Error: "region `FLASH' overflowed by 5164 bytes" occurred after enabling image signing for mcuboot
I was facing below warning that I am using default MCUBoot Key, which I should not use it for our production. I was new to this topic and wanted to resolve this issues asap. Because we will be certifying our product very soon with Verizon and I hope this was a crucial step to remove this warning before certification.
CMake Warning at C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
So to remove this warning I created a private key using openssl using below cmd in bash window and added below prj.conf and kconfig options.
prj.conf
CONFIG_SECURE_BOOT=y
kconfig
config BOOT_SIGNATURE_KEY_FILE
	string "Firmware Signature File Absolute Path"
	default "C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/private.pem"
OpenSSL CMD
openssl ecparam -name prime256v1 -noout -out private.pem
Although, after performing above changes the warning seems to be removed in the logs but the build is failing with the error stating that "region `FLASH' overflowed by 5164 bytes". Please refer complete logs below and a new warning appears mentioned below.
New Warning:
CMake Warning at ../../subsys/bootloader/CMakeLists.txt:21 (message):
        --- WARNING: When using the immutable bootloader on  ---
        --- this SoC, the UICR must be erased when flashing. ---
        --- E.g. by calling 'west flash --erase'             ---
Complete Log: (Somehow I am not able to attach the log in <\> option so attaching it below.)
Building Hermes_Cloud_Firmware
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware\build c:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/prj.conf" -DOVERLAY_CONFIG:STRING="c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52833dk_nrf52833.conf;c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52dk_nrf52832.conf;c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.conf" -DDTC_OVERLAY_FILE:STRING="c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.overlay""
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware
-- Found Python3: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/.cache
-- Zephyr version: 3.1.99 (C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr)
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Found host-tools: zephyr 0.14.1 (C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk)
-- Found dtc: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk)
-- Found BOARD.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.overlay
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/dts.cmake
Parsing C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/Kconfig
Loaded configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/prj.conf'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52833dk_nrf52833.conf'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52dk_nrf52832.conf'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm - begin ===
loading initial cache file C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/child_image_preload.cmake
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/dts.cmake
Parsing C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/Kconfig
Loaded configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm/prj.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/include/generated/autoconf.h'
CMake Warning at C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/CMakeLists.txt:1839 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm
=== child image spm - end ===
=== child image b0 - begin ===
loading initial cache file C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/child_image_preload.cmake
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/bootloader
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/dts.cmake
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/bootloader/prj.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0
=== child image b0 - end ===
-- Found Python3: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/child_image_preload.cmake
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/child_image/mcuboot/boards/nrf9160dk_nrf9160.overlay
-- Found devicetree overlay: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/dts.cmake
Parsing C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/bootloader/bl_override/override_external_mcuboot.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/bootloader/image/multi_image_mcuboot.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/bootloader/image/fw_info.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/child_image/mcuboot.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot
=== child image mcuboot - end ===
-- Found partition manager static configuration: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/pm_static.yml
Partition 'lwm2m_carrier' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_ctrl' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_rx' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_tx' is not included in the dynamic resolving since it is statically defined.
Partition 'nvs_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'spm' is not included in the dynamic resolving since it is statically defined.
Partition 'spm_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'sram_nonsecure' is not included in the dynamic resolving since it is statically defined.
Partition 'sram_secure' is not included in the dynamic resolving since it is statically defined.
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
Dropping partition 's1_pad' since its size is 0.
Dropping partition 's0_pad' since its size is 0.
-- Configuring done
-- Generating done
[0/407] Generating extra provision key files
[1/407] Generating include/generated/version.h
-- Zephyr version: 3.1.99 (C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr), build: v3.1.99-ncs1-2
[5/407] Creating directories for 'b0_subimage'
[6/407] Generating signing key
[9/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/bignum.c.obj
[10/407] Creating public key from private key used for signing
[13/407] No download step for 'mcuboot_subimage'
[14/407] Creating data to be provisioned to the Bootloader, storing to provision.hex
[19/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/nist_kw.c.obj
[21/407] No patch step for 'b0_subimage'
[22/407] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[23/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/padlock.c.obj
[24/407] No patch step for 'spm_subimage'
[25/407] No patch step for 'mcuboot_subimage'
[26/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/platform_util.c.obj
[27/407] No configure step for 'b0_subimage'
[27/407] Performing build step for 'b0_subimage'
[1/165] Generating include/generated/version.h
[2/165] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/165] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[4/165] Generating include/generated/driver-validation.h
[5/165] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/165] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/165] Generating include/generated/offsets.h
[8/165] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[9/165] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[10/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[11/165] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[12/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[13/165] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[14/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[15/165] Generating linker_zephyr_pre1.cmd
[16/165] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[17/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[18/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[19/165] Generating linker_zephyr_pre0.cmd
[20/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[21/165] Linking C static library zephyr\arch\common\libisr_tables.a
[22/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[23/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[24/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[25/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[26/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[27/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[28/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[29/165] Linking C static library zephyr\arch\common\libarch__common.a
[30/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[31/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[32/165] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[33/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[34/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[35/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[36/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[37/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[38/165] Generating ../../../include/generated/libc/minimal/strerror_table.h
[39/165] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[40/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[41/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[42/165] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[43/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[44/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[45/165] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[46/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[47/165] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[48/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[49/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[50/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[51/165] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[52/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[53/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[54/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[55/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[56/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[57/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[58/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[59/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[60/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[61/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[62/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[63/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[64/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[65/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[66/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[67/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[68/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[69/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[70/165] Building C object CMakeFiles/app.dir/src/main.c.obj
[71/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[72/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[73/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[74/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[75/165] Linking C static library zephyr\lib\posix\liblib__posix.a
[76/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[77/165] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[78/165] Linking C static library app\libapp.a
[79/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[80/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[81/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[82/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[83/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[84/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[85/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[86/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[87/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[88/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[89/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[90/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[91/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[92/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[93/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[94/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[95/165] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[96/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[97/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[98/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[99/165] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[100/165] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[101/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[102/165] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[103/165] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[104/165] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[105/165] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[106/165] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[107/165] Linking C static library zephyr\libzephyr.a
[108/165] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[109/165] Linking C static library zephyr\drivers\console\libdrivers__console.a
[110/165] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[111/165] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[112/165] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[113/165] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[114/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_ecdsa.c.obj
[115/165] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[116/165] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
[117/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
[118/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_common.c.obj
[119/165] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[120/165] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[121/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_hash.c.obj
[122/165] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[123/165] Linking C static library modules\nrf\subsys\bootloader\bl_boot\lib..__nrf__subsys__bootloader__bl_boot.a
[124/165] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
[125/165] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[126/165] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
[127/165] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[128/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[129/165] Linking C static library modules\nrf\subsys\bootloader\bl_crypto\lib..__nrf__subsys__bootloader__bl_crypto.a
[130/165] Linking C static library modules\nrf\subsys\bootloader\bl_validation\lib..__nrf__subsys__bootloader__bl_validation.a
[131/165] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[132/165] Linking C static library modules\nrf\subsys\bootloader\bl_storage\lib..__nrf__subsys__bootloader__bl_storage.a
[133/165] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[134/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[135/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[136/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[137/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[138/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[139/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[140/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[141/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[142/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[143/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[144/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[145/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[146/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[147/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[148/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[149/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[150/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[151/165] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[152/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[153/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[154/165] Linking C static library zephyr\kernel\libkernel.a
[155/165] Linking C executable zephyr\zephyr_pre0.elf
[156/165] Generating dev_handles.c
[157/165] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[158/165] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[159/165] Linking C executable zephyr\zephyr_pre1.elf
[160/165] Generating linker.cmd
[161/165] Generating isr_tables.c, isrList.bin
[162/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[163/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[164/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[165/165] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 23004 B 32 KB 70.20%
SRAM: 37288 B 211736 B 17.61%
IDT_LIST: 0 GB 2 KB 0.00%
[85/407] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[86/407] Performing build step for 'spm_subimage'
[1/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/sha1.c.obj
[2/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pk.c.obj
[3/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/cipher_wrap.c.obj
[4/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pk_wrap.c.obj
[5/265] Generating include/generated/version.h
[6/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ripemd160.c.obj
[7/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/sha256.c.obj
[8/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/md5.c.obj
[9/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/md.c.obj
[10/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/aesni.c.obj
[11/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/camellia.c.obj
[12/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/aria.c.obj
[13/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/cmac.c.obj
[14/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/sha512.c.obj
[15/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/des.c.obj
[16/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecdsa.c.obj
[17/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/chachapoly.c.obj
[18/265] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[19/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ccm.c.obj
[20/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecdh.c.obj
[21/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecp.c.obj
[22/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/hmac_drbg.c.obj
[23/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/gcm.c.obj
[24/265] Generating include/generated/driver-validation.h
[25/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/hkdf.c.obj
[26/265] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[27/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecjpake.c.obj
[28/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecp_curves.c.obj
[29/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/chacha20.c.obj
[30/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/poly1305.c.obj
[31/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/rsa_alt_helpers.c.obj
[32/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
[33/265] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[34/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
[35/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
[36/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_create.c.obj
[37/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509.c.obj
[38/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/rsa.c.obj
[39/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509write_csr.c.obj
[40/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_crl.c.obj
[41/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_cache.c.obj
[42/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/net_sockets.c.obj
[43/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_crt.c.obj
[44/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/debug.c.obj
[45/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_csr.c.obj
[46/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_ciphersuites.c.obj
[47/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_msg.c.obj
[48/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_cookie.c.obj
[49/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_tls13_keys.c.obj
[50/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_cli.c.obj
[51/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_srv.c.obj
[52/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_ticket.c.obj
[53/265] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[54/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/asn1parse.c.obj
[55/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/asn1write.c.obj
[56/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/base64.c.obj
[57/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_tls.c.obj
[58/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/padlock.c.obj
[59/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/platform.c.obj
[60/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/nist_kw.c.obj
[61/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/platform_util.c.obj
[62/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/version.c.obj
[63/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/oid.c.obj
[64/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/constant_time.c.obj
[65/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_cipher.c.obj
[66/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_client.c.obj
[67/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/bignum.c.obj
[68/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_ecp.c.obj
[69/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_slot_management.c.obj
[70/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_aead.c.obj
[71/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_rsa.c.obj
[72/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_hash.c.obj
[73/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_mac.c.obj
[74/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pem.c.obj
[75/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/random_ext.c.obj
[76/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
[77/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto.c.obj
[78/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_storage.c.obj
[79/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
[80/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkcs12.c.obj
[81/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkcs5.c.obj
[82/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/dhm.c.obj
[83/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkwrite.c.obj
[84/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkparse.c.obj
[85/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/cipher.c.obj
[86/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[87/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedx509.a
[88/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedtls.a
[89/265] Generating include/generated/offsets.h
[90/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[91/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/spm/secure_services.c.obj
[92/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[93/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/spm/spm.c.obj
[94/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[95/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[96/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[97/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[98/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[99/265] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[100/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[101/265] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[102/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[103/265] Generating linker_zephyr_pre1.cmd
[104/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[105/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[106/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[107/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[108/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[109/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[110/265] Linking C static library zephyr\arch\common\libisr_tables.a
[111/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[112/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[113/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[114/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[115/265] Generating linker_zephyr_pre0.cmd
[116/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[117/265] Linking C static library zephyr\arch\common\libarch__common.a
[118/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[119/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[120/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[121/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[122/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[123/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[124/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[125/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[126/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[127/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[128/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[129/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[130/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[131/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[132/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[133/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[134/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[135/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[136/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[137/265] Building C object CMakeFiles/app.dir/src/main.c.obj
[138/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[139/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[140/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[141/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[142/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[143/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[144/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[145/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[146/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[147/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[148/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[149/265] Linking C static library app\libapp.a
[150/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[151/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[152/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[153/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[154/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[155/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[156/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[157/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[158/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[159/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[160/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[161/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[162/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[163/265] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[164/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[165/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[166/265] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[167/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[168/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[169/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[170/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[171/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[172/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
[173/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[174/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
[175/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[176/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[177/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[178/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[179/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[180/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[181/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[182/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[183/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[184/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[185/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[186/265] Linking C static library zephyr\kernel\libkernel.a
[187/265] Linking C static library zephyr\libzephyr.a
[188/265] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[189/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[190/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[191/265] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[192/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[193/265] Generating ../../../include/generated/libc/minimal/strerror_table.h
[194/265] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[195/265] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[196/265] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[197/265] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[198/265] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[199/265] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[200/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[201/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[202/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[203/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[204/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[205/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[206/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[207/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[208/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[209/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[210/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[211/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[212/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[213/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[214/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[215/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[216/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[217/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[218/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[219/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[220/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[221/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[222/265] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[223/265] Linking C static library zephyr\lib\posix\liblib__posix.a
[224/265] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[225/265] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[226/265] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[227/265] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[228/265] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/drivers/entropy/entropy_cc3xx.c.obj
[229/265] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[230/265] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[231/265] Linking C static library zephyr\subsys\random\libsubsys__random.a
[232/265] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[233/265] Linking C static library zephyr\drivers\console\libdrivers__console.a
[234/265] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[235/265] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[236/265] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/cortex_m_systick.c.obj
[237/265] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[238/265] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[239/265] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[240/265] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[241/265] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[242/265] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[243/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[244/265] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[245/265] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[246/265] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[247/265] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[248/265] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[249/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[250/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[251/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[252/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[253/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
[254/265] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[255/265] Linking C executable zephyr\zephyr_pre0.elf
[256/265] Generating dev_handles.c
[257/265] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[258/265] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[259/265] Linking C executable zephyr\zephyr_pre1.elf
[260/265] Generating linker.cmd
[261/265] Generating isr_tables.c, isrList.bin
[262/265] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[263/265] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[264/265] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[265/265] Linking C executable zephyr\zephyr.elf
FLASH: 65024 B 64 KB 99.22%
SRAM: 11848 B 32 KB 36.16%
[89/407] Generating zephyr/b0_container.hex
[90/407] Performing build step for 'mcuboot_subimage'
[1/211] Generating include/generated/version.h
[2/211] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/211] Generating include/generated/driver-validation.h
[4/211] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/211] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/211] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/211] Generating include/generated/offsets.h
[8/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[9/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[10/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[11/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[12/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[13/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[14/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[15/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[16/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[17/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[18/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[19/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[20/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[21/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[22/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[23/211] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[24/211] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[25/211] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[26/211] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[27/211] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[28/211] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[29/211] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[30/211] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[31/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[32/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[33/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[34/211] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[35/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[36/211] Generating linker_zephyr_pre1.cmd
[37/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[38/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[39/211] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[40/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[41/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[42/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[43/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[44/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[45/211] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[46/211] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[47/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[48/211] Generating linker_zephyr_pre0.cmd
[49/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[50/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[51/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[52/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[53/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[54/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[55/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[56/211] Linking C static library zephyr\arch\common\libisr_tables.a
[57/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[58/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[59/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[60/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[61/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[62/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[63/211] Linking C static library zephyr\arch\common\libarch__common.a
[64/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[65/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[66/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[67/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[68/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[69/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[70/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[71/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[72/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[73/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[74/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[75/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[76/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[77/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[78/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[79/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[80/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[81/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[82/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[83/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[84/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[85/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[86/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[87/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[88/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[89/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[90/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[91/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[92/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[93/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[94/211] Generating zephyr/autogen-pubkey.c
[95/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[96/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[97/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[98/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[99/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[100/211] Building C object CMakeFiles/app.dir/os.c.obj
[101/211] Building C object CMakeFiles/app.dir/main.c.obj
[102/211] Building C object CMakeFiles/app.dir/keys.c.obj
[103/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[104/211] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[105/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[106/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[107/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[108/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[109/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[110/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[111/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[112/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[113/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[114/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[115/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
[116/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[117/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
[118/211] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[119/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
[120/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[121/211] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[122/211] Generating ../../../include/generated/libc/minimal/strerror_table.h
[123/211] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[124/211] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[125/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[126/211] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[127/211] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[128/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[129/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[130/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[131/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[132/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[133/211] Linking C static library app\libapp.a
[134/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[135/211] Linking C static library zephyr\libzephyr.a
[136/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[137/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[138/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[139/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[140/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[141/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[142/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[143/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[144/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[145/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[146/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[147/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[148/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[149/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[150/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[151/211] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[152/211] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[153/211] Linking C static library zephyr\lib\posix\liblib__posix.a
[154/211] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[155/211] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[156/211] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[157/211] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[158/211] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[159/211] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[160/211] Linking C static library zephyr\drivers\console\libdrivers__console.a
[161/211] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[162/211] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[163/211] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[164/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
[165/211] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[166/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[167/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[168/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[169/211] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[170/211] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[171/211] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[172/211] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[173/211] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[174/211] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[175/211] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[176/211] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[177/211] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[178/211] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[179/211] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[180/211] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[181/211] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[182/211] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[183/211] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[184/211] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[185/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[186/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[187/211] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[188/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[189/211] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[190/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[191/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[192/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[193/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[194/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[195/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[196/211] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[197/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[198/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[199/211] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[200/211] Linking C static library zephyr\kernel\libkernel.a
[201/211] Linking C executable zephyr\zephyr_pre0.elf
[202/211] Generating dev_handles.c
[203/211] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[204/211] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[205/211] Linking C executable zephyr\zephyr_pre1.elf
[206/211] Generating linker.cmd
[207/211] Generating isr_tables.c, isrList.bin
[208/211] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[209/211] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[210/211] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[211/211] Linking C executable zephyr\zephyr.elf
FLASH: 44680 B 48 KB 90.90%
SRAM: 25360 B 211736 B 11.98%
[165/407] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/nonsecure/soc_secure.c.obj
C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/nonsecure/soc_secure.c: In function 'soc_secure_mem_read':
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\nonsecure\soc_secure.c:19:2: warning: 'spm_request_read' is deprecated [-Wdeprecated-declarations]
19 | return spm_request_read(dst, (uint32_t)src, len);
In file included from C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\nonsecure\soc_secure.c:10:
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\include\secure_services.h:88:18: note: declared here
88 | __deprecated int spm_request_read(void *destination, uint32_t addr, size_t len);
[182/407] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/drivers/entropy/entropy_cc3xx.c.obj
C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/drivers/entropy/entropy_cc3xx.c: In function 'entropy_cc3xx_rng_get_entropy':
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\drivers\entropy\entropy_cc3xx.c:65:3: warning: 'spm_request_random_number' is deprecated [-Wdeprecated-declarations]
65 | ret = spm_request_random_number(buffer + offset,
In file included from C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\drivers\entropy\entropy_cc3xx.c:18:
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\include\secure_services.h:75:18: note: declared here
75 | __deprecated int spm_request_random_number(uint8_t *output, size_t len, size_t *olen);
[192/407] Building C object modules/nrf/lib/bin/lwm2m_carrier/CMakeFiles/..__nrf__lib__bin__lwm2m_carrier.dir/os/lwm2m_carrier.c.obj
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\lib\bin\lwm2m_carrier\os\lwm2m_carrier.c:15:31: warning: 'config' defined but not used [-Wunused-variable]
15 | static lwm2m_carrier_config_t config;
[267/407] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_download.c.obj
C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/net/lib/fota_download/src/fota_download.c: In function 'fota_download_s0_active_get':
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\net\lib\fota_download\src\fota_download.c:348:2: warning: 'spm_s0_active' is deprecated [-Wdeprecated-declarations]
348 | err = spm_s0_active(PM_S0_ADDRESS, PM_S1_ADDRESS, s0_active);
In file included from C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\net\lib\fota_download\src\fota_download.c:20:
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\include\secure_services.h:99:18: note: declared here
99 | __deprecated int spm_s0_active(uint32_t s0_address, uint32_t s1_address, bool *s0_active);
[382/407] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\Users\Chetan.Kale\nordic_ncs\toolchains\v2.1.3\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware\build\zephyr && C:\Users\Chetan.Kale\nordic_ncs\toolchains\v2.1.3\opt\bin\cmake.exe -E echo ""
c:/users/chetan.kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `datas' will not fit in region `FLASH'
c:/users/chetan.kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 5164 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\Users\Chetan.Kale\nordic_ncs\toolchains\v2.1.3\opt\bin\cmake.EXE' --build 'c:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it
I tried to search on Nordic forum but the solution provided/worked for others did not worked for me. Can you please help me to solve this issue asap ?
Thank you!
Chetan
  • No, that is the default key. Your key file is named 'private.pem' based on the Kconfig you posted earlier. Not sure why you didn't get the warning in the build log though.
    To apply Kconfig fragment to the bootloader build, you can create a child_image like the one attached below and place it in your project root, then do a pristine build.
    7774.child_image.zip
  • Okay, I was suppose to say that. So what I did is I added the my private key absolute path to mcuboot.conf file.
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_MULTITHREADING=y
    # MCUboot requires a large stack size, otherwise an MPU fault will occur
    CONFIG_MAIN_STACK_SIZE=10240
    # Enable flash operations
    CONFIG_FLASH=y
    # This must be increased to accommodate the bigger images.
    CONFIG_BOOT_MAX_IMG_SECTORS=256
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/bootloader_pri_key.pem"
    After build I see that the path in .config file has changed to my private.pem file.
    And after flashing the firmware it worked.
  • Happy to see that it is working now. Thank you for the update.
  • Also, can you please confirm below questions:
    1. I can use app_update.bin (assuming already being signed now) file for doing FOTA update using AWS S3 as previously it use to work.
    2. Can we use this private key for multiple device like we will be manufacturing more than 10000 devices.
    3. What will happen if I lost the private key? Will I be able to use other key and send an FOTA update to older firmware where it has the old private key which is lost ?
  • 1. yes
    2. yes, the devices will include the public key needed to verify if the update was signed with your private key.
    3. The devices will only accept updates from images which have been signed with your current key. If you lose your private key, you will lose the ability to push new updates to your devices. Therefore, it is critical that you keep the private key securely stored somewhere.
