nRF5340 LE Audio Samsung Galaxy Buds2 Pro - Multiple Problems
I using the Samsung Galaxy Buds2 Pro headphones to connect to the latest v2.4.0 nRF SDK. I am using the LE Audio demo code as gateway. The demo connects successfully out of the box to the headphones, with some modifications to the prj.conf file, using the nRF5340 Audio DK. For my project needs, I have both source and sink enabled via CONFIG_STREAM_BIDIRECTIONAL.
CONFIG_AUDIO_DEV=2
CONFIG_BT_DEVICE_NAME="Galaxy Buds2 Pro"
#QOS will fail without this
CONFIG_BT_AUDIO_PRESENTATION_DELAY_US=40000
#Seem to get failed to discover without this
CONFIG_BLE_ACL_CONN_INTERVAL=72
CONFIG_BT_AUDIO_MAX_TRANSPORT_LATENCY_MS=100
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_BT_AUDIO_RETRANSMITS=2
CONFIG_BT_BAP_UNICAST_CLIENT_ASE_SRC_COUNT=2
CONFIG_STREAM_BIDIRECTIONAL=y
CONFIG_WALKIE_TALKIE_DEMO=y
CONFIG_AUDIO_SOURCE_I2S=y
CONFIG_BT_BONDABLE=n
CONFIG_BT_VCP_VOL_CTLR=n
Problem #1 - Controller Crashes
If you connect to the right headset first, then connect to the left headset, the"ble5-ctr-rpmsg_3349" controller crashes. I believe this also happened on the 3330 controller as well.
The crash happens after calling bt_bap_stream_start on the Left SINK. This only happens if you connect to the right headset first, followed by the left.
Once the controller crashes, the next call to bt_hci_cmd_send_sync will fail on semaphore take "timeout with err -11". This usually happens either on the next le_audio_send stream send OR on the ble_core.c watchdog call to net_core_ctrl_version_get.
Log:
         nRF5340 Audio nRF5340 Audio DK cpuapp
         NCS base version: 2.4.0
         Cmake run : Tue Jun 13 05:32:12 2023
GW [00:00:00.258,209] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.258,239] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.268,859] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.305,755] <wrn> bt_hci_core: Controller to host flow control not supported
GW [00:00:00.308,898] <inf> bt_hci_core: No ID address. App must call settings_load()
GW [00:00:00.308,959] <inf> ble: MAC: 00:00:00:00:00:00 (public)
GW [00:00:00.309,509] <inf> ble: Controller version: 3349
GW [00:00:00.312,500] <err> settings: set-value failure. key: bt/name error(-2)
GW [00:00:00.312,591] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random)
GW [00:00:00.312,622] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
GW [00:00:00.312,622] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
GW [00:00:00.430,725] <inf> cis_gateway: Scanning successfully started
GW [00:00:05.272,583] <inf> cis_gateway: Connected: 7F:3B:83:F5:3B:A8 (random)
GW [00:00:07.189,117] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:07.189,117] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:07.457,885] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.467,346] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:08.467,346] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005698
GW [00:00:08.468,078] <inf> cis_gateway: Scanning successfully started
GW [00:00:08.857,391] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.917,388] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:08.917,419] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:09.217,315] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:09.217,437] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:09.257,995] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:09.258,026] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:09.258,544] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:09.577,362] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:09.857,421] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:10.107,452] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:10.147,583] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:10.147,583] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:10.207,916] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:10.207,946] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:10.208,404] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:10.208,465] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:10.257,415] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.258,331] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.427,459] <err> cis_gateway: <<<<< stream_started_cb >>>>>
GW [00:00:10.427,459] <inf> cis_gateway: Stream 0x200021ac started
GW [00:00:10.453,308] <wrn> bt_hci_core: opcode 0x2061 status 0x0c
GW [00:00:10.921,203] <err> cis_gateway: <<<<< stream_started_cb >>>>>
GW [00:00:10.921,234] <inf> cis_gateway: Stream 0x200023cc started
GW [00:00:12.058,898] <inf> cis_gateway: Connected: 71:09:B2:4D:BC:12 (random)
GW [00:00:14.863,433] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:14.863,464] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:15.131,622] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:15.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 5000
GW [00:00:16.901,458] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:16.901,458] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005760
GW [00:00:16.901,458] <inf> cis_gateway: All headsets connected
GW [00:00:17.471,496] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:17.531,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:17.531,524] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:18.071,441] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:18.071,563] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:18.141,662] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:18.141,693] <inf> cis_gateway: LEFT sink stream configured
GW [00:00:18.151,611] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:18.651,519] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:19.131,591] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:19.551,605] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:19.641,693] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:19.641,723] <inf> cis_gateway: LEFT source stream configured
GW [00:00:19.751,586] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:19.751,617] <inf> cis_gateway: Enable stream 0x20001f0c
GW [00:00:19.761,718] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:19.761,779] <inf> cis_gateway: Enable stream 0x20001cec
GW [00:00:19.821,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:19.851,562] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:19.857,177] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:19.942,169] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:19.962,158] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:20.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 10000
GW [00:00:25.439,147] <wrn> audio_datapath: In I2S TX underrun condition, total: 15000
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:330
        command opcode 0x2061 timeout with err -11
GW [00:00:29.958,007] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000002  r2/a3:  0x00000001
GW [00:00:29.958,038] <err> os: r3/a4:  0x0000014a r12/ip:  0x00407fd0 r14/lr:  0x00020c95
GW [00:00:29.958,038] <err> os:  xpsr:  0x41100000
GW [00:00:29.958,038] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x0000001c  s[ 2]:  0x00000000  s[ 3]:  0x000000a2
GW [00:00:29.958,038] <err> os: s[ 4]:  0x00000010  s[ 5]:  0x0000001a  s[ 6]:  0x00000000  s[ 7]:  0x000000a2
GW [00:00:29.958,068] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x000000a2  s[10]:  0x00000003  s[11]:  0x00000002
GW [00:00:29.958,068] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000031  s[15]:  0x00000000
GW [00:00:29.958,068] <err> os: fpscr:  0x20000010
GW [00:00:29.958,099] <err> os: Faulting instruction address (r15/pc): 0x00020ca0
GW [00:00:29.958,099] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
GW [00:00:29.958,129] <err> os: Current thread: 0x200018c0 (ENCODER)
GW [00:00:29.958,129] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
Problem #2 - Connection constantly disconnects
There seems to be a possible timing issue when connecting a headset stream, then starting the scan / connection to the other headset.
After starting the left headset stream, when you start scanning / connecting to the right headset, the left headset drops connection. It happens as soon as the right headset starts scan / connection. I have noticed that if you start searching for the right headset later in time / further in the code connection sequence, this happens much less frequently. The ACL scan is originally in unicast_client_location_cb. If I move the ACL scan to discover_source_cb or stream_enabled_cb, the issue happens much less frequently. If this is time dependent, then this is also likely a problem because as we add code to the rest of the system, time could change again and cause the issue to come back.
GW [00:00:00.259,490] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.259,521] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.270,141] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.307,037] <wrn> bt_hci_core: Controller to host flow control not supported
GW [00:00:00.310,150] <inf> bt_hci_core: No ID address. App must call settings_load()
GW [00:00:00.310,241] <inf> ble: MAC: 00:00:00:00:00:00 (public)
GW [00:00:00.310,791] <inf> ble: Controller version: 3349
GW [00:00:00.313,781] <err> settings: set-value failure. key: bt/name error(-2)
GW [00:00:00.313,873] <inf> bt_hci_core: Identity: FD:60:E5:B4:2A:20 (random)
GW [00:00:00.313,903] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
GW [00:00:00.313,903] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
GW [00:00:00.432,067] <inf> cis_gateway: Scanning successfully started
GW [00:00:00.517,395] <inf> cis_gateway: Connected: 60:20:E9:4A:5E:67 (random)
GW [00:00:02.330,261] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:02.330,291] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:02.599,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.478,485] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:03.478,485] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_LEFT 0x20005698
GW [00:00:03.479,217] <inf> cis_gateway: Scanning successfully started
GW [00:00:03.625,518] <inf> cis_gateway: Connected: 4B:D7:D6:29:40:2F (random)
GW [00:00:03.878,540] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.918,548] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:03.918,579] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:04.308,471] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:04.308,593] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:04.368,713] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:04.368,713] <inf> cis_gateway: LEFT sink stream configured
GW [00:00:04.369,262] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:04.718,963] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:05.078,552] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:05.378,601] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:05.419,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:05.419,189] <inf> cis_gateway: LEFT source stream configured
GW [00:00:05.489,044] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:05.489,105] <inf> cis_gateway: Enable stream 0x20001f0c
GW [00:00:05.489,593] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:05.489,654] <inf> cis_gateway: Enable stream 0x20001cec
GW [00:00:05.521,972] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:05.522,003] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:05.528,533] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:05.539,001] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:05.539,855] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:05.540,100] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13
GW [00:00:05.540,130] <wrn> cis_gateway: Unknown stream
GW [00:00:05.540,130] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13
GW [00:00:05.790,588] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.039,703] <wrn> bt_conn: no transition connecting
GW [00:00:06.040,222] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:06.040,496] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:06.040,496] <inf> cis_gateway: Stream 0x20001f0c stopped. Reason 13
GW [00:00:06.040,496] <wrn> cis_gateway: Unknown stream
GW [00:00:06.040,527] <inf> cis_gateway: Stream 0x20001cec stopped. Reason 13
GW [00:00:06.502,532] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:06.502,532] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:06.502,532] <inf> cis_gateway: All headsets connected
GW [00:00:06.872,558] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.912,567] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:06.912,597] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:07.292,510] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:07.292,633] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:07.313,171] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:07.313,201] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:07.313,751] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:07.662,567] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:08.012,603] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:08.272,644] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:08.313,201] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:08.313,232] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:08.372,619] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:08.372,680] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:08.373,138] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:08.373,199] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:08.442,596] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:08.443,511] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:10.444,152] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:10.463,104] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:10.463,531] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:10.463,562] <wrn> cis_gateway: Unknown stream
GW [00:00:10.463,562] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:10.464,843] <wrn> cis_gateway: Unknown stream
GW [00:00:10.464,935] <inf> cis_gateway: Disconnected: 4B:D7:D6:29:40:2F (random) (reason 0x16)
GW [00:00:10.465,576] <inf> cis_gateway: Scanning successfully started
GW [00:00:10.861,907] <inf> cis_gateway: Connected: 44:EF:53:25:6B:96 (random)
GW [00:00:12.492,218] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:12.492,218] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:12.670,776] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:13.642,730] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:13.642,730] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:13.642,730] <inf> cis_gateway: All headsets connected
GW [00:00:14.002,777] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.052,764] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.052,795] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:14.422,698] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:14.422,821] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:14.463,378] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:14.463,409] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:14.472,869] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:14.832,763] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:15.202,789] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:15.472,839] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:15.512,969] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:15.512,969] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:15.573,303] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:15.573,333] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:15.583,007] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:15.583,068] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:15.613,250] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:15.633,239] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:15.633,636] <wrn> bt_conn: no transition connecting
GW [00:00:17.633,911] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:17.653,320] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:17.653,747] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:17.653,747] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:17.653,778] <wrn> cis_gateway: Unknown stream
GW [00:00:17.653,778] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:17.654,998] <wrn> cis_gateway: Unknown stream
GW [00:00:17.655,090] <inf> cis_gateway: Disconnected: 44:EF:53:25:6B:96 (random) (reason 0x16)
GW [00:00:17.655,731] <inf> cis_gateway: Scanning successfully started
GW [00:00:18.001,403] <inf> cis_gateway: Connected: 48:1A:C0:46:05:23 (random)
GW [00:00:19.722,412] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:19.722,412] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:19.901,489] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:20.742,919] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:20.742,919] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:20.742,919] <inf> cis_gateway: All headsets connected
GW [00:00:21.082,977] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.132,965] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.132,995] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:21.482,910] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:21.483,001] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:21.513,580] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:21.513,580] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:21.514,739] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:21.872,955] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:22.162,994] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:22.413,024] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:22.453,155] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:22.453,155] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:22.513,031] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:22.513,061] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:22.513,519] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:22.513,580] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:22.552,978] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:22.563,446] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:22.563,812] <wrn> bt_conn: no transition connecting
GW [00:00:24.564,117] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:24.573,516] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:24.573,944] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:24.573,944] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:24.573,944] <wrn> cis_gateway: Unknown stream
GW [00:00:24.573,974] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:24.575,195] <wrn> cis_gateway: Unknown stream
GW [00:00:24.575,286] <inf> cis_gateway: Disconnected: 48:1A:C0:46:05:23 (random) (reason 0x16)
GW [00:00:24.575,927] <inf> cis_gateway: Scanning successfully started
GW [00:00:25.193,725] <inf> cis_gateway: Connected: 7B:A7:91:0C:AE:5E (random)
GW [00:00:27.002,624] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:27.002,624] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:27.181,182] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.093,109] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:28.093,139] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:28.093,139] <inf> cis_gateway: All headsets connected
GW [00:00:28.453,155] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.503,173] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.503,204] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:28.843,109] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:28.843,231] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:28.863,769] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:28.863,800] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:28.864,349] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.163,146] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:29.473,205] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.793,273] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:29.833,343] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:29.833,374] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:29.893,707] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:29.893,737] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:29.894,195] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:29.894,256] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:29.933,197] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:29.943,634] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:29.944,030] <wrn> bt_conn: no transition connecting
GW [00:00:31.944,305] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:31.954,101] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:31.954,528] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:31.954,528] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:31.954,559] <wrn> cis_gateway: Unknown stream
GW [00:00:31.954,559] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:31.955,810] <wrn> cis_gateway: Unknown stream
GW [00:00:31.955,902] <inf> cis_gateway: Disconnected: 7B:A7:91:0C:AE:5E (random) (reason 0x16)
GW [00:00:31.956,542] <inf> cis_gateway: Scanning successfully started
GW [00:00:32.355,743] <inf> cis_gateway: Connected: 61:E7:90:D0:18:37 (random)
GW [00:00:33.892,791] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:33.892,822] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:34.071,380] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.243,316] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:35.243,347] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:35.243,347] <inf> cis_gateway: All headsets connected
GW [00:00:35.583,374] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.623,382] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.623,413] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:35.933,319] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:35.933,410] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:35.973,968] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:35.973,999] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:35.983,489] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.313,354] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:36.603,393] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.863,433] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:36.903,564] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:36.903,564] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:36.953,887] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:36.953,948] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:36.963,592] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:36.963,653] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:36.993,835] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:37.023,376] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:37.023,773] <wrn> bt_conn: no transition connecting
GW [00:00:39.024,047] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:39.033,905] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:39.034,332] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:39.034,362] <wrn> cis_gateway: Unknown stream
GW [00:00:39.034,362] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:39.035,583] <wrn> cis_gateway: Unknown stream
GW [00:00:39.035,705] <inf> cis_gateway: Disconnected: 61:E7:90:D0:18:37 (random) (reason 0x16)
GW [00:00:39.036,346] <inf> cis_gateway: Scanning successfully started
GW [00:00:39.435,546] <inf> cis_gateway: Connected: 58:44:76:E7:1F:C8 (random)
GW [00:00:41.153,015] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:41.153,015] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:41.421,569] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.353,515] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:42.353,546] <wrn> cis_gateway: BT_AUDIO_LOCATION_FRONT_RIGHT 0x20005760
GW [00:00:42.353,546] <inf> cis_gateway: All headsets connected
GW [00:00:42.703,552] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.743,560] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:42.743,591] <wrn> cis_gateway: More than one sink endpoints found, ep idx 0 is used by default
GW [00:00:43.113,494] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:43.113,616] <err> cis_gateway: <<<<< discover_source >>>>>
GW [00:00:43.163,726] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:43.163,757] <inf> cis_gateway: RIGHT sink stream configured
GW [00:00:43.164,276] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:43.473,541] <err> cis_gateway: <<<<< unicast_client_location_cb >>>>>
GW [00:00:43.763,610] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:44.023,651] <err> cis_gateway: <<<<< discover_source_cb >>>>>
GW [00:00:44.044,189] <err> cis_gateway: <<<<< stream_configured_cb >>>>>
GW [00:00:44.044,219] <inf> cis_gateway: RIGHT source stream configured
GW [00:00:44.064,086] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:44.064,147] <inf> cis_gateway: Enable stream 0x200023cc
GW [00:00:44.064,605] <err> cis_gateway: <<<<< stream_qos_set_cb >>>>>
GW [00:00:44.064,636] <inf> cis_gateway: Enable stream 0x200021ac
GW [00:00:44.074,127] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:44.084,045] <err> cis_gateway: <<<<< stream_enabled_cb >>>>>
GW [00:00:44.084,411] <wrn> bt_conn: no transition connecting
GW [00:00:46.084,686] <err> cis_gateway: Failed to establish CIS, ret = -16
GW [00:00:46.094,116] <wrn> bt_hci_core: opcode 0x206f status 0x0c
GW [00:00:46.094,543] <wrn> bt_hci_core: opcode 0x206f status 0x12
GW [00:00:46.094,543] <inf> cis_gateway: Stream 0x200023cc stopped. Reason 13
GW [00:00:46.094,543] <wrn> cis_gateway: Unknown stream
GW [00:00:46.094,573] <inf> cis_gateway: Stream 0x200021ac stopped. Reason 13
GW [00:00:46.095,794] <wrn> cis_gateway: Unknown stream
GW [00:00:46.095,886] <inf> cis_gateway: Disconnected: 58:44:76:E7:1F:C8 (random) (reason 0x16)
GW [00:00:46.096,527] <inf> cis_gateway: Scanning successfully started
GW [00:00:46.213,775] <inf> cis_gateway: Connected: 40:EB:E0:AD:11:02 (random)
GW [00:00:47.311,126] <wrn> cis_gateway: Unknown stream
GW [00:00:47.311,218] <inf> cis_gateway: Disconnected: 60:20:E9:4A:5E:67 (random) (reason 0x13)
GW [00:00:47.311,889] <inf> cis_gateway: Scanning successfully started
GW [00:00:47.763,641] <err> cis_gateway: <<<<< security_changed_cb >>>>>
GW [00:00:47.763,641] <err> cis_gateway: <<<<< discover_sink >>>>>
GW [00:00:47.843,658] <err> cis_gateway: <<<<< discover_sink_cb >>>>>
GW [00:00:47.843,658] <err> cis_gateway: Discovery failed: 14
GW [00:00:47.843,811] <inf> cis_gateway: Disconnected: 40:EB:E0:AD:11:02 (random) (reason 0x13)
GW [00:00:47.843,811] <wrn> cis_gateway: Connection not found
GW [00:00:47.843,841] <wrn> cis_gateway: Unknown connection
GW [00:00:47.843,841] <inf> cis_gateway: Scanning successfully started
Problem #3 - Source audio not always acquired
The next issue that I have seen is if you connect to the headset successfully, the first time the connection is made, the source (headset microphone) audio will play on the headphone jack every time. The issue comes when you put the headset back in the case and close the lid, then re-open and take the headset out. The next successful connection will have a 50% chance of the microphone audio playing on the headphone jack. This 50% chance of source audio working happens every time you put the headphones back in the case and take them out again.
One note: I have also tested this on a non-audio DK, with the source audio being fed back into the headset sink. For this reason, I don't think the issue has to do with the I2S or HW codec etc.
Lastly, it looks like the audio in data is still being received since the callback for Rx data is still being called.
I have attached an example project. It is the LE audio demo code with minor modifications. Search for <Modified> in the code to see what I modified. The modifications were only made in prj.conf and le_audio_cis_gateway.c
nrf2_4_0_AudioDemo.zip
  • Hi, just wandering if there was any further achievement on this?
    I'm not looking for bidirectional, but whether the CONFIG_STREAM_BIDIRECTIONAL flag is set or not I still see the same behaviour.
    If I take a vanilla nrf5340_audio example, add proj.conf flags as recommended above but I see near identical behaviour to ksmith:
    If I present both buds to pair, Left usually connects and is stable, Right attempts to connect but fails.  I can play audio through left - connection appears stable.  If Right does connect first, Left does not connect and I get a stream of errors: <wrn> audio_datapath: In I2S TX underrun condition, total: 5000.  This counts up and at about 30s the audio stream to the right is lost.
    If I "hide" the right bud in the case, Left connects as above and the connection is stable
    If I "hide" the left bud in the case, Right connects and the audio stream is stable for between a few tens of seconds to single-digit minutes.
    I'm working with SDK v2.4.1
    Many thanks
    Thank you for your extreme patience with this, and thank you for the description of how you reproduced this issue.
    Have you had a chance to try this out with the newest controller, the 3393?
    Please let me know if the problem persists with this controller, so that we may initiate some tests of this.
    It would also be great if you could provide the version of the galaxy ear buds pro 2 firmware you are using, in this case.
    On a general note I would like to emphasize that the project is still experimental - which is also the case on the galaxy earbuds / android side - and so there could still arise issues in compatibility between different versions of different development platforms.
    Karl
  • Thanks, I'll give this a go - I checked and was on 3349. I've kept the headphones at R510XXU0AWA5.
    Yes- I get that LE Audio is taking its time.. It's that new tech chicken-and-egg where there's the new tech burden with a small market reach, but significant advantages when the tech becomes mainstream.  Thanks for creating supporting one of the first dedicated dev boards.
    Alright, great! :) Thanks for the clarification, and let me know if you encounter the issue again (or any other issues) when you test with the newest controller.
    Thank you for the understanding - getting every manufacturer/vendor aligned is indeed quite the burden to begin with, but fortunately the new standard is picking up speed day by day, and the compatibility between vendors gets better and better (until we finally will see full compatibility between every Auracast qualified device).
    I am glad to read that you appreciate the effort we are putting into this, and that you are following the development so closely! :)
    Karl
