if command is manufacturer specific - skip handling it by default */
      TRACE_MSG(TRACE_ZCL2, "manuf_spec %hd", (FMT__H, cmd_info->is_manuf_specific));
      if (cluster_desc &&
          !cmd_info->is_manuf_specific &&
          cmd_info->is_common_command)
        switch(cmd_info->cmd_id)
        case ZB_ZCL_CMD_DISCOVER_COMMANDS_RECEIVED:
        case ZB_ZCL_CMD_DISCOVER_COMMANDS_GENERATED:
          ret = zb_zcl_handle_general_commands(param);
        case ZB_ZCL_CMD_DISCOVER_ATTR_EXT:
          zb_uint8_t *resp_data;
          resp_data = ZB_ZCL_START_PACKET(ZCL_CTX().runtime_buf);
          /* generate frame control taking into account manufacturer specific */
          ZB_ZCL_CONSTRUCT_GENERAL_COMMAND_RESP_FRAME_CONTROL_EXT(
            resp_data, cmd_info->is_manuf_specific, ZB_ZCL_REVERT_DIRECTION(cmd_info->cmd_direction));
          /* Generate command header taking into account manufacturer specific */
          ZB_ZCL_CONSTRUCT_COMMAND_HEADER_EXT(
            resp_data, cmd_info->seq_number, cmd_info->is_manuf_specific, cmd_info->manuf_specific,
            ZB_ZCL_CMD_DISCOVER_ATTR_EXT_RES);
          /* There is the same beginning for both Discover Attr and Discover attr ext Resp */
          ZB_ZCL_PACKET_PUT_DATA8(resp_data, ZB_ZCL_DISC_COMPLETE);
          ZB_ZCL_FINISH_N_SEND_PACKET(ZCL_CTX().runtime_buf, resp_data,
              ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).source.u.short_addr,
              ZB_APS_ADDR_MODE_16_ENDP_PRESENT,
              ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).src_endpoint,
              ZB_ZCL_PARSED_HDR_SHORT_DATA(cmd_info).dst_endpoint,
              cmd_info->profile_id,
              NULL);
          /* Use runtime buffer to send request, use received buffer with
           * request data_buf as runtime buffer */
          ret = ZB_TRUE;
        case ZB_ZCL_CMD_DISCOVER_COMMANDS_RECEIVED_RES:
        case ZB_ZCL_CMD_DISCOVER_COMMANDS_GENERATED_RES:
        case ZB_ZCL_CMD_DISCOVER_ATTR_EXT_RES:
          ret = ZB_FALSE;
          ret = ZB_FALSE;
      TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_rejected_command %hd", (FMT__H, ret));
      return ret;
    void zb_zcl_send_cmd_tsn(
      zb_uint8_t param,
      const zb_addr_u *dst_addr,
      zb_aps_addr_mode_t dst_addr_mode,
      zb_uint8_t dst_ep,
      zb_zcl_frame_direction_t direction,
      zb_uint8_t src_ep,
      const void *payload,
      zb_uint8_t payload_size,
      zb_zcl_put_payload_cb_t put_payload,
      zb_zcl_cluster_id_t cluster_id,
      zb_zcl_disable_default_response_t def_resp,
      zb_uint8_t cmd_id,
      zb_uint8_t tsn,
      zb_callback_t cb
      zb_uint16_t profile_id = get_profile_id_by_endpoint(src_ep);
      zb_uint32_t bytes_avail;
    #ifdef APS_FRAGMENTATION
      /* zb_uint16_t payload_out_cnt = 3; */
      /* It was static variable initially in SE code. Seems can use a runtime buffer for it. Hope no conflict here. */
      /* zb_uint8_t *payload_temp_out; */
      zb_uint8_t *cmd_ptr;
      TRACE_MSG(TRACE_ZCL2, "zb_zcl_send_cmd: param %hd (cluster_id 0x%x cmd_id %d)", (FMT__H_D_D, param, cluster_id, cmd_id));
      TRACE_MSG(TRACE_ZCL2, "payload size %hd", (FMT__H, payload_size));
      cmd_ptr = ZB_ZCL_START_PACKET(param);
      ZB_ZCL_CONSTRUCT_SET_FRAME_CONTROL(*cmd_ptr,
                                         ZB_ZCL_FRAME_TYPE_CLUSTER_SPECIFIC,
                                         ZB_ZCL_NOT_MANUFACTURER_SPECIFIC,
                                         direction,
                                         def_resp);
      cmd_ptr++;
      ZB_ZCL_CONSTRUCT_COMMAND_HEADER(cmd_ptr, tsn, cmd_id);
      bytes_avail = (ZB_ASDU_MAX_FRAG_LEN - ZB_ZCL_GET_BYTES_WRITTEN(param, cmd_ptr));
    #else
      bytes_avail = (ZB_ZCL_HI_MAX_PAYLOAD_SIZE - ZB_ZCL_GET_BYTES_WRITTEN(param, cmd_ptr));
      if (bytes_avail < payload_size)
        TRACE_MSG(TRACE_ERROR, "zb_zcl_send_cmd: ERROR, buffer is full (cluster_id %d cmd_id %d)", (FMT__D_D, cluster_id, cmd_id));
        zb_buf_free(param);
        return;
        TRACE_MSG(TRACE_ZCL3, "zb_zcl_send_cmd: buffer have enough space (bytes_avail = %hd)", (FMT__H, bytes_avail));
      if (put_payload != NULL && payload != NULL)
        cmd_ptr = put_payload(cmd_ptr, payload);
      else if (put_payload == NULL && payload != NULL)
        ZB_MEMCPY(cmd_ptr, payload, payload_size);
        cmd_ptr += payload_size;
        /* MISRA rule 15.7 requires empty 'else' branch. */
      TRACE_MSG(TRACE_ZCL3, "zb_zcl_send_cmd addr_type %d to " TRACE_FORMAT_64,
                (FMT__D_A, dst_addr_mode, TRACE_ARG_64(dst_addr->addr_long)));
      ZB_ZCL_FINISH_N_SEND_PACKET(param, cmd_ptr,
                                  *dst_addr,
                                  dst_addr_mode,
                                  dst_ep,
                                  src_ep,
                                  profile_id,
                                  cluster_id,
                                  cb);
    void zb_zcl_send_cmd(
      zb_uint8_t param,
      zb_uint8_t dst_ep,
      zb_uint8_t src_ep,
      zb_uint8_t cmd_id,
      zb_callback_t cb
      zb_zcl_send_cmd_tsn(param, dst_addr, dst_addr_mode, dst_ep, direction,
      src_ep, payload, payload_size, put_payload, cluster_id, def_resp, cmd_id, ZB_ZCL_GET_SEQ_NUM(), cb);
    /* Helper for sending default responses */
    zb_bool_t zb_zcl_send_default_handler(zb_uint8_t param,
      const zb_zcl_parsed_hdr_t *cmd_info, zb_zcl_status_t status)
      zb_bool_t ret;
      TRACE_MSG(TRACE_ZCL3, ">zb_zcl_send_default_handler param %hd, status: %hd", (FMT__H_H, param, status));
      do
        if (!ZB_ZCL_CHECK_IF_SEND_DEFAULT_RESP(*cmd_info, status))
          ret = ZB_FALSE;
        ZB_ZCL_SEND_DEFAULT_RESP_DIRECTION(
          param,
          cmd_info->cmd_id,
          status,
        param = 0;
        ret = ZB_TRUE;
      } while (0);
      if (param != 0u)
        zb_buf_free(param);
      TRACE_MSG(TRACE_ZCL3, "<zb_zcl_send_default_handler %d", (FMT__D, ret));
      return ret;
    void zb_zcl_process_command_finish(zb_bufid_t buffer, zb_zcl_parsed_hdr_t *pcmd_info, zb_uint8_t status)
      if (ZB_ZCL_CHECK_IF_SEND_DEFAULT_RESP(*(pcmd_info), status))
        ZB_ZCL_SEND_DEFAULT_RESP(
          (buffer),
          ZB_ZCL_PARSED_HDR_SHORT_DATA((pcmd_info)).source.u.short_addr,
          ZB_ZCL_PARSED_HDR_SHORT_DATA((pcmd_info)).src_endpoint,
          ZB_ZCL_PARSED_HDR_SHORT_DATA((pcmd_info)).dst_endpoint,
          (pcmd_info)->profile_id,
          (pcmd_info)->cluster_id,
          (pcmd_info)->seq_number,
          (pcmd_info)->cmd_id,
          (status));
        TRACE_MSG( TRACE_ZCL3, "Default response disabled", (FMT__0));
        zb_buf_free(buffer);
    void zb_zcl_process_command_finish_new(zb_bufid_t buffer, zb_zcl_parsed_hdr_t *pcmd_info, zb_uint8_t status)
        ZB_ZCL_SEND_DEFAULT_RESP_NEW(
          (buffer),
          (status),
          ZB_APS_FC_IS_SECURE((pcmd_info)->addr_data.common_data.fc));
    void zb_zcl_send_default_resp_ext(zb_uint8_t param,
      if (ZB_ZCL_CHECK_IF_SEND_DEFAULT_RESP(*cmd_info, status))
        ZB_ZCL_SEND_DEFAULT_RESP_EXT(
          param,
          cmd_info->cmd_id,
          status,
          ZB_ZCL_REVERT_DIRECTION(cmd_info->cmd_direction),
          NULL);
        zb_buf_free(param);
    #endif /* defined (ZB_ENABLE_ZCL) */
    Marte
    This has been fixed in nRF Connect SDK v2.6.0.
    Marte
