nRF5340 LE Audio Samsung Galaxy Buds2 Pro - Multiple Problems
I using the Samsung Galaxy Buds2 Pro headphones to connect to the latest v2.4.0 nRF SDK. I am using the LE Audio demo code as gateway. The demo connects successfully out of the box to the headphones, with some modifications to the prj.conf file, using the nRF5340 Audio DK. For my project needs, I have both source and sink enabled via CONFIG_STREAM_BIDIRECTIONAL.
CONFIG_AUDIO_DEV=2
CONFIG_BT_DEVICE_NAME="Galaxy Buds2 Pro"
#QOS will fail without this
CONFIG_BT_AUDIO_PRESENTATION_DELAY_US=40000
#Seem to get failed to discover without this
CONFIG_BLE_ACL_CONN_INTERVAL=72
CONFIG_BT_AUDIO_MAX_TRANSPORT_LATENCY_MS=100
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_BT_AUDIO_RETRANSMITS=2
CONFIG_BT_BAP_UNICAST_CLIENT_ASE_SRC_COUNT=2
CONFIG_STREAM_BIDIRECTIONAL=y
CONFIG_WALKIE_TALKIE_DEMO=y
CONFIG_AUDIO_SOURCE_I2S=y
CONFIG_BT_BONDABLE=n
CONFIG_BT_VCP_VOL_CTLR=n
Problem #1 - Controller Crashes
If you connect to the right headset first, then connect to the left headset, the"ble5-ctr-rpmsg_3349" controller crashes. I believe this also happened on the 3330 controller as well.
The crash happens after calling bt_bap_stream_start on the Left SINK. This only happens if you connect to the right headset first, followed by the left.
Once the controller crashes, the next call to bt_hci_cmd_send_sync will fail on semaphore take "timeout with err -11". This usually happens either on the next le_audio_send stream send OR on the ble_core.c watchdog call to net_core_ctrl_version_get.
Log:
         nRF5340 Audio nRF5340 Audio DK cpuapp
         NCS base version: 2.4.0
         Cmake run : Tue Jun 13 05:32:12 2023
GW [00:00:00.258,209] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.258,239] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.268,859] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.305,755] <wrn> bt_hci_core: Controller to host flow control not supported
GW [00:00:00.308,898] <inf> bt_hci_core: No ID address. App must call settings_load()
GW [00:00:00.308,959] <inf> ble: MAC: 00:00:00:00:00:00 (public)
GW [00:00:00.309,509] <inf> ble: Controller version: 3349
GW [00:00:00.312,500] <err> settings: set-value failure. key: bt/name error(-2)
GW [00:00:00.312,591] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random)
GW [00:00:00.312,622] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
GW [00:00:00.312,622] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
GW [00:00:00.430,725] <inf> cis_gateway: Scanning successfully started
GW [00:00:05.272,583] <inf> cis_gateway: Connected: 7F:3B:83:F5:3B:A8 (random)
GW [00:00:07.189,117] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:07.189,117] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:07.457,885] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.467,346] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:08.467,346] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005698
GW [00:00:08.468,078] <inf> cis_gateway: Scanning successfully started
GW [00:00:08.857,391] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.917,388] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.917,419] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:09.217,315] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:09.217,437] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:09.257,995] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:09.258,026] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:09.258,544] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:09.577,362] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:09.857,421] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:10.107,452] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:10.147,583] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:10.147,583] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:10.207,916] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:10.207,946] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:10.208,404] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:10.208,465] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:10.257,415] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.258,331] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.427,459] <err> cis_gateway: <<<<< stream_started_cb >>>>>
GW [00:00:10.427,459] <inf> cis_gateway: Stream 0x200021ac started
GW [00:00:10.453,308] <wrn> bt_hci_core: opcode 0x2061 status 0x0c
GW [00:00:10.921,203] <err> cis_gateway: <<<<< stream_started_cb >>>>>
GW [00:00:10.921,234] <inf> cis_gateway: Stream 0x200023cc started
GW [00:00:12.058,898] <inf> cis_gateway: Connected: 71:09:B2:4D:BC:12 (random)
GW [00:00:14.863,433] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:14.863,464] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:15.131,622] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:15.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 5000
GW [00:00:16.901,458] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:16.901,458] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005760
GW [00:00:16.901,458] <inf> cis_gateway: All headsets connected
GW [00:00:17.471,496] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:17.531,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:17.531,524] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:18.071,441] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:18.071,563] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:18.141,662] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:18.141,693] <inf> cis_gateway: LEFT sink stream configured
GW [00:00:18.151,611] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:18.651,519] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:19.131,591] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:19.551,605] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:19.641,693] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:19.641,723] <inf> cis_gateway: LEFT source stream configured
GW [00:00:19.751,586] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:19.751,617] <inf> cis_gateway: Enable stream 0x20001f0c
GW [00:00:19.761,718] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:19.761,779] <inf> cis_gateway: Enable stream 0x20001cec
GW [00:00:19.821,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:19.851,562] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:19.857,177] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:19.942,169] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:19.962,158] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:20.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 10000
GW [00:00:25.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 15000
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:330
        command opcode 0x2061 timeout with err -11
GW [00:00:29.958,007] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000002  r2/a3:  0x00000001
GW [00:00:29.958,038] <err> os: r3/a4:  0x0000014a r12/ip:  0x00407fd0 r14/lr:  0x00020c95
GW [00:00:29.958,038] <err> os:  xpsr:  0x41100000
GW [00:00:29.958,038] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x0000001c  s[ 2]:  0x00000000  s[ 3]:  0x000000a2
GW [00:00:29.958,038] <err> os: s[ 4]:  0x00000010  s[ 5]:  0x0000001a  s[ 6]:  0x00000000  s[ 7]:  0x000000a2
GW [00:00:29.958,068] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x000000a2  s[10]:  0x00000003  s[11]:  0x00000002
GW [00:00:29.958,068] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000031  s[15]:  0x00000000
GW [00:00:29.958,068] <err> os: fpscr:  0x20000010
GW [00:00:29.958,099] <err> os: Faulting instruction address (r15/pc): 0x00020ca0
GW [00:00:29.958,099] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
GW [00:00:29.958,129] <err> os: Current thread: 0x200018c0 (ENCODER)
GW [00:00:29.958,129] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
Problem #2 - Connection constantly disconnects
There seems to be a possible timing issue when connecting a headset stream, then starting the scan / connection to the other headset.
After starting the left headset stream, when you start scanning / connecting to the right headset, the left headset drops connection. It happens as soon as the right headset starts scan / connection. I have noticed that if you start searching for the right headset later in time / further in the code connection sequence, this happens much less frequently. The ACL scan is originally in unicast_client_location_cb. If I move the ACL scan to discover_source_cb or stream_enabled_cb, the issue happens much less frequently. If this is time dependent, then this is also likely a problem because as we add code to the rest of the system, time could change again and cause the issue to come back.
GW [00:00:00.259,490] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.259,521] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.270,141] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.307,037] <wrn> bt_hci_core: Controller to host flow control not supported
GW [00:00:00.310,150] <inf> bt_hci_core: No ID address. App must call settings_load()
GW [00:00:00.310,241] <inf> ble: MAC: 00:00:00:00:00:00 (public)
GW [00:00:00.310,791] <inf> ble: Controller version: 3349
GW [00:00:00.313,781] <err> settings: set-value failure. key: bt/name error(-2)
GW [00:00:00.313,873] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random)
GW [00:00:00.313,903] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
GW [00:00:00.313,903] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
GW [00:00:00.432,067] <inf> cis_gateway: Scanning successfully started
GW [00:00:00.517,395] <inf> cis_gateway: Connected: 60:20:E9:4A:5E:67 (random)
GW [00:00:02.330,261] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:02.330,291] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:02.599,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.478,485] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:03.478,485] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005698
GW [00:00:03.479,217] <inf> cis_gateway: Scanning successfully started
GW [00:00:03.625,518] <inf> cis_gateway: Connected: 4B:D7:D6:29:40:2F (random)
GW [00:00:03.878,540] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.918,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.918,579] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:04.308,471] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:04.308,593] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:04.368,713] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:04.368,713] <inf> cis_gateway: LEFT sink stream configured
GW [00:00:04.369,262] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:04.718,963] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:05.078,552] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:05.378,601] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:05.419,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:05.419,189] <inf> cis_gateway: LEFT source stream configured
GW [00:00:05.489,044] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:05.489,105] <inf> cis_gateway: Enable stream 0x20001f0c
GW [00:00:05.489,593] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:05.489,654] <inf> cis_gateway: Enable stream 0x20001cec
GW [00:00:05.521,972] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:05.522,003] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:05.528,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:05.539,001] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:05.539,855] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:05.540,100] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13
GW [00:00:05.540,130] <wrn> cis_gateway: Unknown stream
GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13
GW [00:00:05.790,588] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.039,703] <wrn> bt_conn: no transition connecting
GW [00:00:06.040,222] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:06.040,496] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:06.040,496] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13
GW [00:00:06.040,496] <wrn> cis_gateway: Unknown stream
GW [00:00:06.040,527] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13
GW [00:00:06.502,532] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:06.502,532] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:06.502,532] <inf> cis_gateway: All headsets connected
GW [00:00:06.872,558] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.912,567] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.912,597] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:07.292,510] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:07.292,633] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:07.313,171] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:07.313,201] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:07.313,751] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:07.662,567] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:08.012,603] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:08.272,644] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:08.313,201] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:08.313,232] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:08.372,619] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:08.372,680] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:08.373,138] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:08.373,199] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:08.442,596] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:08.443,511] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.444,152] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:10.463,104] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:10.463,531] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:10.463,562] <wrn> cis_gateway: Unknown stream
GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:10.464,843] <wrn> cis_gateway: Unknown stream
GW [00:00:10.464,935] <inf> cis_gateway: Disconnected: 4B:D7:D6:29:40:2F (random) (reason 0x16)
GW [00:00:10.465,576] <inf> cis_gateway: Scanning successfully started
GW [00:00:10.861,907] <inf> cis_gateway: Connected: 44:EF:53:25:6B:96 (random)
GW [00:00:12.492,218] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:12.492,218] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:12.670,776] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:13.642,730] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:13.642,730] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:13.642,730] <inf> cis_gateway: All headsets connected
GW [00:00:14.002,777] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.052,764] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.052,795] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:14.422,698] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.422,821] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:14.463,378] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:14.463,409] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:14.472,869] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:14.832,763] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:15.202,789] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:15.472,839] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:15.512,969] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:15.512,969] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:15.573,303] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:15.573,333] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:15.583,007] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:15.583,068] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:15.613,250] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:15.633,239] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:15.633,636] <wrn> bt_conn: no transition connecting
GW [00:00:17.633,911] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:17.653,320] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:17.653,747] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:17.653,747] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:17.653,778] <wrn> cis_gateway: Unknown stream
GW [00:00:17.653,778] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:17.654,998] <wrn> cis_gateway: Unknown stream
GW [00:00:17.655,090] <inf> cis_gateway: Disconnected: 44:EF:53:25:6B:96 (random) (reason 0x16)
GW [00:00:17.655,731] <inf> cis_gateway: Scanning successfully started
GW [00:00:18.001,403] <inf> cis_gateway: Connected: 48:1A:C0:46:05:23 (random)
GW [00:00:19.722,412] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:19.722,412] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:19.901,489] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:20.742,919] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:20.742,919] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:20.742,919] <inf> cis_gateway: All headsets connected
GW [00:00:21.082,977] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.132,965] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.132,995] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:21.482,910] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.483,001] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:21.513,580] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:21.513,580] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:21.514,739] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:21.872,955] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:22.162,994] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:22.413,024] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:22.453,155] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:22.453,155] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:22.513,031] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:22.513,061] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:22.513,519] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:22.513,580] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:22.552,978] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:22.563,446] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:22.563,812] <wrn> bt_conn: no transition connecting
GW [00:00:24.564,117] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:24.573,516] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:24.573,944] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:24.573,944] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:24.573,944] <wrn> cis_gateway: Unknown stream
GW [00:00:24.573,974] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:24.575,195] <wrn> cis_gateway: Unknown stream
GW [00:00:24.575,286] <inf> cis_gateway: Disconnected: 48:1A:C0:46:05:23 (random) (reason 0x16)
GW [00:00:24.575,927] <inf> cis_gateway: Scanning successfully started
GW [00:00:25.193,725] <inf> cis_gateway: Connected: 7B:A7:91:0C:AE:5E (random)
GW [00:00:27.002,624] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:27.002,624] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:27.181,182] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.093,109] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:28.093,139] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:28.093,139] <inf> cis_gateway: All headsets connected
GW [00:00:28.453,155] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.503,173] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.503,204] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:28.843,109] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.843,231] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:28.863,769] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:28.863,800] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:28.864,349] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.163,146] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:29.473,205] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.793,273] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.833,343] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:29.833,374] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:29.893,707] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:29.893,737] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:29.894,195] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:29.894,256] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:29.933,197] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:29.943,634] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:29.944,030] <wrn> bt_conn: no transition connecting
GW [00:00:31.944,305] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:31.954,101] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:31.954,528] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:31.954,528] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:31.954,559] <wrn> cis_gateway: Unknown stream
GW [00:00:31.954,559] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:31.955,810] <wrn> cis_gateway: Unknown stream
GW [00:00:31.955,902] <inf> cis_gateway: Disconnected: 7B:A7:91:0C:AE:5E (random) (reason 0x16)
GW [00:00:31.956,542] <inf> cis_gateway: Scanning successfully started
GW [00:00:32.355,743] <inf> cis_gateway: Connected: 61:E7:90:D0:18:37 (random)
GW [00:00:33.892,791] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:33.892,822] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:34.071,380] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.243,316] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:35.243,347] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:35.243,347] <inf> cis_gateway: All headsets connected
GW [00:00:35.583,374] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.623,382] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.623,413] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:35.933,319] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.933,410] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:35.973,968] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:35.973,999] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:35.983,489] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.313,354] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:36.603,393] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.863,433] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.903,564] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:36.903,564] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:36.953,887] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:36.953,948] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:36.963,592] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:36.963,653] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:36.993,835] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:37.023,376] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:37.023,773] <wrn> bt_conn: no transition connecting
GW [00:00:39.024,047] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:39.033,905] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:39.034,332] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:39.034,362] <wrn> cis_gateway: Unknown stream
GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:39.035,583] <wrn> cis_gateway: Unknown stream
GW [00:00:39.035,705] <inf> cis_gateway: Disconnected: 61:E7:90:D0:18:37 (random) (reason 0x16)
GW [00:00:39.036,346] <inf> cis_gateway: Scanning successfully started
GW [00:00:39.435,546] <inf> cis_gateway: Connected: 58:44:76:E7:1F:C8 (random)
GW [00:00:41.153,015] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:41.153,015] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:41.421,569] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.353,515] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:42.353,546] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:42.353,546] <inf> cis_gateway: All headsets connected
GW [00:00:42.703,552] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.743,560] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.743,591] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:43.113,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:43.113,616] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:43.163,726] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:43.163,757] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:43.164,276] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:43.473,541] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:43.763,610] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:44.023,651] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:44.044,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:44.044,219] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:44.064,086] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:44.064,147] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:44.064,605] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:44.064,636] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:44.074,127] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:44.084,045] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:44.084,411] <wrn> bt_conn: no transition connecting
GW [00:00:46.084,686] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:46.094,116] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:46.094,543] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:46.094,543] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:46.094,543] <wrn> cis_gateway: Unknown stream
GW [00:00:46.094,573] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:46.095,794] <wrn> cis_gateway: Unknown stream
GW [00:00:46.095,886] <inf> cis_gateway: Disconnected: 58:44:76:E7:1F:C8 (random) (reason 0x16)
GW [00:00:46.096,527] <inf> cis_gateway: Scanning successfully started
GW [00:00:46.213,775] <inf> cis_gateway: Connected: 40:EB:E0:AD:11:02 (random)
GW [00:00:47.311,126] <wrn> cis_gateway: Unknown stream
GW [00:00:47.311,218] <inf> cis_gateway: Disconnected: 60:20:E9:4A:5E:67 (random) (reason 0x13)
GW [00:00:47.311,889] <inf> cis_gateway: Scanning successfully started
GW [00:00:47.763,641] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:47.763,641] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:47.843,658] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:47.843,658] <err> cis_gateway: Discovery failed: 14
GW [00:00:47.843,811] <inf> cis_gateway: Disconnected: 40:EB:E0:AD:11:02 (random) (reason 0x13)
GW [00:00:47.843,811] <wrn> cis_gateway: Connection not found
GW [00:00:47.843,841] <wrn> cis_gateway: Unknown connection
GW [00:00:47.843,841] <inf> cis_gateway: Scanning successfully started
Problem #3 - Source audio not always acquired
The next issue that I have seen is if you connect to the headset successfully, the first time the connection is made, the source (headset microphone) audio will play on the headphone jack every time. The issue comes when you put the headset back in the case and close the lid, then re-open and take the headset out. The next successful connection will have a 50% chance of the microphone audio playing on the headphone jack. This 50% chance of source audio working happens every time you put the headphones back in the case and take them out again.
One note: I have also tested this on a non-audio DK, with the source audio being fed back into the headset sink. For this reason, I don't think the issue has to do with the I2S or HW codec etc.
Lastly, it looks like the audio in data is still being received since the callback for Rx data is still being called.
I have attached an example project. It is the LE audio demo code with minor modifications. Search for <Modified> in the code to see what I modified. The modifications were only made in prj.conf and le_audio_cis_gateway.c
nrf2_4_0_AudioDemo.zip
  • I'm still investigating but I tested your config, which is mostly the same as what I was testing, except that CONFIG_WALKIE_TALKIE_DEMO is enabled (MCS MCC enabled effectively) in my configuration. I did not see a crash with CONFIG_WALKIE_TALKIE_DEMO disabled (your config). However, your config seems to connect to the right quickly then hangs on ACL connections to the left. Infrequently it will connect to the left.
    Enable CONFIG_WALKIE_TALKIE_DEMO and the controller will crash.
    Thanks for double checking. Yes I have the same headphone build.
    "Could you also elaborate on how you specifically test to connect the right earbud first?"
    I have a zip file attached to the post with a failing setup. Search for <Modified> in the code to see what I modified. In the code it connects, then checks if right or left via location like you described. If right first, disconnect and try again.
    On a similar note: we would like to uniquely connect to headsets, not just any headset named "Galaxy Buds2 Pro". I have added filtering into the code but unfortunately only the right headset is filterable. The left headset public address is never found. The left headset always advertises random addresses. So to sum it up, I can connect uniquely to a headset but it can only uniquely connect to the right headset first, which is a problem because of the right before left crash issue.
    "I understand that you also had this disabled initially, but some later comments seem to indicate that you are using bonding in your testing"
    Yes sorry about that. I am not using bonding at all. The info provided was just the results that I receive when trying to bond.
    Thanks for the support!
    If you want to replicate, try the zip file provided in the post
  • We can't provide a pre-release version of the controller. You will have to wait for the official release.
    We also don't have a guarantee for a fix because of the descriptions not matching (as Karl pointed out).
    OK no problem. The attached zip file should provide the controller crash fail condition for your testing. Thanks anyway though Slight smile
  • Also, another issue, we have tried implementing 8 Khz LC3 audio, which looks to be correct, except that the connection drops immediately after starting streaming.
    What is the progress on the crash issue? We are going on 3 weeks and I haven't heard any news that you have replicated the crash issue.
  • Hello!
    Sorry about the delay, and thank you for your patience.
    Based on what I can see this should be supported. But I will ask the LE Audio experts to make sure.
    We still haven't been able to reproduce the crash, so we need some more help from you. In addition to the crash problem
    About problem #1:
    Our tester is back in office and has tried to replicate the crash. He has not been able to do this though.
    We want to be sure that his environment is the same as yours. Could you please check that the correct toolchain is chosen when you are building your project? For NCS v2.3.0 this should be located in ncs/toolchains/v2.3.0 if you have an automatic install and the zephyr-sdk version should be 0.15.2.
    For problem #2:
    Our tester has not seen the disconnection happen.
    Now to problem #3:
    Samsung earbuds will not work without MCS in the gateway. MCS with bidirectional mode is not supported by our solution now.
    Something to look out for is that if you pause the stream before the earbuds are disconnected, the state of the stream will be different from the expectations of the connection. After reconnection the earbuds will request the streams to play, but the gateway will only know how to enable.
    Our main tester had some time to prepare modifications you can use to test:
    In prj.conf add these configs:
    CONFIG_BLE_ACL_CONN_INTERVAL=36
    CONFIG_BT_LOG_SNIFFER_INFO=y
    Maria
  • I included some incomplete and irrelevant information in my last post. Sorry about that.
    Corrections and additions below.
    You are using NCS 2.4.0 of course, so here is the relevant information:
    For NCS v2.4.0 this should be located in ncs/toolchains/31f4403e35 if you have an automatic install and the zephyr-sdk version should be 0.16.0.
    I only included the prj.conf additions, but le_audio_cis_gateway needs modifications as well.
    Comment out:
     static void bond_check(const struct bt_bond_info *info, void *user_data)
     	char addr_buf[BT_ADDR_LE_STR_LEN];
    @@ -1008,6 +1009,7 @@ static void bond_check(const struct bt_bond_info *info, void *user_data)
     	LOG_DBG("Stored bonding found: %s", addr_buf);
     	bonded_num++;
    and
     	bt_foreach_bond(BT_ID_DEFAULT, bond_check, NULL);
     	if (bonded_num >= CONFIG_BT_MAX_PAIRED) {
     		LOG_INF("All bonded slots filled, will not accept new devices");
    Replace
    if (bonded_num < CONFIG_BT_MAX_PAIRED) {
              ad_parse(p_ad, addr);
    with
    +       ad_parse(p_ad, addr);
    Add
    if (ep_state_check(headsets[AUDIO_CH_L].source_stream.ep,
                BT_BAP_EP_STATE_QOS_CONFIGURED)) {
    		ret = bt_bap_stream_enable(&headsets[AUDIO_CH_L].source_stream,
    					   lc3_preset_source.codec.meta,
    					   lc3_preset_source.codec.meta_count);
    	if (ret) {
    		LOG_WRN("Failed to enable left stream");
    as a third if-statement within le_audio_play_pause_cb(bool play) if(play).
    Maria
