nRF5340 LE Audio Samsung Galaxy Buds2 Pro - Multiple Problems
I using the Samsung Galaxy Buds2 Pro headphones to connect to the latest v2.4.0 nRF SDK. I am using the LE Audio demo code as gateway. The demo connects successfully out of the box to the headphones, with some modifications to the prj.conf file, using the nRF5340 Audio DK. For my project needs, I have both source and sink enabled via CONFIG_STREAM_BIDIRECTIONAL.
CONFIG_AUDIO_DEV=2
CONFIG_BT_DEVICE_NAME="Galaxy Buds2 Pro"
#QOS will fail without this
CONFIG_BT_AUDIO_PRESENTATION_DELAY_US=40000
#Seem to get failed to discover without this
CONFIG_BLE_ACL_CONN_INTERVAL=72
CONFIG_BT_AUDIO_MAX_TRANSPORT_LATENCY_MS=100
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_BT_AUDIO_RETRANSMITS=2
CONFIG_BT_BAP_UNICAST_CLIENT_ASE_SRC_COUNT=2
CONFIG_STREAM_BIDIRECTIONAL=y
CONFIG_WALKIE_TALKIE_DEMO=y
CONFIG_AUDIO_SOURCE_I2S=y
CONFIG_BT_BONDABLE=n
CONFIG_BT_VCP_VOL_CTLR=n
Problem #1 - Controller Crashes
If you connect to the right headset first, then connect to the left headset, the"ble5-ctr-rpmsg_3349" controller crashes. I believe this also happened on the 3330 controller as well.
The crash happens after calling bt_bap_stream_start on the Left SINK. This only happens if you connect to the right headset first, followed by the left.
Once the controller crashes, the next call to bt_hci_cmd_send_sync will fail on semaphore take "timeout with err -11". This usually happens either on the next le_audio_send stream send OR on the ble_core.c watchdog call to net_core_ctrl_version_get.
Log:
         nRF5340 Audio nRF5340 Audio DK cpuapp
         NCS base version: 2.4.0
         Cmake run : Tue Jun 13 05:32:12 2023
GW [00:00:00.258,209] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.258,239] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.268,859] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.305,755] <wrn> bt_hci_core: Controller to host flow control not supported
GW [00:00:00.308,898] <inf> bt_hci_core: No ID address. App must call settings_load()
GW [00:00:00.308,959] <inf> ble: MAC: 00:00:00:00:00:00 (public)
GW [00:00:00.309,509] <inf> ble: Controller version: 3349
GW [00:00:00.312,500] <err> settings: set-value failure. key: bt/name error(-2)
GW [00:00:00.312,591] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random)
GW [00:00:00.312,622] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
GW [00:00:00.312,622] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
GW [00:00:00.430,725] <inf> cis_gateway: Scanning successfully started
GW [00:00:05.272,583] <inf> cis_gateway: Connected: 7F:3B:83:F5:3B:A8 (random)
GW [00:00:07.189,117] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:07.189,117] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:07.457,885] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.467,346] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:08.467,346] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005698
GW [00:00:08.468,078] <inf> cis_gateway: Scanning successfully started
GW [00:00:08.857,391] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.917,388] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.917,419] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:09.217,315] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:09.217,437] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:09.257,995] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:09.258,026] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:09.258,544] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:09.577,362] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:09.857,421] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:10.107,452] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:10.147,583] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:10.147,583] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:10.207,916] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:10.207,946] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:10.208,404] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:10.208,465] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:10.257,415] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.258,331] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.427,459] <err> cis_gateway: <<<<< stream_started_cb >>>>>
GW [00:00:10.427,459] <inf> cis_gateway: Stream 0x200021ac started
GW [00:00:10.453,308] <wrn> bt_hci_core: opcode 0x2061 status 0x0c
GW [00:00:10.921,203] <err> cis_gateway: <<<<< stream_started_cb >>>>>
GW [00:00:10.921,234] <inf> cis_gateway: Stream 0x200023cc started
GW [00:00:12.058,898] <inf> cis_gateway: Connected: 71:09:B2:4D:BC:12 (random)
GW [00:00:14.863,433] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:14.863,464] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:15.131,622] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:15.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 5000
GW [00:00:16.901,458] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:16.901,458] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005760
GW [00:00:16.901,458] <inf> cis_gateway: All headsets connected
GW [00:00:17.471,496] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:17.531,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:17.531,524] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:18.071,441] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:18.071,563] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:18.141,662] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:18.141,693] <inf> cis_gateway: LEFT sink stream configured
GW [00:00:18.151,611] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:18.651,519] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:19.131,591] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:19.551,605] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:19.641,693] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:19.641,723] <inf> cis_gateway: LEFT source stream configured
GW [00:00:19.751,586] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:19.751,617] <inf> cis_gateway: Enable stream 0x20001f0c
GW [00:00:19.761,718] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:19.761,779] <inf> cis_gateway: Enable stream 0x20001cec
GW [00:00:19.821,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:19.851,562] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:19.857,177] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:19.942,169] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:19.962,158] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:20.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 10000
GW [00:00:25.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 15000
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:330
        command opcode 0x2061 timeout with err -11
GW [00:00:29.958,007] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000002  r2/a3:  0x00000001
GW [00:00:29.958,038] <err> os: r3/a4:  0x0000014a r12/ip:  0x00407fd0 r14/lr:  0x00020c95
GW [00:00:29.958,038] <err> os:  xpsr:  0x41100000
GW [00:00:29.958,038] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x0000001c  s[ 2]:  0x00000000  s[ 3]:  0x000000a2
GW [00:00:29.958,038] <err> os: s[ 4]:  0x00000010  s[ 5]:  0x0000001a  s[ 6]:  0x00000000  s[ 7]:  0x000000a2
GW [00:00:29.958,068] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x000000a2  s[10]:  0x00000003  s[11]:  0x00000002
GW [00:00:29.958,068] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000031  s[15]:  0x00000000
GW [00:00:29.958,068] <err> os: fpscr:  0x20000010
GW [00:00:29.958,099] <err> os: Faulting instruction address (r15/pc): 0x00020ca0
GW [00:00:29.958,099] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
GW [00:00:29.958,129] <err> os: Current thread: 0x200018c0 (ENCODER)
GW [00:00:29.958,129] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
Problem #2 - Connection constantly disconnects
There seems to be a possible timing issue when connecting a headset stream, then starting the scan / connection to the other headset.
After starting the left headset stream, when you start scanning / connecting to the right headset, the left headset drops connection. It happens as soon as the right headset starts scan / connection. I have noticed that if you start searching for the right headset later in time / further in the code connection sequence, this happens much less frequently. The ACL scan is originally in unicast_client_location_cb. If I move the ACL scan to discover_source_cb or stream_enabled_cb, the issue happens much less frequently. If this is time dependent, then this is also likely a problem because as we add code to the rest of the system, time could change again and cause the issue to come back.
GW [00:00:00.259,490] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.259,521] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.270,141] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.307,037] <wrn> bt_hci_core: Controller to host flow control not supported
GW [00:00:00.310,150] <inf> bt_hci_core: No ID address. App must call settings_load()
GW [00:00:00.310,241] <inf> ble: MAC: 00:00:00:00:00:00 (public)
GW [00:00:00.310,791] <inf> ble: Controller version: 3349
GW [00:00:00.313,781] <err> settings: set-value failure. key: bt/name error(-2)
GW [00:00:00.313,873] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random)
GW [00:00:00.313,903] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
GW [00:00:00.313,903] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
GW [00:00:00.432,067] <inf> cis_gateway: Scanning successfully started
GW [00:00:00.517,395] <inf> cis_gateway: Connected: 60:20:E9:4A:5E:67 (random)
GW [00:00:02.330,261] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:02.330,291] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:02.599,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.478,485] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:03.478,485] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005698
GW [00:00:03.479,217] <inf> cis_gateway: Scanning successfully started
GW [00:00:03.625,518] <inf> cis_gateway: Connected: 4B:D7:D6:29:40:2F (random)
GW [00:00:03.878,540] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.918,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.918,579] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:04.308,471] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:04.308,593] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:04.368,713] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:04.368,713] <inf> cis_gateway: LEFT sink stream configured
GW [00:00:04.369,262] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:04.718,963] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:05.078,552] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:05.378,601] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:05.419,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:05.419,189] <inf> cis_gateway: LEFT source stream configured
GW [00:00:05.489,044] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:05.489,105] <inf> cis_gateway: Enable stream 0x20001f0c
GW [00:00:05.489,593] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:05.489,654] <inf> cis_gateway: Enable stream 0x20001cec
GW [00:00:05.521,972] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:05.522,003] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:05.528,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:05.539,001] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:05.539,855] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:05.540,100] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13
GW [00:00:05.540,130] <wrn> cis_gateway: Unknown stream
GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13
GW [00:00:05.790,588] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.039,703] <wrn> bt_conn: no transition connecting
GW [00:00:06.040,222] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:06.040,496] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:06.040,496] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13
GW [00:00:06.040,496] <wrn> cis_gateway: Unknown stream
GW [00:00:06.040,527] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13
GW [00:00:06.502,532] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:06.502,532] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:06.502,532] <inf> cis_gateway: All headsets connected
GW [00:00:06.872,558] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.912,567] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.912,597] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:07.292,510] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:07.292,633] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:07.313,171] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:07.313,201] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:07.313,751] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:07.662,567] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:08.012,603] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:08.272,644] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:08.313,201] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:08.313,232] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:08.372,619] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:08.372,680] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:08.373,138] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:08.373,199] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:08.442,596] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:08.443,511] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.444,152] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:10.463,104] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:10.463,531] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:10.463,562] <wrn> cis_gateway: Unknown stream
GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:10.464,843] <wrn> cis_gateway: Unknown stream
GW [00:00:10.464,935] <inf> cis_gateway: Disconnected: 4B:D7:D6:29:40:2F (random) (reason 0x16)
GW [00:00:10.465,576] <inf> cis_gateway: Scanning successfully started
GW [00:00:10.861,907] <inf> cis_gateway: Connected: 44:EF:53:25:6B:96 (random)
GW [00:00:12.492,218] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:12.492,218] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:12.670,776] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:13.642,730] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:13.642,730] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:13.642,730] <inf> cis_gateway: All headsets connected
GW [00:00:14.002,777] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.052,764] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.052,795] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:14.422,698] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.422,821] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:14.463,378] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:14.463,409] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:14.472,869] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:14.832,763] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:15.202,789] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:15.472,839] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:15.512,969] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:15.512,969] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:15.573,303] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:15.573,333] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:15.583,007] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:15.583,068] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:15.613,250] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:15.633,239] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:15.633,636] <wrn> bt_conn: no transition connecting
GW [00:00:17.633,911] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:17.653,320] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:17.653,747] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:17.653,747] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:17.653,778] <wrn> cis_gateway: Unknown stream
GW [00:00:17.653,778] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:17.654,998] <wrn> cis_gateway: Unknown stream
GW [00:00:17.655,090] <inf> cis_gateway: Disconnected: 44:EF:53:25:6B:96 (random) (reason 0x16)
GW [00:00:17.655,731] <inf> cis_gateway: Scanning successfully started
GW [00:00:18.001,403] <inf> cis_gateway: Connected: 48:1A:C0:46:05:23 (random)
GW [00:00:19.722,412] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:19.722,412] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:19.901,489] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:20.742,919] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:20.742,919] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:20.742,919] <inf> cis_gateway: All headsets connected
GW [00:00:21.082,977] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.132,965] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.132,995] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:21.482,910] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.483,001] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:21.513,580] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:21.513,580] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:21.514,739] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:21.872,955] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:22.162,994] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:22.413,024] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:22.453,155] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:22.453,155] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:22.513,031] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:22.513,061] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:22.513,519] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:22.513,580] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:22.552,978] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:22.563,446] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:22.563,812] <wrn> bt_conn: no transition connecting
GW [00:00:24.564,117] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:24.573,516] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:24.573,944] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:24.573,944] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:24.573,944] <wrn> cis_gateway: Unknown stream
GW [00:00:24.573,974] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:24.575,195] <wrn> cis_gateway: Unknown stream
GW [00:00:24.575,286] <inf> cis_gateway: Disconnected: 48:1A:C0:46:05:23 (random) (reason 0x16)
GW [00:00:24.575,927] <inf> cis_gateway: Scanning successfully started
GW [00:00:25.193,725] <inf> cis_gateway: Connected: 7B:A7:91:0C:AE:5E (random)
GW [00:00:27.002,624] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:27.002,624] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:27.181,182] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.093,109] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:28.093,139] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:28.093,139] <inf> cis_gateway: All headsets connected
GW [00:00:28.453,155] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.503,173] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.503,204] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:28.843,109] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.843,231] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:28.863,769] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:28.863,800] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:28.864,349] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.163,146] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:29.473,205] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.793,273] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.833,343] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:29.833,374] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:29.893,707] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:29.893,737] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:29.894,195] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:29.894,256] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:29.933,197] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:29.943,634] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:29.944,030] <wrn> bt_conn: no transition connecting
GW [00:00:31.944,305] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:31.954,101] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:31.954,528] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:31.954,528] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:31.954,559] <wrn> cis_gateway: Unknown stream
GW [00:00:31.954,559] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:31.955,810] <wrn> cis_gateway: Unknown stream
GW [00:00:31.955,902] <inf> cis_gateway: Disconnected: 7B:A7:91:0C:AE:5E (random) (reason 0x16)
GW [00:00:31.956,542] <inf> cis_gateway: Scanning successfully started
GW [00:00:32.355,743] <inf> cis_gateway: Connected: 61:E7:90:D0:18:37 (random)
GW [00:00:33.892,791] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:33.892,822] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:34.071,380] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.243,316] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:35.243,347] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:35.243,347] <inf> cis_gateway: All headsets connected
GW [00:00:35.583,374] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.623,382] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.623,413] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:35.933,319] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.933,410] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:35.973,968] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:35.973,999] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:35.983,489] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.313,354] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:36.603,393] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.863,433] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.903,564] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:36.903,564] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:36.953,887] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:36.953,948] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:36.963,592] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:36.963,653] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:36.993,835] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:37.023,376] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:37.023,773] <wrn> bt_conn: no transition connecting
GW [00:00:39.024,047] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:39.033,905] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:39.034,332] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:39.034,362] <wrn> cis_gateway: Unknown stream
GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:39.035,583] <wrn> cis_gateway: Unknown stream
GW [00:00:39.035,705] <inf> cis_gateway: Disconnected: 61:E7:90:D0:18:37 (random) (reason 0x16)
GW [00:00:39.036,346] <inf> cis_gateway: Scanning successfully started
GW [00:00:39.435,546] <inf> cis_gateway: Connected: 58:44:76:E7:1F:C8 (random)
GW [00:00:41.153,015] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:41.153,015] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:41.421,569] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.353,515] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:42.353,546] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:42.353,546] <inf> cis_gateway: All headsets connected
GW [00:00:42.703,552] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.743,560] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.743,591] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:43.113,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:43.113,616] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:43.163,726] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:43.163,757] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:43.164,276] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:43.473,541] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:43.763,610] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:44.023,651] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:44.044,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:44.044,219] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:44.064,086] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:44.064,147] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:44.064,605] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:44.064,636] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:44.074,127] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:44.084,045] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:44.084,411] <wrn> bt_conn: no transition connecting
GW [00:00:46.084,686] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:46.094,116] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:46.094,543] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:46.094,543] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:46.094,543] <wrn> cis_gateway: Unknown stream
GW [00:00:46.094,573] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:46.095,794] <wrn> cis_gateway: Unknown stream
GW [00:00:46.095,886] <inf> cis_gateway: Disconnected: 58:44:76:E7:1F:C8 (random) (reason 0x16)
GW [00:00:46.096,527] <inf> cis_gateway: Scanning successfully started
GW [00:00:46.213,775] <inf> cis_gateway: Connected: 40:EB:E0:AD:11:02 (random)
GW [00:00:47.311,126] <wrn> cis_gateway: Unknown stream
GW [00:00:47.311,218] <inf> cis_gateway: Disconnected: 60:20:E9:4A:5E:67 (random) (reason 0x13)
GW [00:00:47.311,889] <inf> cis_gateway: Scanning successfully started
GW [00:00:47.763,641] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:47.763,641] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:47.843,658] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:47.843,658] <err> cis_gateway: Discovery failed: 14
GW [00:00:47.843,811] <inf> cis_gateway: Disconnected: 40:EB:E0:AD:11:02 (random) (reason 0x13)
GW [00:00:47.843,811] <wrn> cis_gateway: Connection not found
GW [00:00:47.843,841] <wrn> cis_gateway: Unknown connection
GW [00:00:47.843,841] <inf> cis_gateway: Scanning successfully started
Problem #3 - Source audio not always acquired
The next issue that I have seen is if you connect to the headset successfully, the first time the connection is made, the source (headset microphone) audio will play on the headphone jack every time. The issue comes when you put the headset back in the case and close the lid, then re-open and take the headset out. The next successful connection will have a 50% chance of the microphone audio playing on the headphone jack. This 50% chance of source audio working happens every time you put the headphones back in the case and take them out again.
One note: I have also tested this on a non-audio DK, with the source audio being fed back into the headset sink. For this reason, I don't think the issue has to do with the I2S or HW codec etc.
Lastly, it looks like the audio in data is still being received since the callback for Rx data is still being called.
I have attached an example project. It is the LE audio demo code with minor modifications. Search for <Modified> in the code to see what I modified. The modifications were only made in prj.conf and le_audio_cis_gateway.c
nrf2_4_0_AudioDemo.zip
  • Hello again,
    Thank you for your patience with this, and for the detailed reports of your findings.
    Unfortunately our primary tester of the Galaxy Buds 2 Pro are out of office this week, and will not be back until Monday the 26th of June.
    We will update you here once we have gotten a chance to run the bidirectional tests of the Galaxy Buds 2 Pro for ourselves, and see if we can identify the root causes of the issues that you describe here.
    I thought I should mention that we are targeting a new controller release towards the end of June, so that should be right around the corner. The new controller contains fixes for some issues that sounds similar to the issues you describe here, but since it is not an exact match of the description it is too soon to say whether it will improve the situation in this case.
    Karl
  • Hello again,
    I had a discussion with our primary tester of the Galaxy Buds 2 Pro and he said he was able to run the gateway with the Galaxy Buds 2 Pro as the headset devices in the bidirectional configuration 'out of the box' without issue.
    He specified that he made these changes to the prj.conf of the default nRF5340 LE Audio reference application from the nRF Connect SDK v2.4.0:
    CONFIG_BLE_ACL_CONN_INTERVAL=36
    CONFIG_BT_LOG_SNIFFER_INFO=y
    Could you give this a try and see if you are able to see the same results?
    Please also make sure that you are using the R510XXU0AWA5 software version on the Galaxy Buds 2 Pro as well.
    Could you also elaborate on how you specifically test to connect the right earbud first?
    I note from your earlier comment that you ask if we have any insight on how to achieve this, but to us it seems that both earbuds needs to be removed from their case before the connections will be initiated, and so we have not been able to force the connection to start with the right earbud in our attempts to replicate the behavior you describe. From our tests it seems that the only way to note this is to first connect to one of the earbud, then pull for the earbuds location, which you also note.
    In regards to Problem#3 it is a known issue to us that bonding with the earbuds are causing issues, which is why we have turned this off in our tests currently. I understand that you also had this disabled initially, but some later comments seem to indicate that you are using bonding in your testing - is your current project depending on being able to bond with the Galaxy Buds Pro 2, or was this done primarily as part of functional testing?
    Lastly, I was unfortunately wrong in my previous comment about our primary tester's availability next week - he will be out of office for the entire duration of next week as well, and thus unable to test until Monday 3rd July at the earliest.
    I have written an email to Michael Knight about this along with my suggestions for how we should proceed with the debugging in the case that you are not able to have this working as expected (without bonding, and without controller crashes) with the approach mentioned above. I have also asked my colleague Maria to follow up on your ticket while I am out of office for the next three weeks.
    Karl
  • Hey Karl, is there any way we could get a pre-release (beta) version of the controller so we can test to see if it fixes the issue. We understand that it is not complete yet and may still have issues being resolved but we could give some feedback and initially see if it resolves the issue. We have a deadline next week to meet so it would be nice to at least test out.
    I'm following this up while Karl is out of office.
    We are working on a way to test this further while our main tester is out of office.
    I will investigate if this is possible.
    Meanwhile: could you please address the questions from Karl's latest reply?
    Maria
  • Hello again,
    We can't provide a pre-release version of the controller. You will have to wait for the official release.
    We also don't have a guarantee for a fix because of the descriptions not matching (as Karl pointed out).
    Sorry for not coming back with a positive update.
    I would still like to hear your comments on Karl's latest questions.
    Maria
