I using the Samsung Galaxy Buds2 Pro headphones to connect to the latest v2.4.0 nRF SDK. I am using the LE Audio demo code as gateway. The demo connects successfully out of the box to the headphones, with some modifications to the prj.conf file, using the nRF5340 Audio DK. For my project needs, I have both source and sink enabled via CONFIG_STREAM_BIDIRECTIONAL.
CONFIG_AUDIO_DEV=2 CONFIG_BT_DEVICE_NAME="Galaxy Buds2 Pro" #QOS will fail without this CONFIG_BT_AUDIO_PRESENTATION_DELAY_US=40000 #Seem to get failed to discover without this CONFIG_BLE_ACL_CONN_INTERVAL=72 CONFIG_BT_AUDIO_MAX_TRANSPORT_LATENCY_MS=100 CONFIG_LOG_BUFFER_SIZE=8192 CONFIG_BT_AUDIO_RETRANSMITS=2 CONFIG_BT_BAP_UNICAST_CLIENT_ASE_SRC_COUNT=2 CONFIG_STREAM_BIDIRECTIONAL=y CONFIG_WALKIE_TALKIE_DEMO=y CONFIG_AUDIO_SOURCE_I2S=y CONFIG_BT_BONDABLE=n CONFIG_BT_VCP_VOL_CTLR=n
Problem #1 - Controller Crashes
If you connect to the right headset first, then connect to the left headset, the"ble5-ctr-rpmsg_3349" controller crashes. I believe this also happened on the 3330 controller as well.
The crash happens after calling bt_bap_stream_start on the Left SINK. This only happens if you connect to the right headset first, followed by the left.
Once the controller crashes, the next call to bt_hci_cmd_send_sync will fail on semaphore take "timeout with err -11". This usually happens either on the next le_audio_send stream send OR on the ble_core.c watchdog call to net_core_ctrl_version_get.
Log:
nRF5340 Audio nRF5340 Audio DK cpuapp NCS base version: 2.4.0 Cmake run : Tue Jun 13 05:32:12 2023 GW [00:00:00.258,209] <inf> fw_info: ------- DEBUG BUILD ------- GW [00:00:00.258,239] <inf> fw_info: Compiled for GATEWAY device GW [00:00:00.268,859] <inf> board_version: Compatible board/HW version found: 1.0.0 GW [00:00:00.305,755] <wrn> bt_hci_core: Controller to host flow control not supported GW [00:00:00.308,898] <inf> bt_hci_core: No ID address. App must call settings_load() GW [00:00:00.308,959] <inf> ble: MAC: 00:00:00:00:00:00 (public) GW [00:00:00.309,509] <inf> ble: Controller version: 3349 GW [00:00:00.312,500] <err> settings: set-value failure. key: bt/name error(-2) GW [00:00:00.312,591] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random) GW [00:00:00.312,622] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8 GW [00:00:00.312,622] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15 GW [00:00:00.430,725] <inf> cis_gateway: Scanning successfully started GW [00:00:05.272,583] <inf> cis_gateway: Connected: 7F:3B:83:F5:3B:A8 (random) GW [00:00:07.189,117] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:07.189,117] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:07.457,885] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:08.467,346] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:08.467,346] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005698 GW [00:00:08.468,078] <inf> cis_gateway: Scanning successfully started GW [00:00:08.857,391] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:08.917,388] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:08.917,419] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:09.217,315] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:09.217,437] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:09.257,995] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:09.258,026] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:09.258,544] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:09.577,362] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:09.857,421] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:10.107,452] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:10.147,583] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:10.147,583] <inf> cis_gateway: RIGHT source stream configured GW [00:00:10.207,916] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:10.207,946] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:10.208,404] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:10.208,465] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:10.257,415] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:10.258,331] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:10.427,459] <err> cis_gateway: <<<<< stream_started_cb >>>>> GW [00:00:10.427,459] <inf> cis_gateway: Stream 0x200021ac started GW [00:00:10.453,308] <wrn> bt_hci_core: opcode 0x2061 status 0x0c GW [00:00:10.921,203] <err> cis_gateway: <<<<< stream_started_cb >>>>> GW [00:00:10.921,234] <inf> cis_gateway: Stream 0x200023cc started GW [00:00:12.058,898] <inf> cis_gateway: Connected: 71:09:B2:4D:BC:12 (random) GW [00:00:14.863,433] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:14.863,464] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:15.131,622] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:15.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 5000 GW [00:00:16.901,458] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:16.901,458] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005760 GW [00:00:16.901,458] <inf> cis_gateway: All headsets connected GW [00:00:17.471,496] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:17.531,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:17.531,524] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:18.071,441] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:18.071,563] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:18.141,662] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:18.141,693] <inf> cis_gateway: LEFT sink stream configured GW [00:00:18.151,611] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:18.651,519] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:19.131,591] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:19.551,605] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:19.641,693] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:19.641,723] <inf> cis_gateway: LEFT source stream configured GW [00:00:19.751,586] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:19.751,617] <inf> cis_gateway: Enable stream 0x20001f0c GW [00:00:19.761,718] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:19.761,779] <inf> cis_gateway: Enable stream 0x20001cec GW [00:00:19.821,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:19.851,562] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:19.857,177] <wrn> audio_datapath: I2S RX overrun. Single msg GW [00:00:19.942,169] <wrn> audio_datapath: I2S RX continuing stream GW [00:00:19.962,158] <wrn> audio_datapath: I2S RX overrun. Single msg GW [00:00:20.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 10000 GW [00:00:25.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 15000 ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:330 command opcode 0x2061 timeout with err -11 GW [00:00:29.958,007] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000002 r2/a3: 0x00000001 GW [00:00:29.958,038] <err> os: r3/a4: 0x0000014a r12/ip: 0x00407fd0 r14/lr: 0x00020c95 GW [00:00:29.958,038] <err> os: xpsr: 0x41100000 GW [00:00:29.958,038] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x0000001c s[ 2]: 0x00000000 s[ 3]: 0x000000a2 GW [00:00:29.958,038] <err> os: s[ 4]: 0x00000010 s[ 5]: 0x0000001a s[ 6]: 0x00000000 s[ 7]: 0x000000a2 GW [00:00:29.958,068] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x000000a2 s[10]: 0x00000003 s[11]: 0x00000002 GW [00:00:29.958,068] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000031 s[15]: 0x00000000 GW [00:00:29.958,068] <err> os: fpscr: 0x20000010 GW [00:00:29.958,099] <err> os: Faulting instruction address (r15/pc): 0x00020ca0 GW [00:00:29.958,099] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0 GW [00:00:29.958,129] <err> os: Current thread: 0x200018c0 (ENCODER) GW [00:00:29.958,129] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
Problem #2 - Connection constantly disconnects
There seems to be a possible timing issue when connecting a headset stream, then starting the scan / connection to the other headset.
nRF5340 Audio nRF5340 Audio DK cpuapp NCS base version: 2.4.0 Cmake run : Tue Jun 13 05:32:12 2023 GW [00:00:00.259,490] <inf> fw_info: ------- DEBUG BUILD ------- GW [00:00:00.259,521] <inf> fw_info: Compiled for GATEWAY device GW [00:00:00.270,141] <inf> board_version: Compatible board/HW version found: 1.0.0 GW [00:00:00.307,037] <wrn> bt_hci_core: Controller to host flow control not supported GW [00:00:00.310,150] <inf> bt_hci_core: No ID address. App must call settings_load() GW [00:00:00.310,241] <inf> ble: MAC: 00:00:00:00:00:00 (public) GW [00:00:00.310,791] <inf> ble: Controller version: 3349 GW [00:00:00.313,781] <err> settings: set-value failure. key: bt/name error(-2) GW [00:00:00.313,873] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random) GW [00:00:00.313,903] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8 GW [00:00:00.313,903] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15 GW [00:00:00.432,067] <inf> cis_gateway: Scanning successfully started GW [00:00:00.517,395] <inf> cis_gateway: Connected: 60:20:E9:4A:5E:67 (random) GW [00:00:02.330,261] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:02.330,291] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:02.599,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:03.478,485] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:03.478,485] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005698 GW [00:00:03.479,217] <inf> cis_gateway: Scanning successfully started GW [00:00:03.625,518] <inf> cis_gateway: Connected: 4B:D7:D6:29:40:2F (random) GW [00:00:03.878,540] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:03.918,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:03.918,579] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:04.308,471] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:04.308,593] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:04.368,713] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:04.368,713] <inf> cis_gateway: LEFT sink stream configured GW [00:00:04.369,262] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:04.718,963] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:05.078,552] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:05.378,601] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:05.419,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:05.419,189] <inf> cis_gateway: LEFT source stream configured GW [00:00:05.489,044] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:05.489,105] <inf> cis_gateway: Enable stream 0x20001f0c GW [00:00:05.489,593] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:05.489,654] <inf> cis_gateway: Enable stream 0x20001cec GW [00:00:05.521,972] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:05.522,003] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:05.528,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:05.539,001] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:05.539,855] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:05.540,100] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13 GW [00:00:05.540,130] <wrn> cis_gateway: Unknown stream GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13 GW [00:00:05.790,588] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:06.039,703] <wrn> bt_conn: no transition connecting GW [00:00:06.040,222] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:06.040,496] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:06.040,496] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13 GW [00:00:06.040,496] <wrn> cis_gateway: Unknown stream GW [00:00:06.040,527] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13 GW [00:00:06.502,532] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:06.502,532] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760 GW [00:00:06.502,532] <inf> cis_gateway: All headsets connected GW [00:00:06.872,558] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:06.912,567] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:06.912,597] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:07.292,510] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:07.292,633] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:07.313,171] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:07.313,201] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:07.313,751] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:07.662,567] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:08.012,603] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:08.272,644] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:08.313,201] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:08.313,232] <inf> cis_gateway: RIGHT source stream configured GW [00:00:08.372,619] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:08.372,680] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:08.373,138] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:08.373,199] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:08.442,596] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:08.443,511] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:10.444,152] <err> cis_gateway: Failed to establish CIS, ret = -16 GW [00:00:10.463,104] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:10.463,531] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13 GW [00:00:10.463,562] <wrn> cis_gateway: Unknown stream GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13 GW [00:00:10.464,843] <wrn> cis_gateway: Unknown stream GW [00:00:10.464,935] <inf> cis_gateway: Disconnected: 4B:D7:D6:29:40:2F (random) (reason 0x16) GW [00:00:10.465,576] <inf> cis_gateway: Scanning successfully started GW [00:00:10.861,907] <inf> cis_gateway: Connected: 44:EF:53:25:6B:96 (random) GW [00:00:12.492,218] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:12.492,218] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:12.670,776] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:13.642,730] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:13.642,730] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760 GW [00:00:13.642,730] <inf> cis_gateway: All headsets connected GW [00:00:14.002,777] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:14.052,764] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:14.052,795] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:14.422,698] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:14.422,821] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:14.463,378] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:14.463,409] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:14.472,869] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:14.832,763] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:15.202,789] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:15.472,839] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:15.512,969] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:15.512,969] <inf> cis_gateway: RIGHT source stream configured GW [00:00:15.573,303] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:15.573,333] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:15.583,007] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:15.583,068] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:15.613,250] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:15.633,239] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:15.633,636] <wrn> bt_conn: no transition connecting GW [00:00:17.633,911] <err> cis_gateway: Failed to establish CIS, ret = -16 GW [00:00:17.653,320] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:17.653,747] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:17.653,747] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13 GW [00:00:17.653,778] <wrn> cis_gateway: Unknown stream GW [00:00:17.653,778] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13 GW [00:00:17.654,998] <wrn> cis_gateway: Unknown stream GW [00:00:17.655,090] <inf> cis_gateway: Disconnected: 44:EF:53:25:6B:96 (random) (reason 0x16) GW [00:00:17.655,731] <inf> cis_gateway: Scanning successfully started GW [00:00:18.001,403] <inf> cis_gateway: Connected: 48:1A:C0:46:05:23 (random) GW [00:00:19.722,412] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:19.722,412] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:19.901,489] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:20.742,919] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:20.742,919] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760 GW [00:00:20.742,919] <inf> cis_gateway: All headsets connected GW [00:00:21.082,977] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:21.132,965] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:21.132,995] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:21.482,910] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:21.483,001] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:21.513,580] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:21.513,580] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:21.514,739] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:21.872,955] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:22.162,994] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:22.413,024] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:22.453,155] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:22.453,155] <inf> cis_gateway: RIGHT source stream configured GW [00:00:22.513,031] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:22.513,061] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:22.513,519] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:22.513,580] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:22.552,978] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:22.563,446] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:22.563,812] <wrn> bt_conn: no transition connecting GW [00:00:24.564,117] <err> cis_gateway: Failed to establish CIS, ret = -16 GW [00:00:24.573,516] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:24.573,944] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:24.573,944] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13 GW [00:00:24.573,944] <wrn> cis_gateway: Unknown stream GW [00:00:24.573,974] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13 GW [00:00:24.575,195] <wrn> cis_gateway: Unknown stream GW [00:00:24.575,286] <inf> cis_gateway: Disconnected: 48:1A:C0:46:05:23 (random) (reason 0x16) GW [00:00:24.575,927] <inf> cis_gateway: Scanning successfully started GW [00:00:25.193,725] <inf> cis_gateway: Connected: 7B:A7:91:0C:AE:5E (random) GW [00:00:27.002,624] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:27.002,624] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:27.181,182] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:28.093,109] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:28.093,139] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760 GW [00:00:28.093,139] <inf> cis_gateway: All headsets connected GW [00:00:28.453,155] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:28.503,173] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:28.503,204] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:28.843,109] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:28.843,231] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:28.863,769] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:28.863,800] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:28.864,349] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:29.163,146] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:29.473,205] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:29.793,273] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:29.833,343] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:29.833,374] <inf> cis_gateway: RIGHT source stream configured GW [00:00:29.893,707] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:29.893,737] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:29.894,195] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:29.894,256] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:29.933,197] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:29.943,634] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:29.944,030] <wrn> bt_conn: no transition connecting GW [00:00:31.944,305] <err> cis_gateway: Failed to establish CIS, ret = -16 GW [00:00:31.954,101] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:31.954,528] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:31.954,528] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13 GW [00:00:31.954,559] <wrn> cis_gateway: Unknown stream GW [00:00:31.954,559] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13 GW [00:00:31.955,810] <wrn> cis_gateway: Unknown stream GW [00:00:31.955,902] <inf> cis_gateway: Disconnected: 7B:A7:91:0C:AE:5E (random) (reason 0x16) GW [00:00:31.956,542] <inf> cis_gateway: Scanning successfully started GW [00:00:32.355,743] <inf> cis_gateway: Connected: 61:E7:90:D0:18:37 (random) GW [00:00:33.892,791] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:33.892,822] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:34.071,380] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:35.243,316] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:35.243,347] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760 GW [00:00:35.243,347] <inf> cis_gateway: All headsets connected GW [00:00:35.583,374] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:35.623,382] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:35.623,413] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:35.933,319] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:35.933,410] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:35.973,968] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:35.973,999] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:35.983,489] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:36.313,354] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:36.603,393] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:36.863,433] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:36.903,564] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:36.903,564] <inf> cis_gateway: RIGHT source stream configured GW [00:00:36.953,887] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:36.953,948] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:36.963,592] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:36.963,653] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:36.993,835] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:37.023,376] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:37.023,773] <wrn> bt_conn: no transition connecting GW [00:00:39.024,047] <err> cis_gateway: Failed to establish CIS, ret = -16 GW [00:00:39.033,905] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:39.034,332] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13 GW [00:00:39.034,362] <wrn> cis_gateway: Unknown stream GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13 GW [00:00:39.035,583] <wrn> cis_gateway: Unknown stream GW [00:00:39.035,705] <inf> cis_gateway: Disconnected: 61:E7:90:D0:18:37 (random) (reason 0x16) GW [00:00:39.036,346] <inf> cis_gateway: Scanning successfully started GW [00:00:39.435,546] <inf> cis_gateway: Connected: 58:44:76:E7:1F:C8 (random) GW [00:00:41.153,015] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:41.153,015] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:41.421,569] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:42.353,515] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:42.353,546] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760 GW [00:00:42.353,546] <inf> cis_gateway: All headsets connected GW [00:00:42.703,552] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:42.743,560] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:42.743,591] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default GW [00:00:43.113,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:43.113,616] <err> cis_gateway: <<<<< discover_source >>>>> GW [00:00:43.163,726] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:43.163,757] <inf> cis_gateway: RIGHT sink stream configured GW [00:00:43.164,276] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:43.473,541] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>> GW [00:00:43.763,610] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:44.023,651] <err> cis_gateway: <<<<< discover_source_cb >>>>> GW [00:00:44.044,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>> GW [00:00:44.044,219] <inf> cis_gateway: RIGHT source stream configured GW [00:00:44.064,086] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:44.064,147] <inf> cis_gateway: Enable stream 0x200023cc GW [00:00:44.064,605] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>> GW [00:00:44.064,636] <inf> cis_gateway: Enable stream 0x200021ac GW [00:00:44.074,127] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:44.084,045] <err> cis_gateway: <<<<< stream_enabled_cb >>>>> GW [00:00:44.084,411] <wrn> bt_conn: no transition connecting GW [00:00:46.084,686] <err> cis_gateway: Failed to establish CIS, ret = -16 GW [00:00:46.094,116] <wrn> bt_hci_core: opcode 0x206f status 0x0c GW [00:00:46.094,543] <wrn> bt_hci_core: opcode 0x206f status 0x12 GW [00:00:46.094,543] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13 GW [00:00:46.094,543] <wrn> cis_gateway: Unknown stream GW [00:00:46.094,573] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13 GW [00:00:46.095,794] <wrn> cis_gateway: Unknown stream GW [00:00:46.095,886] <inf> cis_gateway: Disconnected: 58:44:76:E7:1F:C8 (random) (reason 0x16) GW [00:00:46.096,527] <inf> cis_gateway: Scanning successfully started GW [00:00:46.213,775] <inf> cis_gateway: Connected: 40:EB:E0:AD:11:02 (random) GW [00:00:47.311,126] <wrn> cis_gateway: Unknown stream GW [00:00:47.311,218] <inf> cis_gateway: Disconnected: 60:20:E9:4A:5E:67 (random) (reason 0x13) GW [00:00:47.311,889] <inf> cis_gateway: Scanning successfully started GW [00:00:47.763,641] <err> cis_gateway: <<<<< security_changed_cb >>>>> GW [00:00:47.763,641] <err> cis_gateway: <<<<< discover_sink >>>>> GW [00:00:47.843,658] <err> cis_gateway: <<<<< discover_sink_cb >>>>> GW [00:00:47.843,658] <err> cis_gateway: Discovery failed: 14 GW [00:00:47.843,811] <inf> cis_gateway: Disconnected: 40:EB:E0:AD:11:02 (random) (reason 0x13) GW [00:00:47.843,811] <wrn> cis_gateway: Connection not found GW [00:00:47.843,841] <wrn> cis_gateway: Unknown connection GW [00:00:47.843,841] <inf> cis_gateway: Scanning successfully started
Problem #3 - Source audio not always acquired
The next issue that I have seen is if you connect to the headset successfully, the first time the connection is made, the source (headset microphone) audio will play on the headphone jack every time. The issue comes when you put the headset back in the case and close the lid, then re-open and take the headset out. The next successful connection will have a 50% chance of the microphone audio playing on the headphone jack. This 50% chance of source audio working happens every time you put the headphones back in the case and take them out again.
One note: I have also tested this on a non-audio DK, with the source audio being fed back into the headset sink. For this reason, I don't think the issue has to do with the I2S or HW codec etc.
Lastly, it looks like the audio in data is still being received since the callback for Rx data is still being called.
I have attached an example project. It is the LE audio demo code with minor modifications. Search for <Modified> in the code to see what I modified. The modifications were only made in prj.conf and le_audio_cis_gateway.c
